I have a freshly flashed TX1 with Jetpack 2.3 and the ethernet adapter is not working. It was apparently able to complete the installation with the device connected to the network, but the ethernet interface has not worked since then.
When I run ifconfig I get a very strange looking interface name instead of the normal eth0. I’ve tried powering off the board completely and restarting, but the problem remains.
ubuntu@tegra-zac-2:~$ ifconfig
enx00044b5abce0 Link encap:Ethernet HWaddr 00:04:4b:5a:bc:e0
inet6 addr: fe80::204:4bff:fe5a:bce0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3306 errors:0 dropped:0 overruns:0 frame:0
TX packets:7 errors:366 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:427541 (427.5 KB) TX bytes:1161 (1.1 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:559 errors:0 dropped:0 overruns:0 frame:0
TX packets:559 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:40908 (40.9 KB) TX bytes:40908 (40.9 KB)
wlan0 Link encap:Ethernet HWaddr 00:04:4b:5a:bc:de
inet addr:192.168.1.190 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fe5a:bcde/64 Scope:Link
RX packets:3676 errors:0 dropped:0 overruns:0 frame:0
TX packets:310 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:538334 (538.3 KB) TX bytes:31441 (31.4 KB)
