ExFAT support is also missing in version 36.3: why did you omit support for one of the most used filesystems?
r36.3 is aligned with upstream kernel and we don’t enable addition kernel configs. Please share which configs have to be enabled for ExFAT support. We will check with our teams.
The config setting needed for this kernel module is CONFIG_FUSE_FS
Without it, users can’t hook up large USB drives without recompiling the kernel.
