Execution of driveworks sample without using cuda and tensorrt
Software Version
DRIVE OS 6.0.10.0
[1] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1] Linux
QNX
other
Hardware Platform
[1] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1] other
Host Machine Version
other
Issue Description
Hi team, there is object detector tracker sample. In the sample, cuda and tensorrt has been used. But what if I want to execute the code without using cuda and tensorRT? Are there any ways to do so? I want my application to run on CPU only
Dear @akshay.tupkar,
Are you asking like if there is any switch or parameter in code that makes the sample to run inference on CPU? If so, it is not possible. The inference would always run on GPU/DLA using the DW DNN framework.
If you want to add custom code in the sample, you can get the input data on CPU like below and feed into your network on CPU implementation
CHECK_DW_ERROR(dwDataConditioner_prepareDataRaw(m_dnnInputDevice, &rgbaImage, 1, &m_detectionRegion,
                                                          cudaAddressModeClamp, m_dataConditioner));
          // Copy input back to CPU after preprocessing
CHECK_CUDA_ERROR(cudaMemcpy(m_dnnInputputHost, m_dnnInputDevice,
                                    sizeof(float32_t) * m_totalSizeInput, cudaMemcpyDeviceToHost));
//Add CPU inference code
