Everything is undefined ? First time cuda programming
I am currently writing my first CUDA program. I am transferring my serial Jacobi Method code to a parallel code. I left some for loops in my host code and when I tried compiling my code I received a lot of undefined errors. These errors only occur for my non-array values. For instance using i or j to iterate in a for loop. The only solution I can find is to redefine the variable every time I use it, which doesn’t make sense. Can someone explain this error.
Also what is this error?
calling a host function from a device/global function is only allowed in device emulation mode
Show a small code fragment which gives the error…
You must be trying to call a function such as printf from within a device or global function. Again, can you show an example?
WITH EXAMPLES:
I am currently writing my first CUDA program. I am transferring my serial Jacobi Method code to a parallel code. I left some for loops in my host code and when I tried compiling my code I received a lot of undefined errors. These errors only occur for my non-array values. For instance using i or j to iterate in a for loop. The only solution I can find is to redefine the variable every time I use it, which doesn’t make sense. Can someone explain this error. This is the same code I used in my serial version so I am unsure why they are acting this way.
[codebox]unsigned int j, i;
for (i=0; i<row; i++)
for (j=0; j<col; j++)
fscanf(inFile,"%f", &Mat[i][j]);
fscanf(inFile,"%f",&BMat[i]);[/codebox]
(118): calling a host function from a device/global function is only allowed in device emulation mode
I’m not not using any printf or scanf in the kernel Here is my kernel for dividing the A matrix to the Up, Low, and Inverse Diagonal matrices.
[codebox]#ifndef DIVIMATRIX_KERNEL
#define DIVIMATRIX_KERNEL
#include <stdio.h>
#include <math.h>
global void Jacobi_It(float* A, float* Up, float* Low, float* InvDia, float* Xold, unsigned int row, unsigned int col)
unsigned int n;
// Block Index
int bx= blockIdx.x;
int by= blockIdx.y;
// Thread Index
int tx= threadIdx.x;
int ty= threadIdx.y;
// Step Size
unsigned int stpsz=BLOCK_SIZE;
// Start index for each sub-matrix to be processed
int aBegin=rowBLOCK_SIZEby;
// End index for sub-matrix
int aEnd=aBegin+row-1;
for (n=aBegin; n<=aEnd; n+=stpsz)
{__shared__ float SubA[BLOCK_SIZE][BLOCK_SIZE];
 __shared__ float SubUp[BLOCK_SIZE][BLOCK_SIZE];
 __shared__ float SubLow[BLOCK_SIZE][BLOCK_SIZE];
 __shared__ float SubInD[BLOCK_SIZE][BLOCK_SIZE];
 __shared__ float SubX[BLOCK_SIZE];
SubA[tx][ty]=A[n+row*tx+ty];
if (bx == by)
   {if (SubA[tx][tx]==0)
   SubInD[tx][tx]=0;
    else
      {SubInD[tx][tx]=1/SubA[tx][tx];
   SubUp[tx][tx]=0;
   SubLow[tx][tx]=0;
if (ty > tx)
  {SubUp[tx][ty]=SubA[tx][ty];
   SubLow[tx][ty]=0;
   SubInD[tx][ty]=0;
if (tx > ty)
  {SubUp[tx][ty]=0;
   SubLow[tx][ty]=SubA[tx][ty];
   SubInD[tx][ty]=0;
 if (bx > by)
   {SubInD[tx][ty]=0;
SubUp[tx][ty]=0;
 if (by > bx)
   {SubInD[tx][ty]=0;
    SubLow[tx][ty]=0;
SubInD[tx][ty]=SubA[tx][ty];
 SubX[tx]=0;
__syncthreads();
 Up[n+row*tx+ty]=SubUp[tx][ty];
 Low[n+row*tx+ty]=SubLow[tx][ty];
 InvDia[n+row*tx+ty]=SubInD[tx][ty];
 Xold[n+row*tx]=SubX[tx];
#endif // ifndef DIVIMATRIX_KERNEL
[/codebox]
Ok I feel as if the compiler thinks my host file is a device file (not sure what that means). At function in the host code (printf, fscanf, etc) I receive an error from the compiler:
At the beginning I receive:
error: identifier “main” is undefined
Here is first few lines of my host code
[codebox]#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <DiviMatrix.cu>
define CONVERGENCE 0.001
define MAXITERATIONS 50
define BLOCK_SIZE 16
main(){
float UpSum=0; /* UpMat sum used for Jacobi It */
float LowSum=0; /* LowMat sum used for Jacobi It */
unsigned int count_it=1; /* Number of iterations */
unsigned int j, i;
unsigned int count_conv=0; /* Count_conv argument if all converge */
unsigned int row, col; /* Number of Rows and Columns in A Matrix */
unsigned int placeholder, n; /* Placeholder - tells which rows to switch */
float SubMat /* Substitution Variable */
FILE *inFile;
/******************** Read in A and B Matrix ***********************/
inFile=fopen(“JacobiMatrix.dat”,“r”); /* Matrix File Extension */
if (inFile == NULL) /* If the program doesn’t exist */
printf(“\n The file was not successfully opened”);
printf(“\n Please Check that the file JacobiMatrix.dat exists. \n”);
exit(1);
fscanf(inFile,“%d”, &row);
fscanf(inFile,“%d”, &col);
float Mat[row][col]; /* A matrix */
float BMat[row]; /* B matrix */
float Inv_DiaMat [row][col]; /* Inverse Diagonal Matrix */
float UpMat [row][col]; /* Upper Matrix */
float LowMat [row][col]; /* Lower Matrix */
float Xold [col]; /* Vector of previous x values */
float XVec [col]; /* Vector of current x values */
fclose(inFile);
[/codebox]
I think it would be useful to know what’s on line 118 of the file :)
N.
