Excuse me, can TX1`s HDMI interface connect AV port directly?
Hi WordZzzz,
We need to inform you that any other interface which requires a converter is not under our test coverage.
But you can still buy one converter and give it a try.
Suggestion: If you provide EDID on the DDC wire you could trick the system into believing any older non-HDMI-compliant type interface is actually HDMI.
Hi, WayneWWW,
I want to know how can I change the output format of HDMI.I have a converter but it doesn’t work. The technician suggested me to change the output format of HDMI. What should I do?
Hi WordZzzz,
What format are you asking? Current output (if you are on L4T) should be 24bpps RGB output.
If you want to ask further question about this, maybe file a new topic is better for visibility.
