Ethernet Wake-On-Lan
Regarding Pin A47 (GPIO38) which implement the function Ethernet Wake-On-Lan Status:
  1. How this signal is acting?
  2. should we implement a circuit in the electrical scheme to enable this feature?
    Regards,
    Itai
It depends on how you use it. It is a reserved pin for WOL if necessary.
Hi Trumany,
Thanks for the reply.
We would like to use it to wake the AGX with it.
What should we implement in the electrical schematic for it?
The circuit on module side is as below in P3737_A05 schematic, the other side circuit depends on your device requests.
