Ethernet Issue
For some reason the green LED on the ethernet port of the Nvidia Jetson Xavier we’re using isn’t coming on whenever we connect an ethernet interface to it. Furthermore, the device is unable to connect with any ethernet based device. Is there a specific cause and potential fix to this issue? Thanks. Attached is a message that comes on the desktop.Screenshot from 2021-11-02 17-03-51
Hi, is it normal before? Have you changed anything before this? If not, it might be something broken on board. You may need to run RMA for it. Jetson FAQ | NVIDIA Developer
