Hi all, I tried executing the script convert_to_onnx.py from the directory /usr/src/tensorrt/samples/python/onnx_packnet/
python3.6 convert_to_onnx.py --output model.onnx
But it resulted in displaying the message Killed and it could not succeed
Below is the log output
/home/mistral/.local/lib/python3.6/site-packages/torch/nn/functional.py:2471: UserWarning: floordiv is deprecated, and its behavior will change in a future version of pytorch. It currently rounds toward 0 (like the ‘trunc’ function NOT ‘floor’). This results in incorrect rounding for negative values. To keep the current behavior, use torch.div(a, b, rounding_mode=‘trunc’), or for actual floor division, use torch.div(a, b, rounding_mode=‘floor’).
_verify_batch_size([input.size(0) * input.size(1) // num_groups, num_groups] + list(input.size()[2:]))
/usr/src/tensorrt/samples/python/onnx_packnet/packnet-sfm-0.1.2/packnet_sfm/networks/layers/packnet/layers01.py:146: UserWarning: floordiv is deprecated, and its behavior will change in a future version of pytorch. It currently rounds toward 0 (like the ‘trunc’ function NOT ‘floor’). This results in incorrect rounding for negative values. To keep the current behavior, use torch.div(a, b, rounding_mode=‘trunc’), or for actual floor division, use torch.div(a, b, rounding_mode=‘floor’).
out_h, out_w = h // r, w // r
Killed
Let me know what could be the reason behind it and the solution for it.
Thanks and Regards
Nagaraj Trivedi
