Is it possible to export the names and description of all metrics in frame profiler?
just like “nv-nsight-cu-cli --query-metrics” in Nsight Compute
Thank you for using Nsight Graphics and your question about exporting names and descriptions of all metrics in frame profiler. Can you share more about what your end goal is? There is a help command for the ngfx command line. The command line syntax for that help command is: “ngfx --help-all”. You can find the ngfx executable in the following install directory of Nsight Graphics: C:\Program Files\NVIDIA Corporation\Nsight Graphics 2022.6.1\host\windows-desktop-nomad-x64.
If you are a current user of Frame Profiler you should actually switched to using GPU Trace Profiler instead because we have deprecated Frame Profiler. See the following section of the User Guide for more details on the Nsight Graphics GPU Trace Profiler and the various metrics and descriptions, Advanced Learning :: Nsight Graphics Documentation. Please let me know if this is what you’re looking for.
Regards,
