Evaluating LiDAR in NuRec for a digital‑twin showcase (images‑only pipeline today)
Hi all,
We’re preparing a realistic simulation showcase toward a future digital twin.
Current workflow I follow https://docs.nvidia.com/nurec/robotics/neural_reconstruction_mono.html: smartphone‑camera images → COLMAP → 3DGRUT → USD as appearance layer.
We also have a survey‑grade point‑cloud baseline from a previous mapping session and associated USDs as a base layer.
We are evaluating NuRec for future USD generation. Documentation and talks suggest NuRec/NCore can ingest images and auxiliary LiDAR.
Questions:
  1. In NuRec/NCore, is LiDAR strictly required or treated as optional auxiliary input alongside images?
  2. If we add iPad Pro LiDAR scans per zone, what practical benefits should we expect vs. images‑only? Any indicative metrics or best practices?
  3. Using the legacy survey point cloud as auxiliary input: expected benefits vs. images‑only, and when is it sufficient without new iPad LiDAR?
  4. Accepted LiDAR formats and manifest requirements (timestamps, intrinsics/extrinsics, units/axes, transforms) for NCore validation.
  5. If images and LiDAR are captured in separate passes, is rigid registration (ICP/control points) acceptable, or do you recommend synchronized RGB‑D (ARKit) for depth‑supervised runs?
  6. USD composition tips when mixing point clouds and 3DGS appearance layers (references/payloads vs sublayers; masking overlaps).
Thanks for any pointers to sample datasets or documentation.
    • LiDAR is not required but is currently recommended to resolve scale ambiguity or improve pose optimization
    • You should expect faster convergence and avoidance of the “scale ambiguity” common in monocular photogrammetry (COLMAP).
    • In general, keep capture zones small and static, and over‑capture overlapping corridors so registration errors don’t accumulate.
    • Using your existing survey-grade point cloud is a valid workflow, provided the data is static.
      • Expected Benefits: This serves as a “ground truth” geometric scaffold. It ensures that the generated 3DGS (3D Gaussian Splatting) appearance layer aligns perfectly with your existing USD base layer.
      • When is it sufficient? If your scene geometry hasn’t changed (i.e., walls/infrastructure are the same), the legacy cloud is superior to iPad LiDAR due to higher precision and range. You would only need new iPad LiDAR if you need to capture new geometric features that aren’t in the legacy scan.
    • xyz_s: Start point coordinates (float32, shape [N,3]).
    • xyz_e: End point coordinates, motion compensated (float32, shape [N,3]).
    • intensity: Normalized intensity values ranging from 0.0 to 1.0 (float32, shape [N]).
    • timestamp_us: Point timestamps in microseconds (uint64, shape [N]).
    • T_sensor_rig: The Lidar-to-rig transformation matrix (float32, shape [4,4]).
    • frame_labels: Frame-specific label data (object, shape varies).
    • model_elements: Row and column indices within the LiDAR model (uint16, shape [N,2]).
    • Synchronized RGB-D (ARKit) is recommended. Strict rigid registration (ICP) alignment can work but when not done correctly can introduce alignment errors that can cause “blurring” or artifacts.
    • Use a “References” workflow rather than Sublayers for heavy assets.
      • Create a root Assembly.usd.
      • Reference your static Survey_PointCloud.usd (set to kind = prop).
      • Reference your dynamic NuRec_Appearance.usd (3DGS).
    • Prefer the survey mesh as ground truth for large‑scale structure (floors, walls), and:
      • Either exclude those regions from NuRec training using masks, or in USD, mark survey geometry as purpose=render and NuRec 3DGS as complement (or vice versa) depending on which asset you trust more visually.
Thanks !
