I’m trying to run a simple detection/segmentation on an AGX Xavier + an Intel Realsense camera. The code is similar to the one found in the tutorials (). Everything goes well until attempting to import cv2, at which point I get the following error:
segNet – loaded 21 class colors
jetson.utils – PyDisplay_New()
jetson.utils – PyDisplay_Init()
[OpenGL] glDisplay – X screen 0 resolution: 1920x1080
[OpenGL] failed to create X11 Window.
jetson.utils – PyDisplay_Dealloc()
File “/home/xavier/<…>”, line 79, in
display = jetson.utils.glDisplay()
Exception: jetson.utils – failed to create glDisplay device
Note: The Xavier is connected to a display on the HDMI port, as I’ve found similar posts with the same issue that were running it headless.
SW:
JetPack 4.4
Removed OpeCV 4 and built 3.4.3, as I thought that might the issue
code:
import cv2
import pyrealsense2 as rs
import numpy as np
import jetson.inference
import jetson.utils
import argparse
import ctypes
import sys[…parse the command line…]
try:
opt = parser.parse_known_args()[0]
except:
print(“”)
parser.print_help()
sys.exit(0)net = jetson.inference.segNet(opt.network, sys.argv)
net.SetOverlayAlpha(opt.alpha)
img_overlay = jetson.utils.cudaAllocMapped(opt.width * opt.height * 4 * ctypes.sizeof(ctypes.c_float))
pipeline = rs.pipeline()
config = rs.config()config.enable_stream(rs.stream.depth, opt.width, opt.height, rs.format.z16, 30)
config.enable_stream(rs.stream.color, opt.width, opt.height, rs.format.rgba8, 30)
pipeline.start(config)display = jetson.utils.glDisplay()
while display.IsOpen():
frames = pipeline.wait_for_frames()
color_frame = frames.get_color_frame()
if not color_frame:
continue
color_image = np.asanyarray(color_frame.get_data())
cuda_frame = jetson.utils.cudaFromNumpy(color_image)
net.Process(cuda_frame, opt.width, opt.height, opt.ignore_class)
net.Overlay(img_overlay, opt.width, opt.height, opt.filter_mode)
display.BeginRender()
display.Render(img_overlay, opt.width, opt.height)
display.EndRender()
display.SetTitle(“{:s} | Network {:.0f} FPS | Display {:.1f} FPS”.format(opt.network, net.GetNetworkFPS(),
display.GetFPS()))
