I’m a absolute newbie to OpenGL. I’ve found a CUDA mandelbrot set example where OpenGL is used to show it on the display.
I now wanted to program the same application but without use of CUDA. The sense is that I want to switch between CPU and GPU while executing.
But I don’t know how to transform the existing CUDA OpenGL instruction in that way, that I can use it for my CPU calculation.
The buffer and texture are initialised as following:
GLint bsize;
glGenBuffers(1, &buffer);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER, buffer);
glBufferData(GL_PIXEL_UNPACK_BUFFER,Bpp * sizeof(unsigned char) * width * height, NULL, GL_STREAM_DRAW);
glGetBufferParameteriv(GL_PIXEL_UNPACK_BUFFER, GL_BUFFER_SIZE, &bsize);
if ((GLuint)bsize != (Bpp * sizeof(unsigned char) * width * height))
printf("Buffer object (%d) has incorrect size (%d).\n",(unsigned)buffer, (unsigned)bsize);
cudaThreadExit();
exit(-1);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER, 0);
cudaGLRegisterBufferObject(buffer);
glGenTextures(1, &texid);
glBindTexture(GL_TEXTURE_2D, texid);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB, width, height, 0, GL_RGB, GL_UNSIGNED_BYTE, NULL);
glBindTexture(GL_TEXTURE_2D, 0);
glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
glPixelStorei(GL_PACK_ALIGNMENT, 1);
Now Cuda uses it in the following way:
cudaGLMapBufferObject((void**)&data, buffer);
// Calling of the CUDA Hostfunction
calculateHost( data, centerX, centerY, zoom, width, height );
cudaGLUnmapBufferObject(buffer);
data is an pointer to unsigned char
I want to give my CPUfunction the same Parameters as the CUDA hostfunktion (unsigned char* data, centerX, centerY, zoom, width, height )
But I don’t know how the code it. :( As far as I can say it the variable data is the problem because it needs to be a pointer to unsigned char.
