I have a problem with the understanding of the subroutine’s parameter in the example code for the matrix multiplication (NVIDIA_CUDA_Programming_Guide_2.1 - page 77) - the header of the subroutine is posted below.
A should be a matrix. But the soubroutine will get a constant pointer to a float A… and not to a matrix.
Now my problem: how exactly do I have to call this subroutine Mul from my main-routine? How does the declaration of the matrix in the main-routine looks like? I tried out a lot of different ways but I could never call the subroutine with a matrix … I appreciate any help!
// Host multiplication function
// Compute C = A * B
// hA is the height of A
// wA is the width of A
// wB is the width of B
void Mul(const float* A, const float* B, int hA, int wA, int wB, float* C)
I know that fact. Unfortunately I could not use this fact to implement a solution. I always got errors concerning unmatching format of the parameter while calling the subroutine…
I defined the matrix in the main routine:
float Matrix1[N][N]; // N is defined as a constant integer value
Mul(Matrix1); // call of subroutine Mul with Matrix1...
// in c the Arrays are always call by reference therefore Matrix1 should be a Pointer to the Array, isn't it?
// I also tried &Matrix1 -> did not work either!
I am mistaking something? Can someone give me a running solution?!
You are welcome, but might I suggest a spot of revision on pointers and arrays in C and/or C++. It is pretty central to being able to write expressive, functional code in CUDA.
