Hardware: NVIDIA Jetson AGX Thor Developer Kit (stock, confirmed via /proc/device-tree/model)
BSP: JetPack 7.2 / L4T R39.2.0 GA, clean install
- nvidia-l4t-core: 39.2.0-20260601141651
- UEFI/system firmware: 39.2.0-gcid-45755727 (matches OS GCID)
Issue: The onboard 5GbE RJ45 port does not work. The PCIe NIC behind it never
enumerates — it is absent from lspci, and no corresponding net interface exists.
Wi-Fi and NVMe work normally.
At boot, only three PCIe controllers come up. Controller-2 reports link down and
is powered off:
tegra264-pcie a808400000.pcie: PCIe Controller-1 Link is UP (Speed: 2)
tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is DOWN
tegra264-pcie a808420000.pcie: PCIe Controller-2 Link is DOWN and not hot-plug-capable. Turning off Controller.
tegra264-pcie a808480000.pcie: PCIe Controller-5 Link is UP (Speed: 4)
Resulting lspci (Controller-2 / the NIC is the only missing device):
0000:01:00.0 3D controller: NVIDIA Corporation Device 2b00
0001:01:00.0 Network controller: Realtek RTL8852CE (Wi-Fi) ← Controller-1
0005:01:00.0 Non-Volatile memory controller: Sandisk WD SN5000S (NVMe) ← Controller-5
Controller-1 (Wi-Fi) and Controller-5 (NVMe) account for both removable PCIe
devices, so Controller-2 is the soldered onboard 5GbE NIC. Its link fails to train.
Already checked:
- Firmware and OS are matched R39.2.0 (same GCID), so this is not a UEFI/OS mismatch.
- echo 1 > /sys/bus/pci/rescan does not recover it (expected, controller is powered off).
- This is the onboard RJ45, not the QSFP/MGBE interfaces — the mgbeX_0 interfaces
are present and unrelated to this issue.
Questions:
- Is the onboard NIC failing to enumerate a known issue on R39.2.0 / JetPack 7.2?
- Is Controller-2 expected to host the onboard NIC, and is there anything in the
R39.2.0 device tree / UPHY config that would leave it disabled or untrained?
- Did the same unit work on R38.4 (JetPack 7.1)? Recommended next step to confirm
hardware vs. software regression?
dmesg and full lspci -nnk attached.
dmesg.txt (126.6 KB)
lspci.txt (968 Bytes)
Run
nmcli
# Confirm your rj45 ethernet is named enP2p1s0
# If not correct the next line. Than run the commands.
IF=enP2p1s0
ip link show "$IF"
sudo ethtool "$IF" | egrep 'Link detected|Speed|Duplex|Auto-negotiation'
nmcli -f DEVICE,TYPE,STATE,CONNECTION dev status
# Then run this to try to bring up your link.
sudo ip link set enP2p1s0 up
sudo ethtool enP2p1s0
If the device is up you could do following to set it up with DHCP.
IF=enP2p1s0
CON=realtek-r8126
sudo nmcli con delete "$CON"
sudo nmcli con add type ethernet \
ifname "$IF" \
con-name "$CON" \
autoconnect yes \
ipv4.method auto \
ipv6.method auto
sudo nmcli dev set "$IF" managed yes
sudo nmcli con up "$CON"
sorry, I am just curious why are you asking a question that I want to ask here …?
Was this device able to have working RJ45 before this version?
Really I just want to get it working on the latest JetPack 7.2. The reason I upgraded was it quit working. Here is my nmcli output also. The interface name mentioned did not show up.
nmcli.txt (2.5 KB)
I don’t think that nmcli matters here if lspci does not show any device to you.
Is this board really able to detect the device when you are using Jetpack7.1?
Just want to clarify if this is software issue or hardware problem. Reflashing the board might help clarify.
It was working then quit working. I reflashed and it still didn’t work.
This seems to be a hardware problem.
Please go ahead with RMA process.
I guess the good news is the wifi still works. I just wanted to have a wired ethernet connection. If it is hardware how do I get it fixed? Is it covered under warranty? Where is the link for RMA?
We don’t do hardware repair in such forum support way.
RMA Procedure:
- Go to Support Home Page | NVIDIA
- Select “Live Chat” from the options near the top of the page.
- Enter your personal information.
- Select the appropriate product from the drop-down list (“Tegra” in this case).
- Submit the request.
- If the Service agent is unable to resolve the technical issue, an RMA (Return Material Authorization) will be initiated.
