I have a question, in normal with having a few streams (e.g less than 3) and running with only detector engine. The output frames of decoder are smooths.
But why when increased number of streams or add more detector engine to pipeline (I have 3 detectors engine continue and some classifier engine), then the output frames of decoders sometimes corrupted, specially happened on the objects are moving. And I said that with streams RTSP do not have problem in transmission.
Thank you very much!
• Hardware Platform (GPU) • DeepStream Version 4 • TensorRT Version 6.0 • NVIDIA GPU Driver Version 440.100
You would to like trying to add as much detector engine continue (which typical heavy like yolo or ssd) as I descriptive and trying to run with some (increase 5~10 stream) rtsp sources.
Just see you run with deepstream 4.0, please move to deepstream 5.0, we have many changes and fixes in this version, please try it and report if you still have the issue, if issue still there, we will see there.
