Exception handling
I try to compile a part of the Bayesian optical flow code (from the Cuda Zone). Unfortunately, I have some troubles:
BayesianOpticalFlowKernels.cu
>"C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE\xlocinfo", line 77: error:
>          support for exception handling is disabled
>              throw runtime_error("bad locale name");
Its author says his code works under Linux, so I’m quite :omg:
Thx
Definitely works under Linux; just tried it. Add --host-compilation ‘C++’ to your compiler command if you haven’t done so already.
test02_spatialDerivs, from the bayesian optical flow works with this compilation option. :thumbup: (and more important, I understand why)
I am trying for the complete code now…
Thx
Finally, I confirm that it is quite strange that the code works fine without any return value in the overloading of the = operator (LinearMemory.hpp, line 109) :angel:
After fixing this issue, it seems good.:thumbsup:
EDIT: a new released has fixed it since my first download :blush:
H.
