once a model is trained in Modulus, how can I evaluate the results for a range of inputs? I’m expecting to get the outputs instantaneously without running the simulations.
Hi @smraniaki
There are a couple of ways, the first “Modulus workflow” approach is using the evaluate mode built into the solver: solver.eval()
. This will just run any inferencer / validators you’ve added. See the _eval
function in the trainer: https://gitlab.com/nvidia/modulus/modulus/-/blob/release_22.09/modulus/trainer.py#L749
Alternatively you could look at loading the model checkpoint manually using a Modulus model. This checkpoint is saved in the outputs folder of your run. Then running inference manually in a typical PyTorch method:
https://gitlab.com/nvidia/modulus/modulus/-/blob/release_22.09/modulus/models/arch.py#L165
