There is a good example and description of fields for detection networks in the TLT pdf. However the classification example could use some more details.
Is there an exhaustive spec for these files for both classification and detection networks?
It is odd that the classification spec uses different identifiers than the detection spec (e.g. lr_config in the classification example vs learning_rate in the detection example.
