Event Handlers with pgi
Hello All,
I am new to using C++ with MPI.
I have a MPI program which is running in master slave mode. My MPI slave program dies due to its nature and I want to implement timeout event on master side. Does anyone has any suggestions on how that can be done with C++.
Regards
Abhi
Hi Abhi,
Granted, I’m not a MPI expert but I don’t believe there is a timeout event. Are you blocking on an “MPI_Wait” call? If this is the case, then consider using the non-blocking “MPI_Test”. This means you’ll need to change your code to do polling, but you could check the time after each call to MPI_Test to see if the slave has “timed out”.
Has any other user encountered this issue?
  • Mat
