ExecuteV2 freezes after running a few inferences
Description
The application i’m working on is supposed to run inferences in a sequential manner but after a while (under a minute) the execution freezes and the last instruction executed was calling executeV2.
Environment
TensorRT Version: 8
GPU Type: v100
Nvidia Driver Version: 460.91
CUDA Version: 11.2
CUDNN Version:
Operating System + Version: Ubuntu 20.04
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Just running inferences for a couple of seconds will freeze the execution completely.
Skeleton TrtEngine::runInference(const std::string &base64, Skeleton old)
    const std::regex regex("^data:image\/[a-z]+;base64,"); // matches with base64-encoded binary image data
    if (std::regex_search(base64, regex, std::regex_constants::match_continuous))
        const auto rawImageData = base64_decode(std::regex_replace(base64, regex, ""));
        auto imageData = cv::imdecode(cv::Mat(1, rawImageData.length(), CV_8UC1, const_cast<char *>(rawImageData.c_str())),1);
        // get sizes of input and output and allocate memory required for input data and for output data
        std::vector<nvinfer1::Dims> input_dims; // we expect only one input
        std::vector<nvinfer1::Dims> output_dims; // and one output
        void* buffers[engine->getNbBindings()]; // buffers for input and output data
        for (int i = 0; i < engine->getNbBindings(); ++i)
            auto binding_size = getSizeByDim(engine->getBindingDimensions(i)) * sizeof(float);
            cudaMalloc(&buffers[i], binding_size);
            if (engine->bindingIsInput(i))
                input_dims.emplace_back(engine->getBindingDimensions(i));
            else
                output_dims.emplace_back(engine->getBindingDimensions(i));
        preprocessImage(imageData, (float*)buffers[0], input_dims[0]);
        // Here the execution stops
        context->executeV2(buffers);
        auto sk = postprocessResults(buffers[2], buffers[1], output_dims[1], output_dims[0], old);
        for (void* buf : buffers)
            cudaFree(buf);
        return sk;
    return Skeleton();
void TrtEngine::preprocessImage(cv::Mat &image, float *gpu_input, const nvinfer1::Dims &dims)
    cv::cuda::GpuMat gpu_frame;
    // upload image to GPU
    gpu_frame.upload(image);
    auto input_width = dims.d[3];
    auto input_height = dims.d[2];
    auto channels = dims.d[1];
    auto input_size = cv::Size(input_width, input_height);
    // normalize
    cv::cuda::GpuMat flt_image;
    gpu_frame.convertTo(flt_image, CV_32FC3, 1.f / 255.f);
    cv::cuda::subtract(flt_image, cv::Scalar(0.485f, 0.456f, 0.406f), flt_image, cv::noArray(), -1);
    cv::cuda::divide(flt_image, cv::Scalar(0.229f, 0.224f, 0.225f), flt_image, 1, -1);
    // to tensor
    std::vector<cv::cuda::GpuMat> chw;
    for (int i = 0; i < channels; ++i)
        chw.emplace_back(cv::cuda::GpuMat(input_size, CV_32FC1, gpu_input + i * input_width * input_height));
    cv::cuda::split(flt_image, chw);
Can you try running your model with trtexec command, and share the “”–verbose"" log in case if the issue persist
https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
You can refer below link for all the supported operators list, in case any operator is not supported you need to create a custom plugin to support that operation
Also, request you to share your model and script if not shared already so that we can help you better.
Meanwhile, for some common errors and queries please refer to below link:
https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/#error-messaging
https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/#faq
