[Exception] Exiting.. at the designated frame position
• Hardware Platform (Jetson / GPU) NVIDIA Jetson Nano (Developer Kit Version)
• DeepStream Version deepstream-5.0
• JetPack Version (valid for Jetson only) Jetpack 4.4 DP [L4T 32.4.2]
• TensorRT Version 7.1.0.16
I was trying to implement deepstream python samples. I need to implement for multistreaming + detection + tracking + message broker.
So, I have combined python examples: test2, test4 and imagedata-multistream into single script.
Its working well but giving me below error after 200 frames.
!![Exception] Exiting… at the designated frame position: 200
python3: …/…/src/hb-object-private.hh:154: Type* hb_object_reference(Type*) [with Type = hb_unicode_funcs_t]: Assertion `hb_object_is_valid (obj)’ failed.
Aborted (core dumped)
Here is my code: (showing only those function/code which I have edited. Function which are not shown below are used with same code like in samples)
PGIE_CONFIG_FILE="config_infer_primary_yoloV3.txt"
MSCONV_CONFIG_FILE="dstest4_msgconv_config.txt"
def meta_copy_func(data,user_data):
    user_meta=pyds.NvDsUserMeta.cast(data)
    src_meta_data=user_meta.user_meta_data
    # Cast src_meta_data to pyds.NvDsEventMsgMeta
    srcmeta=pyds.NvDsEventMsgMeta.cast(src_meta_data)
    dstmeta_ptr=pyds.memdup(pyds.get_ptr(srcmeta), sys.getsizeof(pyds.NvDsEventMsgMeta))
    # Cast the duplicated memory to pyds.NvDsEventMsgMeta
    dstmeta=pyds.NvDsEventMsgMeta.cast(dstmeta_ptr)
    dstmeta.ts=pyds.memdup(srcmeta.ts, MAX_TIME_STAMP_LEN+1)
    if(srcmeta.objSignature.size>0):
        dstmeta.objSignature.signature=pyds.memdup(srcmeta.objSignature.signature,srcMeta.objSignature.size)
        dstmeta.objSignature.size = srcmeta.objSignature.size;
    return dstmeta
# Callback function for freeing an NvDsEventMsgMeta instance
def meta_free_func(data,user_data):
    srcmeta=pyds.NvDsEventMsgMeta.cast(user_meta.user_meta_data)
    pyds.free_buffer(srcmeta.ts)
    if(srcmeta.objSignature.size > 0):
        pyds.free_buffer(srcmeta.objSignature.signature);
        srcmeta.objSignature.size = 0
def osd_sink_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    #Intiallizing object counter with 0.
    is_first_object=True
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    if not batch_meta:
        return Gst.PadProbeReturn.OK
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
        except StopIteration:
            continue
        is_first_object = True;
        frame_number=frame_meta.frame_num
        source_id = frame_meta.source_id
        l_obj=frame_meta.obj_meta_list
        while l_obj is not None:
            try:
                obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
                continue
            if obj_meta.class_id not in [0, 24, 26, 28]:  # doing for specific classes
                try:
                    l_obj=l_obj.next
                    break
                continue
            if(not (frame_number%30)):
                print(frame_number)
                msg_meta=pyds.alloc_nvds_event_msg_meta()
                msg_meta.bbox.top =  obj_meta.rect_params.top
                msg_meta.bbox.left =  obj_meta.rect_params.left
                msg_meta.bbox.width = obj_meta.rect_params.width
                msg_meta.bbox.height = obj_meta.rect_params.height
                msg_meta.frameId = frame_number
                msg_meta.trackingId = long_to_int(obj_meta.object_id)
                msg_meta.confidence = obj_meta.confidence
                msg_meta.componentId = source_id
                msg_meta.objClassId = obj_meta.class_id
                msg_meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON
                msg_meta.ts = pyds.alloc_buffer(MAX_TIME_STAMP_LEN + 1)
                pyds.generate_ts_rfc3339(msg_meta.ts, MAX_TIME_STAMP_LEN)
                user_event_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta)
                if(user_event_meta):
                    user_event_meta.user_meta_data = msg_meta;
                    user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
                    pyds.set_user_copyfunc(user_event_meta, meta_copy_func)
                    pyds.set_user_releasefunc(user_event_meta, meta_free_func)
                    pyds.nvds_add_user_meta_to_frame(frame_meta, user_event_meta)
                else:
                    print("Error in attaching event meta to buffer\n")
                is_first_object = False
            try:
                l_obj=l_obj.next
                break
        try:
            l_frame=l_frame.next
            break
        fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
def main(args):
    number_sources = len(uri_files)
    for i in range(number_sources):
        fps_streams["stream{0}".format(i)]=GETFPS(i)
    GObject.threads_init()
    Gst.init(None)
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    ###########  adding multistream to streamux ###########
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
        uri_name=uri_files[i]
        if uri_name.find("rtsp://") == 0 :
            is_live = True
        source_bin=create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname="sink_%u" %i
        sinkpad= streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad=source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    tracker = Gst.ElementFactory.make("nvtracker", "tracker")
    if not tracker:
        sys.stderr.write(" Unable to create tracker \n")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    msgconv=Gst.ElementFactory.make("nvmsgconv", "nvmsg-converter")
    if not msgconv:
        sys.stderr.write(" Unable to create msgconv \n")
    msgbroker=Gst.ElementFactory.make("nvmsgbroker", "nvmsg-broker")
    if not msgbroker:
        sys.stderr.write(" Unable to create msgbroker \n")
    streammux.set_property('width', 1280)  # 1280
    streammux.set_property('height', 720) # 720
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', PGIE_CONFIG_FILE)
#     pgie.set_property("batch-size",number_sources)
    msgconv.set_property('config',MSCONV_CONFIG_FILE)
    msgconv.set_property('payload-type', schema_type)
    msgbroker.set_property('proto-lib', proto_lib)
    msgbroker.set_property('conn-str', conn_str)
    msgbroker.set_property('sync', False)
    #Set properties of tracker
    config1 = configparser.ConfigParser()
    config1.read('dstest2_tracker_config.txt')
    config1.sections()
    for key in config1['tracker']:
        if key == 'tracker-width' :
            tracker_width = config1.getint('tracker', key)
            tracker.set_property('tracker-width', tracker_width)
        if key == 'tracker-height' :
            tracker_height = config1.getint('tracker', key)
            tracker.set_property('tracker-height', tracker_height)
        if key == 'gpu-id' :
            tracker_gpu_id = config1.getint('tracker', key)
            tracker.set_property('gpu_id', tracker_gpu_id)
        if key == 'll-lib-file' :
            tracker_ll_lib_file = config1.get('tracker', key)
            tracker.set_property('ll-lib-file', tracker_ll_lib_file)
        if key == 'll-config-file' :
            tracker_ll_config_file = config1.get('tracker', key)
            tracker.set_property('ll-config-file', tracker_ll_config_file)
        if key == 'enable-batch-process' :
            tracker_enable_batch_process = config1.getint('tracker', key)
            tracker.set_property('enable_batch_process', tracker_enable_batch_process)
    if not is_aarch64():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv.set_property("nvbuf-memory-type", mem_type)
        nvvidconv2n.set_property("nvbuf-memory-type", mem_type)
    ##################### adding rest of the elements to pipeline ##############
    pipeline.add(pgie)
    pipeline.add(tracker)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(msgconv)
    pipeline.add(msgbroker)
    print("Linking elements in the Pipeline \n")
    streammux.link(pgie)
    pgie.link(tracker)
    tracker.link(nvvidconv)
    nvvidconv.link(nvosd)
    nvosd.link(msgconv)
    msgconv.link(msgbroker)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GObject.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect ("message", bus_call, loop)
    osdsinkpad = nvosd.get_static_pad("sink")
    if not osdsinkpad:
        sys.stderr.write(" Unable to get sink pad of nvosd \n")
    osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except Exception as e:
        print("loop exception", str(e))
        pass
    # cleanup
    pyds.unset_callback_funcs()
    print("unset callback funcs completed ")
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = OptionParser()
    parser.add_option("-p", "--proto-lib", dest="proto_lib",
                  help="Absolute path of adaptor library", metavar="PATH")
    parser.add_option("", "--conn-str", dest="conn_str",
                  help="Connection string of backend server. Optional if it is part of config file.", metavar="STR")
    (options, args) = parser.parse_args()
    global proto_lib
    global conn_str
    global schema_type
    global uri_files
    proto_lib = options.proto_lib
    conn_str = options.conn_str
    uri_files = ["file:///home/mohit/deepstream_python_apps/apps/deepstream-imagedata-multistream/video1.mp4",
                 "file:///home/mohit/deepstream_python_apps/apps/deepstream-imagedata-multistream/video2.mp4"]
    if proto_lib is None or conn_str is None:
        print("Usage: python3 detect_and_track.py -p <Proto adaptor library> --conn-str=<ip;port;topic>")
        return 1
    schema_type = 0
    return 0
Hi Mohit, were you able to get a fix or this as I’m getting same issue on my end too.
-Sanjeev
Not yet Sanjeev
@2024a Team, any help/suggestion on this?
The error is reported by gltext library which met the invalid text input. We need more time to identify the reason.
The issue is resolved now. Actually NvDCF, default tracker config file is having a entry for endFrameNum, which was causing this issue.
endFrameNum: 200
After commenting out, it worked well.
