I’m trying to build an app that monitors people entering a ROI, with rtsp cc-cam streams as input.
The base Python app deepstream-rtsp-in-rtsp-out works fine and is a great base to build my app on top of.
The only problem I’m facing is that the script suddenly stops after random amounts of time with this message:
End-of-stream
I think the problem is with the input stream from live camera, because the problem doesn’t happen (or at least not that often) with a self-hosted rtsp server streaming a video file.
I’d like to at least configure the thing so that it keeps the connection alive and/or tries to reconnect if it doesn’t receive data instead of terminating. The script should ideally be able to run forever with no interruptions and no manual operations needed.
NOTE: Yesterday I started the script and it kept running for 24h+ without any problem. Once I stopped it and tried to start it again (even after a Jetson reboot) it just keeps stopping with the End-of-stream message after a short while, like it always did.
• Hardware Platform: Jetson Nano
• DeepStream Version: 6.1.1
• JetPack Version: 5.0.2
• Issue Type: Question
