Etson Nano + JetPack 4.5: System won't boot after installing Docker and ROS2 (No display, no Wi-Fi, OLED not responding)
📌 Device Info
  • Device: Jetson Nano 4GB
  • OS: JetPack 4.5 (L4T R32.5.0), flashed via SD card image
  • Display: OLED panel (usually shows IP at boot)
  • Network: Wi-Fi was previously configured and connected successfully
⚙️ Installation Process
  1. Successfully flashed JetPack 4.5 to SD card — system booted normally, OLED panel worked.
  2. Installed Docker (using standard Jetson installation instructionshttps://jetbot.org/master/software_setup/docker.html).
  3. Installed ROS2 (foxy).
  4. After reboot:
  • OLED panel is blank
  • Wi-Fi is no longer auto-connecting
🐞 What I’ve tried so far
  • Swapped SD card back to an older one (without Docker/ROS2) → boots normally → likely not hardware-related.
  • Checked SD card insertion — secure, but no display or network.
  • Attempted to manually remove Docker containers via external Linux machine (mounting the SD card) → no success.
  • Tried disabling auto-start Docker container with:
    sudo docker update --restart=no jetbot_display
    → but the system never gets far enough to apply it.
Please refer to About the process of building ROS2 docker container in Jetson nano devkit (jp4.5.1) - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to see if can help. Thanks
