It’s because there’s a bug in nv_egl_util.cpp when it checks for
eglGetSystemTimeNV and eglGetSystemTimeFrequencyNV. The correct way to do this is to FIRST check whether the extension name exists in the EGL_EXTENSIONS string, and THEN ask for the function pointer.
Here’s a quick patch to fix it:
Source: http://jangutter.com/files/tdk-samples-extension-check-fix.patch
No guarantees that the forum won’t mangle it, but here it is just in case you’re afraid to click on the link.
--- TDK_Samples/tegra_android_native_samples_v10p12/libs/jni/nv_egl_util/nv_egl_util.cpp.orig 2013-09-18 16:29:38.007711196 +0200
+++ TDK_Samples/tegra_android_native_samples_v10p12/libs/jni/nv_egl_util/nv_egl_util.cpp 2013-09-18 16:29:47.735759466 +0200
@@ -254,6 +254,33 @@
return false;
+bool NvEGLUtil::checkExtension(const char* extName)
+ ** This code is adapted from http://www.mesa3d.org/brianp/sig97/exten.htm
+ ** Search for extName in the extensions string. Use of strstr()
+ ** is not sufficient because extension names can be prefixes of
+ ** other extension names. Could use strtok() but the constant
+ ** string returned by glGetString can be in read-only memory.
+ ** This code is relatively safe, as long as extName is a well-behaved string
+ const char *p = (const char *) eglQueryString(getDisplay(),EGL_EXTENSIONS);
+ size_t extNameLen = strlen(extName);
+ const char *end = p + strlen(p);
+ while (p < end) {
+ size_t n = strcspn(p, " ");
+ if ((extNameLen == n) && (strncmp(extName, p, n) == 0)) {
+ return true;
+ p += (n + 1);
+ return false;
bool NvEGLUtil::createSurface()
if (m_status >= NV_HAS_SURFACE)
@@ -437,8 +464,13 @@
m_nvTimeExtensionQueried = true;
- m_eglGetSystemTimeFrequencyNVProc = (PFNEGLGETSYSTEMTIMEFREQUENCYNVPROC) eglGetProcAddress("eglGetSystemTimeFrequencyNV");
- m_eglGetSystemTimeNVProc = (PFNEGLGETSYSTEMTIMENVPROC) eglGetProcAddress("eglGetSystemTimeNV");
+ if (checkExtension("EGL_NV_system_time")) {
+ m_eglGetSystemTimeFrequencyNVProc = (PFNEGLGETSYSTEMTIMEFREQUENCYNVPROC) eglGetProcAddress("eglGetSystemTimeFrequencyNV");
+ m_eglGetSystemTimeNVProc = (PFNEGLGETSYSTEMTIMENVPROC) eglGetProcAddress("eglGetSystemTimeNV");
+ } else {
+ m_eglGetSystemTimeFrequencyNVProc = (PFNEGLGETSYSTEMTIMEFREQUENCYNVPROC) NULL;
+ m_eglGetSystemTimeNVProc = (PFNEGLGETSYSTEMTIMENVPROC) NULL;
// now, we'll proceed through a series of sanity checking.
// if they all succeed, we'll return.
@@ -456,6 +488,7 @@
if (time1 != time2) // quick sanity only...
// we've sanity checked:
+ // - extension is advertised
// - fn pointers non-null
// - freq non-zero
// - two calls to time sep'd by sleep non-equal
