Ethernet issue in orin nanoo
kernel version 5.10.104
sudo dmesg | grep 8169
This is case of carrier board of orin nano 8GB
for a release image it showed 3 ethernet eth0 eth1 and eth2
but now its showing only 1 ethernet
lspci -nnv
ifconfig -a
inside the deconfig file R8169 was made y and R8168 n
what is the issue …
Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Please move to new release.
Also, I don’t know what you are talking about. Even old release won’t have 3 ethernet.
Are you adding some devices by yourself?
I added a realtek ethernet 2.5G , its not showing
I changed R8169 to y in the defconfig file
and R8168 to n
There is a default realtek ethernet that is using r8168 on Orin Nano module and shouldn’t be removed.
Please upgrade to rel-35.4.1 and it will use r8168 driver for on-board ethernet by default.
