Jetson Orin Nano 8GB Dev Kit
• DeepStream Version
7.0
6.0
• TensorRT Version
8.6.2
I want a Graph Composer graph example that uses the Jetson’s onboard CSI camera as input. The reference test graphs tend to crash after a few frames (deepstream-test1 and test2). There does not appear to be any references for CSI inputs. Thanks!
Run the test graphs with a stock install of JP6, DS7 and Graph Composer 4.0 on the Jetson. Jetson is the gxf_server, Windows 10 or Ubuntu 22 is the client.
What kind of CSI camera? The Argus API supported CSI camera( Accelerated GStreamer — NVIDIA Jetson Linux Developer Guide 1 documentation )or the ordinary CSI camera which only support V4L2 APIs?
The NvDsCameraSrcInput extension can be used as the source input.
Thanks. I am using standard Pi HQ camera (tested and working with JP6 after resistor removal). It is on /dev/video0.
Whenever I attempt to run with Camera Source Input with the device, I get an error. I get it if I run remotely or locally.
Thoughts?
xxxx@jetson-orin-nano:~/graphs$ /opt/nvidia/graph-composer/execute_graph.sh test_csi.yaml -d target_aarch64.yaml
Graphs: test_csi.yaml
Target: target_aarch64.yaml
Running test_csi.yaml
[INFO] Writing manifest to /tmp/ds.test_csi/manifest.yaml
2024-06-25 10:28:28,755 - Registry - INFO - Installing graph ...
2024-06-25 10:28:28,785 - Registry - INFO -
Requested target configuration:
arch: aarch64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.4 tensorrt: 8.6.2 deepstream: 7.0 vpi: 3.1.5
Selected extension variants:
NvDsInterfaceExt
Version: 1.5.0 Variant: arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0
StandardExtension
Version: 2.5.0 Variant: arch: aarch64 os: linux distribution: ubuntu_22.04 cuda: 12.2
MultimediaExtension
NvDsBaseExt
NvDsMuxDemuxExt
NvDsOutputSinkExt
NvDsVisualizationExt
HttpExtension
Version: 0.4.0 Variant: arch: aarch64 os: linux distribution: ubuntu_22.04
NvDsSourceExt
Graph installed to output directory
2024-06-25 10:28:34.484 INFO gxf/gxe/gxe.cpp@183: Creating context
2024-06-25 10:28:34.630 INFO gxf/gxe/gxe.cpp@108: Loading app: '/home/user/graphs/test_csi.yaml'
2024-06-25 10:28:34.631 INFO gxf/std/yaml_file_loader.cpp@174: Loading GXF entities from YAML file '/home/user/graphs/test_csi.yaml'...
2024-06-25 10:28:34.634 INFO gxf/gxe/gxe.cpp@272: Initializing...
2024-06-25 10:28:34.656 INFO extensions/nvdsbase/nvds_scheduler.cpp@272: This program is linked against GStreamer 1.20.3
2024-06-25 10:28:34.657 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux Stream Muxer10
2024-06-25 10:28:34.658 INFO extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin On Screen Display21
2024-06-25 10:28:34.658 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@24: initialize: nvvideorenderersinkbin NVidia Video Renderer27
2024-06-25 10:28:34.659 INFO extensions/nvdssource/nvcamerasrcbin.hpp@23: initialize: nvcamerasrcbin Camera Source Input34
2024-06-25 10:28:34.659 INFO gxf/gxe/gxe.cpp@279: Running...
2024-06-25 10:28:34.659 INFO extensions/nvdsbase/nvds_scheduler.cpp@120: Scheduling 4 elements and 0 components
2024-06-25 10:28:34.659 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux Stream Muxer10
2024-06-25 10:28:34.680 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux Stream Muxer10
2024-06-25 10:28:34.680 INFO extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin On Screen Display21
2024-06-25 10:28:34.777 INFO extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin On Screen Display21
2024-06-25 10:28:34.777 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@32: create_element: nvvideorenderersinkbin NVidia Video Renderer27
2024-06-25 10:28:34.777 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@54: bin_add: nvvideorenderersinkbin NVidia Video Renderer27
2024-06-25 10:28:34.777 INFO extensions/nvdssource/nvcamerasrcbin.hpp@31: create_element: nvcamerasrcbin Camera Source Input34
2024-06-25 10:28:34.778 INFO extensions/nvdssource/nvcamerasrcbin.hpp@49: bin_add: nvcamerasrcbin Camera Source Input34
Running...
****** NvDsScheduler Runtime Keyboard controls:
p: Pause pipeline
r: Resume pipeline
q: Quit pipeline
2024-06-25 10:28:34.880 INFO extensions/nvdsbase/nvds_scheduler.cpp@400: NvDsScheduler Pipeline ready
2024-06-25 10:28:34.881 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvCameraSrcBin:Camera Source Input/Camera Source Input34/GstV4l2Src:src_elem: Internal data stream error.
2024-06-25 10:28:34.881 INFO extensions/nvdsbase/nvds_scheduler.cpp@385: NvDsScheduler Pipeline running
2024-06-25 10:28:34.881 ERROR extensions/nvdsbase/nvds_scheduler.cpp@316: Debug info:
../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvCameraSrcBin:Camera Source Input/Camera Source Input34/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
nvstreammux: Successfully handled EOS for source_id=0
Returned, stopping playback
Deleting pipeline
2024-06-25 10:28:34.891 INFO gxf/gxe/gxe.cpp@301: Deinitializing...
2024-06-25 10:28:34.891 INFO gxf/gxe/gxe.cpp@309: Destroying context
2024-06-25 10:28:34.892 INFO gxf/gxe/gxe.cpp@315: Context destroyed.
End test_csi.yaml
[INFO] Graph installation directory /tmp/ds.test_csi and manifest /tmp/ds.test_csi/manifest.yaml retained
Can you answer the question?
Sorry. I am still learning things. I switched from V4L2 to the nvargus setting and it appears to work.
system
Closed
July 11, 2024, 1:21am
9
