Expansion I/O Speed on Jetson
I would like to use the Jetson for very broad (60 MHz bandwidth) and fast FFTs. I want to use the Expansion I/O for interfacing the board and I’m not sure if all the Expansion I/O pins are created equal, so if there are pins I should avoid using them.
I would need to send 16 bits in parallel plus a clock. Ideally this would be with the clock at 122.88MHz but half that would be fine also. If the clock could generate an interrupt that would be ideal.
My question: are the Expansion I/O pins capable of that?
Thanks in advance!
You might be interested in this thread:
[url]https://devtalk.nvidia.com/default/topic/792315/embedded-systems/highest-speed-data-interface-to-nvidia-jetson-tk1-/[/url]
