Hi, i want to do some tests on local memory,as the programming guide saied,
there are three situation that compiler will use local memory:
- Arrays for which it cannot determine that they are indexed with constant quantities,
- Large structures or arrays that would consume too much register space,
- Any variable if the kernel uses more registers than available (this is also known as register spilling ).
is there any instructions explicit define an array stores in Local Memory?
