Expert Parallelism on Blackwell: RTX PRO 6000 PCIe Gen5 vs. B200 NVLink
Hello everyone,
I recently compared Qwen/Qwen3.5-35B-A3B, a MoE model, on two different Blackwell platforms:
- 2× NVIDIA RTX PRO 6000 Blackwell (PCIe Gen5)
- 2× NVIDIA B200 with NVLink
The goal was to evaluate the impact of Expert Parallelism (EP) on inference performance and compare it with the standard tensor-parallel (TP) configuration.
MoE model without EP with TP
vllm serve Qwen/Qwen3.5-35B-A3B \
--tensor-parallel-size 2 \
--gpu-memory-utilization 0.9 \
--max-model-len 32768
vllm bench serve \
--model Qwen/Qwen3.5-35B-A3B \
--dataset-name random \
--random-input-len 1000 \
--random-output-len 1000 \
--request-rate 10000 \
--num-prompts 16 \
--ignore-eos
Output:
2xBlackwell 6000 Pro with PCIe Gen5
============ Serving Benchmark Result ============
Successful requests: 16
Failed requests: 0
Request rate configured (RPS): 10000.00
Benchmark duration (s): 30.98
Total input tokens: 16000
Total generated tokens: 16000
Request throughput (req/s): 0.52
Output token throughput (tok/s): 516.44
Peak output token throughput (tok/s): 1344.00
Peak concurrent requests: 16.00
Total token throughput (tok/s): 1032.87
---------------Time to First Token----------------
Mean TTFT (ms): 18354.95
Median TTFT (ms): 18326.58
P99 TTFT (ms): 18486.20
-----Time per Output Token (excl. 1st token)------
Mean TPOT (ms): 12.63
Median TPOT (ms): 12.66
P99 TPOT (ms): 12.89
---------------Inter-token Latency----------------
Mean ITL (ms): 12.63
Median ITL (ms): 12.59
P99 ITL (ms): 13.48
2xB200 with NVlink
Failed requests: 0
Benchmark duration (s): 8.49
Request throughput (req/s): 1.89
Output token throughput (tok/s): 1885.26
Peak output token throughput (tok/s): 2544.00
Total token throughput (tok/s): 3770.52
Mean TTFT (ms): 1965.40
Median TTFT (ms): 1935.22
P99 TTFT (ms): 2069.94
Mean TPOT (ms): 6.52
Median TPOT (ms): 6.55
P99 TPOT (ms): 6.89
Mean ITL (ms): 6.53
Median ITL (ms): 6.33
P99 ITL (ms): 7.92
MoE model with EP + TP=2
A command:
--enable-expert-parallel \
Blackwell 6000 Pro
Failed requests: 0
Benchmark duration (s): 13.49
Request throughput (req/s): 1.19
Output token throughput (tok/s): 1186.12
Peak output token throughput (tok/s): 1328.00
Total token throughput (tok/s): 2372.23
Mean TTFT (ms): 672.99
Median TTFT (ms): 645.70
P99 TTFT (ms): 801.48
Mean TPOT (ms): 12.82
Median TPOT (ms): 12.85
P99 TPOT (ms): 13.08
Mean ITL (ms): 12.82
Median ITL (ms): 12.75
P99 ITL (ms): 13.52
2xB200 with NVlink
Failed requests: 0
Benchmark duration (s): 8.14
Request throughput (req/s): 1.97
Output token throughput (tok/s): 1965.18
Peak output token throughput (tok/s): 2960.00
Total token throughput (tok/s): 3930.36
Mean TTFT (ms): 2510.53
Median TTFT (ms): 2462.16
P99 TTFT (ms): 2661.18
Mean TPOT (ms): 5.63
Median TPOT (ms): 5.68
P99 TPOT (ms): 6.16
Mean ITL (ms): 5.63
Median ITL (ms): 5.47
P99 ITL (ms): 5.77
Expert Parallelism is particularly beneficial on PCIe-connected GPUs, more than doubling throughput and dramatically reducing TTFT for this MoE model. NVLink remains the fastest interconnect for multi-GPU MoE inference
