Ethernet querry
Jetpack 5.1.1 orin nano
L4T 35.3.1
I have 3 ethernet ports 1 directly connected to SOM and 2 via PCI
setting ip statically
eth0 ip 192.168.1.0
eth1 ip 192.168.1.10 connected to lap via ethernet
eth2 192.168.1.20
lap ip also in same domain
I'm able to ping to all the 3 ethernet port
is this possible
I need to set 3 ip statically in same domain using sudo ifconfig eth<num> <ip> up
but when i ping <ip_which_is_not_connected> it should not ping ,
Not sure what are you talking about.
Please share a diagram for how does the connection look like now.
Its a carrier board
1 connection to ethernet from som directly
2 eth connections are through pci
i have connected to one of the ethernet port and set all eth ports ip statically in same domain
even though i connected 1 ethernet to lap
iamable to ping to all 3 ip of the 3 ethernet
Your whole comment just went mystery from this part.
Not really understand what are you trying to say here. That is why I said share a diagram of your connection.
