So I’ve found how how to export the model for the dofbot using this code:
https://github.com/Denys88/rl_games/blob/master/notebooks/train_and_export_onnx_example_continuous.ipynb
so I included in the training script from the Dofbot repo to train the model in rl_games train:
def run(self):
class ModelWrapper(torch.nn.Module):
Main idea is to ignore outputs which we don't need from model
def __init__(self, model):
torch.nn.Module.__init__(self)
self._model = model
def forward(self, input_dict):
input_dict['obs'] = self._model.norm_obs(input_dict['obs'])
just model export doesn't work. Looks like onnx issue with torch distributions
thats why we are exporting only neural network
# print(input_dict)
# output_dict = self._model.a2c_network(input_dict)
# input_dict['is_train'] = False
# return output_dict['logits'], output_dict['values']
return self._model.a2c_network(input_dict)
# create runner and set the settings
runner = Runner(RLGPUAlgoObserver())
runner.load(self.rlg_config_dict)
runner.reset()
# dump config dict
experiment_dir = os.path.join('runs', self.cfg.train.params.config.name)
os.makedirs(experiment_dir, exist_ok=True)
with open(os.path.join(experiment_dir, 'config.yaml'), 'w') as f:
f.write(OmegaConf.to_yaml(self.cfg))
agent = runner.create_player()
agent.restore('/home/dylan/Desktop/repos/OmniIsaacGymEnvs-DofbotReacher/runs/DofbotReacher/nn/DofbotReacher.pth')
inputs = {
'obs': torch.zeros((1,) + agent.obs_shape).to(agent.device),
'rnn_states': agent.states,
with torch.no_grad():
adapter = flatten.TracingAdapter(ModelWrapper(agent.model), inputs, allow_non_tensor=True)
traced = torch.jit.trace(adapter, adapter.flattened_inputs, check_trace=False)
flattened_outputs = traced(*adapter.flattened_inputs)
print(flattened_outputs)
torch.onnx.export(traced, *adapter.flattened_inputs, "dofbotreacherDefault.onnx", verbose=True, input_names=['obs'],
output_names=['mu', 'log_std', 'value'])
runner.run({
'train': not self.cfg.test,
'play': self.cfg.test,
'checkpoint': self.cfg.checkpoint,
'sigma': None
But when I run this in a notebook to compare with the output of the model in Isaac Sim I am getting different results:
while True:
input_data = np.concatenate((jointPos, jointVel, goalPos, goalRot, goalRotRel, prevAct), dtype=np.float32)
input_dict = {input_name: input_data.reshape(1, -1)}
actions = []
output = sess.run(None, input_dict)
# Run the model on the input data
mus = output[0][0]
sigmas = output[1][0]
for mu, sigma in zip(mus, sigmas):
#print("mu is " + str(mu))
#print("sigma is " + str(sigma))
sigma = np.exp(sigma)
action = np.random.normal(mu, sigma)
action = clip_actions(action)
#print(str(action))
actions.append(action)
# Print the output
prevAct = np.array(actions, dtype=np.float32)
joinPos = prevAct
mus = clip_actions(mus)
print("From Mu: " + str(mus))
print("Sampled Actions: " + str(actions)+"\n")
My results from exported ONNX:
From Mu: [-1. -1. -1. -0.8046344 1. 0.03140484]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9712634764535495, 1.0, 0.13085964262265282]
From Mu: [-1. -1. -1. -0.7526153 0.3962637 -0.4832963]
Sampled Actions: [-1.0, -1.0, -1.0, -0.673332441238304, 0.4277837343190856, -0.8004600149667951]
From Mu: [-1. -1. -1. -0.7781227 1. 0.01266351]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9150055130283129, 1.0, 0.5220340378975656]
From Mu: [-1. -1. -1. -0.75321215 0.4043142 -0.48851803]
Sampled Actions: [-1.0, -1.0, -1.0, -0.740595988656948, 0.6001872415307878, -0.43890275166219206]
From Mu: [-1. -1. -1. -0.79603606 1. 0.02533225]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7589437855821842, 0.9001211409978054, 0.45835817870457995]
From Mu: [-1. -1. -1. -0.7440234 0.44310746 -0.50922453]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7435969780643082, 0.12811670977753048, -0.7244098554326204]
From Mu: [-1. -1. -1. -0.7519526 1. 0.01125173]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7532973499744635, 1.0, -0.40081315228268555]
From Mu: [-1. -1. -1. -0.83088285 0.99210644 0.0389543 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8324133591496548, 0.706666445481611, 0.19869922991846953]
From Mu: [-1. -1. -1. -0.7238199 0.46477643 -0.5139754 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.5591049802680348, 0.4525925046550397, -0.8477365401897607]
From Mu: [-1.0000000e+00 -1.0000000e+00 -1.0000000e+00 -7.7655083e-01
1.0000000e+00 8.5781515e-04]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9417623079946027, 1.0, 0.19555459127998726]
From Mu: [-1. -1. -1. -0.752935 0.40048864 -0.4860393 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7758784773062144, 0.2824237395466518, -0.6451741533484725]
From Mu: [-1. -1. -1. -0.7677086 1. 0.0195474]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7224911522708941, 1.0, 0.013253213240240352]
From Mu: [-1. -1. -1. -0.76368755 0.4935695 -0.4761499 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.711067045811111, 0.45817385742559213, -0.33301126978630297]
From Mu: [-1. -1. -1. -0.78214306 1. 0.01774313]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8200303164566594, 1.0, 0.06691762403021183]
From Mu: [-1. -1. -1. -0.7540979 0.41784108 -0.49724796]
Sampled Actions: [-1.0, -1.0, -1.0, -0.971417280472688, 0.24631265870297667, -0.420806805659078]
From Mu: [-1. -1. -1. -0.7697392 1. 0.04017575]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8351657458525144, 1.0, -0.3143587497067801]
From Mu: [-1. -1. -1. -0.83230096 0.9839373 0.04801101]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6531447447963699, 1.0, -0.5401700070822363]
From Mu: [-1. -1. -1. -0.82877606 1. 0.02789856]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7325868211515937, 1.0, -0.2056215451291925]
From Mu: [-1. -1. -1. -0.8304811 0.99420536 0.03666638]
Sampled Actions: [-0.9596524949814464, -1.0, -1.0, -0.727783274374398, 1.0, -0.022099674545825593]
From Mu: [-1. -1. -1. -0.83203524 0.98964196 0.02937362]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9240667476074332, 1.0, 0.14339611663589916]
From Mu: [-1. -1. -1. -0.75311977 0.4030195 -0.4876795 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6717779185202091, -0.18275692793347031, -0.36308104834416527]
From Mu: [-1. -1. -1. -0.7185393 1. -0.00630318]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6100275823929414, 1.0, 0.016816065477693667]
From Mu: [-1. -1. -1. -0.7555036 0.4474652 -0.51618 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7180995217046809, 1.0, -0.13469952553495773]
From Mu: [-1. -1. -1. -0.8301895 0.99568105 0.03506646]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7588848485509612, 0.9381901139756421, 0.31158853516230894]
From Mu: [-1. -1. -1. -0.74803036 0.4368003 -0.50681484]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7154093862788289, 0.8633711819668368, -1.0]
From Mu: [-1. -1. -1. -0.81857425 1. 0.03061933]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9605380108456176, 1.0, 0.224580063371297]
From Mu: [-1. -1. -1. -0.75273305 0.39780074 -0.48429456]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7599399310258989, 0.683415490179879, 0.10554475773474592]
From Mu: [-1. -1. -1. -0.7216615 0.47854942 -0.5221823 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8500937557664596, 0.44775010561508727, -0.062483218958119646]
From Mu: [-1. -1. -1. -0.78516716 1. 0.0327966 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6297888878813683, 0.8676291846536264, -0.044572628309073714]
From Mu: [-1. -1. -1. -0.8168054 1. 0.02131866]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9869841126204636, 0.749818234488756, -0.0865036930558632]
From Mu: [-1. -1. -1. -0.81412536 1. 0.0572635 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8774458476527681, 0.9262720416298681, -0.3105193372811678]
From Mu: [-1. -1. -1. -0.8269616 0.99148035 0.05044907]
Sampled Actions: [-1.0, -1.0, -1.0, -0.956779717342482, 1.0, -0.09833272962712514]
From Mu: [-1. -1. -1. -0.8339178 0.97218335 0.06150183]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8847926518222826, 0.7811633147768765, 0.6468734889113454]
From Mu: [-1. -1. -1. -0.7310789 0.4452337 -0.50467825]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7219534542825735, 0.6578086633571447, -0.5079010698438633]
From Mu: [-1. -1. -1. -0.80070335 1. 0.02505435]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7067711793896203, 1.0, 0.04010780364819768]
From Mu: [-1. -1. -1. -0.75495094 0.43386662 -0.50752133]
Sampled Actions: [-1.0, -1.0, -1.0, -0.734413969039702, 0.5941167050192434, -0.5086914582627033]
From Mu: [-1. -1. -1. -0.79531425 1. 0.02446295]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8421573316399269, 1.0, 0.30989272641437204]
From Mu: [-1. -1. -1. -0.75390536 0.4146967 -0.49522403]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9163837434115838, 0.31018013332085653, -0.6052221552721155]
From Mu: [-1. -1. -1. -0.77425617 1. 0.03597975]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6653456375410538, 1.0, -0.06353721821121802]
From Mu: [-1. -1. -1. -0.8290542 1. 0.02924436]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6330052804822425, 0.29690473715661647, -0.2526023832207899]
From Mu: [-1. -1. -1. -0.7643934 1. 0.00425477]
Sampled Actions: [-1.0, -1.0, -1.0, -0.644647362984077, 1.0, -0.039213324141717576]
From Mu: [-1. -1. -1. -0.82857746 1. 0.02696133]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6490890462102662, 0.9928362688072035, -0.020496762619332073]
From Mu: [-1. -1. -1. -0.8280749 1. 0.02723466]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7456473961946039, 1.0, -0.19916520520425451]
From Mu: [-1. -1. -1. -0.83073646 0.99288005 0.03810912]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6872249670162497, 1.0, -0.1842744928744335]
From Mu: [-1. -1. -1. -0.82953936 0.99884725 0.03165848]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7027429862791732, 1.0, 0.1565127741614349]
From Mu: [-1. -1. -1. -0.75497705 0.43443447 -0.5078842 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9300769908160136, 0.5547780652801778, -0.15824015832012317]
From Mu: [-1. -1. -1. -0.7966184 1. 0.04495192]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9351516547556644, 1.0, 0.41995618692489717]
From Mu: [-1. -1. -1. -0.75300497 0.4014346 -0.48665246]
Sampled Actions: [-1.0, -1.0, -1.0, -0.799439295000151, 0.33643433600371603, -0.1238350057988532]
From Mu: [-1. -1. -1. -0.7734776 1. 0.02380122]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7137572110777022, 1.0, 0.03234684937291753]
From Mu: [-1. -1. -1. -0.75490457 0.4328815 -0.50689197]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6739407059979791, 0.3401257993163045, -0.5932283956507928]
From Mu: [-1. -1. -1. -0.76990277 1. 0.01006894]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9218036317157808, 1.0, 0.19921441468520712]
From Mu: [-1. -1. -1. -0.753143 0.4033429 -0.48788902]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8677409427333201, 0.10603287720424603, -1.0]
From Mu: [-1. -1. -1. -0.7537337 1. 0.02431748]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7987103700020154, 0.9748768000782158, -0.19254955620029196]
From Mu: [-1. -1. -1. -0.82964367 0.99151677 0.04321043]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7772603301650468, 1.0, 0.08330701284505027]
From Mu: [-1. -1. -1. -0.7544461 0.42390615 -0.5011452 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7215235033994709, 0.7475780753105198, -0.4463962371186046]
From Mu: [-1. -1. -1. -0.8086596 1. 0.02776166]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7416580639653408, 0.7908667095687227, -0.7007411216283626]
From Mu: [-1. -1. -1. -0.8129317 1. 0.03130444]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9641518084761704, 0.7152171875335328, -0.1790646387606805]
From Mu: [-1. -1. -1. -0.8109068 1. 0.0536619]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9449071105724618, 0.9214226188393199, 0.3830525353828998]
From Mu: [-1. -1. -1. -0.7448434 0.41333145 -0.49061635]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6139587415753119, 0.27964950178425085, -0.805540133657932]
From Mu: [-1. -1. -1. -0.7620633 1. 0.00163948]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7513908686503362, 1.0, 0.23165483971241815]
From Mu: [-1. -1. -1. -0.754641 0.42756668 -0.5034921 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9274740125963947, 0.5669085915310174, -0.6694073326868109]
From Mu: [-1. -1. -1. -0.79761654 1. 0.04503421]
Sampled Actions: [-1.0, -1.0, -1.0, -0.829177380456725, 0.9792390638350275, 0.7460004057255771]
From Mu: [-1. -1. -1. -0.7518366 0.4200245 -0.49774817]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7531855640293652, 0.3724516385546356, -0.81092287920861]
From Mu: [-1. -1. -1. -0.77546066 1. 0.01978657]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8006624931542228, 1.0, -0.2035726014573656]
From Mu: [-1. -1. -1. -0.831736 0.9873554 0.04419161]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8211956396909531, 1.0, 0.3126758327660015]
From Mu: [-1. -1. -1. -0.75408775 0.41767544 -0.497142 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6773146200950056, 0.23898131031657155, -0.00888535581840777]
From Mu: [-1. -1. -1. -0.7500414 1. -0.12462715]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7044294522807475, 1.0, -0.37893207805010704]
From Mu: [-1. -1. -1. -0.8299064 0.9970793 0.03355742]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8042123596741024, 1.0, 0.02978162273492279]
From Mu: [-1. -1. -1. -0.7542301 0.42008585 -0.49869195]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7994773223681491, 0.35195154559923064, -0.6513128507643774]
From Mu: [-1. -1. -1. -0.77492505 1. 0.02427842]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8146382622800785, 1.0, 0.4632515711692034]
From Mu: [-1. -1. -1. -0.7541432 0.41860655 -0.49774054]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6399486189712743, 0.47991460152377413, -0.6106060048915335]
From Mu: [-1. -1. -1. -0.7818957 1. 0.0105686]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7521512450297217, 1.0, -0.101485989421196]
From Mu: [-1. -1. -1. -0.8308614 0.9922222 0.03882762]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8318709297241236, 0.7954753471454886, 0.18972583585456484]
From Mu: [-1. -1. -1. -0.7328147 0.45023966 -0.50883967]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7645353328437561, 0.8173021942662632, -0.4628886097273362]
From Mu: [-1. -1. -1. -0.8157343 1. 0.03463554]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8481815342708638, 1.0, 0.03233081407351638]
From Mu: [-1. -1. -1. -0.7538517 0.4138401 -0.4946716]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8667782367159919, 0.5177156208302721, -0.3209698993271739]
From Mu: [-1. -1. -1. -0.7919213 1. 0.03677167]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7166605067083957, 0.7848380977631081, -0.903113004857943]
From Mu: [-1. -1. -1. -0.8118021 1. 0.0283642]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7483624175285033, 0.9690469629087698, 0.3157288374427686]
From Mu: [-1. -1. -1. -0.75136656 0.43315125 -0.50578666]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7228498155618657, 0.8739042277649753, -0.8068623520948508]
From Mu: [-1. -1. -1. -0.8196482 1. 0.0317601]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7101558499317228, 1.0, 0.11094376540214405]
From Mu: [-1. -1. -1. -0.7549284 0.43338925 -0.5072165 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7380984420750469, 0.19013209276868123, -0.4474742833012317]
From Mu: [-1. -1. -1. -0.7577391 1. 0.01255114]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7153524683163135, 1.0, 0.42582526401823645]
From Mu: [-1. -1. -1. -0.7548941 0.43265638 -0.5067481 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8254276575165649, 0.7881192382061699, -0.5197676868750642]
From Mu: [-1. -1. -1. -0.8145303 1. 0.04047535]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8888925976178152, 0.5152770032077211, -1.0]
From Mu: [-1. -1. -1. -0.7922334 1. 0.03915513]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7928917736744503, 1.0, 0.7313546877440096]
From Mu: [-1. -1. -1. -0.75432247 0.4216915 -0.4997233 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7441526863909724, 0.38976482033239357, -0.06913269820327372]
From Mu: [-1. -1. -1. -0.77680117 1. 0.0193164 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7109446039021524, 1.0, 0.0463337171791479]
From Mu: [-1. -1. -1. -0.7549233 0.43327805 -0.50714546]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9411369457112222, 0.6229244546911966, -0.002945034717867112]
From Mu: [-1. -1. -1. -0.7737288 0.87156916 -0.20136413]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8333429132267878, 0.7866244967082299, -0.40523307862356206]
From Mu: [-1. -1. -1. -0.8145625 1. 0.04130588]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8137097281918882, 0.8703228699255615, -0.11254037521151103]
From Mu: [-1. -1. -1. -0.8212401 1. 0.04168546]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8345495408115013, 0.964417183788387, -0.08616398051944929]
From Mu: [-1. -1. -1. -0.8293955 0.989624 0.04685815]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9619933018895461, 0.9294147044207864, 0.26190701677129324]
From Mu: [-1. -1. -1. -0.7454954 0.40955535 -0.4885219 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7298318947599646, 0.7249129003673476, -0.44874197696222995]
From Mu: [-1. -1. -1. -0.80687493 1. 0.0279835 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9172371300540336, 1.0, -0.11950898063572937]
From Mu: [-1. -1. -1. -0.83345515 0.97595435 0.05710997]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7520426333517087, 0.7108703606577311, -0.2643116840263049]
From Mu: [-1. -1. -1. -0.80619746 1. 0.03000315]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8700702838087512, 1.0, -0.5868225448990657]
From Mu: [-1. -1. -1. -0.83282405 0.9805167 0.0518783 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8459504345277016, 0.852532244547307, 0.21485077773330233]
From Mu: [-1. -1. -1. -0.73856825 0.43881717 -0.5040919 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6042425399210104, 0.38998532721734425, -0.6512789363508023]
From Mu: [-1. -1. -1. -0.7722377 1. 0.00392138]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8335485796836798, 1.0, 0.6453908524881675]
From Mu: [-1. -1. -1. -0.7539808 0.41592062 -0.4960123 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6598709852418955, 0.3168695489524249, -0.836174569712293]
From Mu: [-1. -1. -1. -0.76722413 1. 0.00781376]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8826941159915369, 0.9815507997243897, 0.09223066650737678]
From Mu: [-1. -1. -1. -0.7516089 0.41203526 -0.49267414]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7262354023240403, 0.611571876077073, -0.3748896004425093]
From Mu: [-1. -1. -1. -0.7966631 1. 0.02409985]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8437298752685033, 1.0, -0.21390895491626874]
From Mu: [-1. -1. -1. -0.83243376 0.9830944 0.04895948]
Sampled Actions: [-1.0, -1.0, -1.0, -1.0, 0.5754243191292447, 0.23529930719799402]
From Mu: [-1. -1. -1. -0.71029884 0.463244 -0.50490886]
Sampled Actions: [-1.0, -1.0, -1.0, -0.73022477601822, 0.022821628964901475, -0.5316323107425646]
From Mu: [-1. -1. -1. -0.7412426 1. 0.00652762]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7626166359492124, 1.0, -0.06862099196679089]
From Mu: [-1. -1. -1. -0.83105797 0.99116623 0.03998423]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9733124724446618, 0.37299390582550784, 0.44632602453678194]
From Mu: [-1. -1. -1. -0.691082 0.49967584 -0.51800704]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6466158853593572, 0.10894997588414462, -1.0]
From Mu: [-1.0000000e+00 -1.0000000e+00 -1.0000000e+00 -7.4669188e-01
1.0000000e+00 -2.7045608e-06]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8063693254883623, 1.0, 0.5692572123634391]
From Mu: [-1. -1. -1. -0.7542121 0.41978022 -0.49849543]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7238280431509154, 0.38645082434177647, -0.9589964281916483]
From Mu: [-1. -1. -1. -0.77586526 1. 0.01697315]
Sampled Actions: [-1.0, -1.0, -1.0, -0.831368703825368, 1.0, -0.5139026712857898]
From Mu: [-1. -1. -1. -0.8322415 0.9843118 0.04759049]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7360280364090481, 0.9232017585720846, 0.5881593626744092]
From Mu: [-1. -1. -1. -0.746584 0.4424964 -0.5098611]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6488643998651968, 0.2686077691383384, -0.3111219097689356]
From Mu: [-1. -1. -1. -0.76224035 1. 0.00513411]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8595738078202146, 1.0, -0.512847792326814]
From Mu: [-1. -1. -1. -0.8326718 0.98154134 0.05071499]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8643575460178847, 0.862350834502499, -0.38874976606175027]
From Mu: [-1. -1. -1. -0.8214912 1. 0.04705023]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6588649259331928, 1.0, -0.5046605473797209]
From Mu: [-1. -1. -1. -0.8289071 1. 0.02852955]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8517433537320316, 1.0, 0.05951976909559868]
From Mu: [-1. -1. -1. -0.75381917 0.41333315 -0.4943451 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6605816309924912, 0.5240264577972836, -0.36094379048087666]
From Mu: [-1. -1. -1. -0.7866599 1. 0.01418263]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8125747178432652, 1.0, -0.6301311988732121]
From Mu: [-1. -1. -1. -0.8319364 0.98617125 0.04550968]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9180389179816161, 1.0, 0.28216419973977785]
From Mu: [-1. -1. -1. -0.7531814 0.4038807 -0.4882373]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6380547114189727, 0.03953814606399447, -0.2504484085064785]
From Mu: [-1. -1. -1. -0.7395368 1. -0.0030805]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6973475279789967, 0.8115279369858396, 0.07558269950511493]
From Mu: [-1. -1. -1. -0.735009 0.46627623 -0.520403 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.622644426546135, 0.4373438596924615, -0.08400922156111618]
From Mu: [-1. -1. -1. -0.77733594 1. 0.00737545]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7586348374902103, 0.7959879168119375, 0.17666705980918532]
From Mu: [-1. -1. -1. -0.7331888 0.46033216 -0.51566833]
Sampled Actions: [-1.0, -1.0, -1.0, -0.5334251034131978, 0.3052061611582506, -0.5437402490291854]
From Mu: [-1. -1. -1. -0.7615332 1. -0.00640586]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7560654529868349, 1.0, 0.539021922370829]
From Mu: [-1. -1. -1. -0.7546068 0.4269057 -0.5030684]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8423875899476196, 0.4653336632067847, -1.0]
From Mu: [-1. -1. -1. -0.7865687 1. 0.03247565]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7663988395721106, 1.0, -0.17325005915778452]
From Mu: [-1. -1. -1. -0.83112794 0.99078536 0.04040235]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9676105318614661, 0.8365514947440982, 0.5571944694536217]
From Mu: [-1. -1. -1. -0.7360707 0.4243949 -0.49354514]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7366622475797552, 0.390995301230382, -0.03810309075937229]
From Mu: [-1. -1. -1. -0.77668625 1. 0.01852713]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8130309624714379, 1.0, 0.44082986876843167]
From Mu: [-1. -1. -1. -0.75415725 0.41883454 -0.49788752]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6394138721748022, 0.5443130386856704, -0.4965374936603323]
From Mu: [-1. -1. -1. -0.78786045 1. 0.01247414]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8427138518191807, 1.0, 0.16638944786908302]
From Mu: [-1. -1. -1. -0.75390023 0.41461757 -0.49517307]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6390485261141253, 0.5640379344859947, -0.5100361164760574]
From Mu: [-1. -1. -1. -0.78967327 1. 0.01303856]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7034092600547694, 0.7546028299960432, 0.05844635706625497]
From Mu: [-1. -1. -1. -0.72906953 0.47473878 -0.5232934 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.5826544421244291, 0.5793368480820541, -0.4019668633045341]
From Mu: [-1. -1. -1. -0.78923744 1. 0.00731073]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6381532763226888, 1.0, 0.3110264941862362]
From Mu: [-1. -1. -1. -0.7553595 0.4435204 -0.51367366]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7857085545448248, 0.494469254950458, -0.6016415142932836]
From Mu: [-1. -1. -1. -0.78768235 1. 0.02708494]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8083727740193192, 1.0, -0.24852696109124245]
From Mu: [-1. -1. -1. -0.83186644 0.98658824 0.04504448]
Sampled Actions: [-1.0, -1.0, -1.0, -0.776346378269931, 1.0, -0.28950093764337215]
From Mu: [-1. -1. -1. -0.8313095 0.98978597 0.04150212]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6960893478644005, 0.9014041015396248, -0.22198072487502907]
From Mu: [-1. -1. -1. -0.82138604 1. 0.02964587]
Sampled Actions: [-0.9768299492942232, -1.0, -1.0, -0.8759363600846799, 1.0, 0.12790216985630348]
From Mu: [-1. -1. -1. -0.75762206 0.40363485 -0.49327156]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7063905887776372, 0.20395591216468664, -0.486436042214649]
From Mu: [-1. -1. -1. -0.75801116 1. 0.00948197]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9542299599565807, 1.0, 0.11332216743685222]
From Mu: [-1. -1. -1. -0.75280184 0.39870414 -0.4848815 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6944751518937373, 0.20959305591299868, 0.04993119163857018]
From Mu: [-1. -1. -1. -0.67443234 0.5622158 -0.55371433]
Sampled Actions: [-1.0, -1.0, -1.0, -0.665550245298805, 0.38887023213162863, -0.1318197420317252]
From Mu: [-1. -1. -1. -0.7742209 1. 0.01062669]
Sampled Actions: [-1.0, -1.0, -1.0, -0.745085411438627, 0.9742014617465792, -0.4184609329492054]
From Mu: [-1. -1. -1. -0.8285844 0.9970036 0.03726296]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7205167559993333, 0.8334237806172715, -0.26492267600600583]
From Mu: [-1. -1. -1. -0.81611484 1. 0.03027082]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8613384701109654, 0.9797665377255256, 0.24349944851927657]
From Mu: [-1. -1. -1. -0.7516162 0.41537166 -0.49475768]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8702310431423083, 0.22695640724913071, -0.7334373026744053]
From Mu: [-1. -1. -1. -0.765258 1. 0.02830486]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7504270744637468, 1.0, -0.3195996561245299]
From Mu: [-1. -1. -1. -0.83082813 0.9923965 0.03863757]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8663857049559778, 0.5733008315297083, 0.7173743299851452]
From Mu: [-1. -1. -1. -0.71049124 0.48186427 -0.51813126]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8041422951433205, 0.5554909080842381, 0.20613152230278142]
From Mu: [-1. -1. -1. -0.70880026 0.49321756 -0.5251183 ]
Sampled Actions: [-1.0, -1.0, -1.0, -0.614003760194867, 0.7653976137533172, -0.9266509000795795]
From Mu: [-1. -1. -1. -0.80729204 1. 0.01647381]
Sampled Actions: [-1.0, -1.0, -1.0, -0.6881985439225536, 0.9390496989627011, -0.2663311783688894]
From Mu: [-1. -1. -1. -0.8244148 1. 0.02991825]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8310000061950585, 1.0, -0.31772355246662787]
From Mu: [-1. -1. -1. -0.8322353 0.98434806 0.04754952]
Sampled Actions: [-1.0, -1.0, -1.0, -0.9037621099534194, 0.8333114817000511, -0.6050761211733053]
From Mu: [-1. -1. -1. -0.81974214 1. 0.05053739]
Sampled Actions: [-1.0, -1.0, -1.0, -0.8060724344365541, 1.0, -0.17339006375675628]
From Mu: [-1. -1. -1. -0.8318277 0.98681706 0.04479015]
Sampled Actions: [-1.0, -1.0, -1.0, -1.0, 0.8159709382943136, 0.024050554393333336]
From Mu: [-1. -1. -1. -0.7337516 0.4232876 -0.4916418]
Sampled Actions: [-1.0, -1.0, -1.0, -0.7702245885232373, 0.5973745937048496, -0.26677264893490593]
My results from the IsaacSim:
new position tensor([[0.1949, 0.1820, 0.2187]], device='cuda:0')
tensor([[-0.7803, -1.0000, -1.0000, -1.0000, 1.0000, -0.5157]],
device='cuda:0')
tensor([[-0.5791, -1.0000, -1.0000, -1.0000, 0.3410, -0.5124]],
device='cuda:0')
tensor([[-0.4997, -1.0000, -1.0000, -1.0000, 0.2800, -0.5737]],
device='cuda:0')
tensor([[-0.4843, -1.0000, -1.0000, -1.0000, 0.2260, -0.5793]],
device='cuda:0')
tensor([[-0.5000, -1.0000, -1.0000, -1.0000, 0.1828, -0.5856]],
device='cuda:0')
tensor([[-0.5323, -1.0000, -1.0000, -1.0000, 0.1400, -0.5825]],
device='cuda:0')
tensor([[-0.5508, -1.0000, -1.0000, -1.0000, 0.1113, -0.6239]],
device='cuda:0')
tensor([[-0.6025, -1.0000, -1.0000, -1.0000, 0.0443, -0.5531]],
device='cuda:0')
tensor([[-0.5848, -1.0000, -1.0000, -1.0000, 0.0372, -0.6465]],
device='cuda:0')
tensor([[-0.5442, -1.0000, -1.0000, -1.0000, 0.0082, -0.6643]],
device='cuda:0')
tensor([[-0.4736, -1.0000, -1.0000, -1.0000, -0.0145, -0.7116]],
device='cuda:0')
tensor([[-0.5291, -1.0000, -1.0000, -1.0000, -0.0703, -0.7217]],
device='cuda:0')
tensor([[-0.4950, -1.0000, -1.0000, -1.0000, -0.0821, -0.7635]],
device='cuda:0')
tensor([[-0.5306, -1.0000, -1.0000, -1.0000, -0.1220, -0.8100]],
device='cuda:0')
tensor([[-0.5168, -1.0000, -1.0000, -1.0000, -0.1207, -0.8285]],
device='cuda:0')
tensor([[-0.5442, -1.0000, -1.0000, -1.0000, -0.0972, -0.8447]],
device='cuda:0')
tensor([[-0.5368, -1.0000, -1.0000, -1.0000, -0.0495, -0.7873]],
device='cuda:0')
tensor([[-0.5217, -1.0000, -1.0000, -1.0000, 0.0289, -0.7510]],
device='cuda:0')
tensor([[-0.4257, -0.7880, -1.0000, -1.0000, 0.1470, -0.6592]],
device='cuda:0')
tensor([[-0.2987, -0.0884, -1.0000, -1.0000, 0.2608, -0.5015]],
device='cuda:0')
tensor([[-0.4287, 0.1850, -1.0000, -1.0000, -0.2809, -0.4096]],
device='cuda:0')
tensor([[-0.5971, 0.0153, -1.0000, -1.0000, -0.1758, -0.5567]],
device='cuda:0')
tensor([[-0.6339, -0.6090, -1.0000, -1.0000, -0.1512, -0.5023]],
device='cuda:0')
tensor([[-0.3895, -0.3582, -1.0000, -1.0000, 0.3381, -0.3637]],
device='cuda:0')
tensor([[-0.2472, 0.5666, -1.0000, -0.9056, 0.4192, -0.1518]],
device='cuda:0')
tensor([[-0.5179, 0.4278, -0.8854, -0.8633, -0.1279, -0.2017]],
device='cuda:0')
tensor([[-0.7538, -0.2676, -1.0000, -1.0000, -0.1480, -0.3828]],
device='cuda:0')
tensor([[-0.5746, -0.3179, -1.0000, -1.0000, 0.1659, -0.4121]],
device='cuda:0')
tensor([[-0.3536, 0.1061, -1.0000, -1.0000, 0.2730, -0.0825]],
device='cuda:0')
tensor([[-0.4643, 0.4024, -1.0000, -0.9495, -0.2056, -0.2248]],
device='cuda:0')
tensor([[-0.6804, -0.0439, -1.0000, -1.0000, -0.2589, -0.5425]],
device='cuda:0')
tensor([[-0.6613, -0.5530, -1.0000, -1.0000, -0.1297, -0.4616]],
device='cuda:0')
tensor([[-0.4080, -0.3370, -1.0000, -1.0000, 0.2396, -0.3226]],
device='cuda:0')
tensor([[-0.3005, 0.5082, -1.0000, -0.9445, 0.3195, -0.1575]],
device='cuda:0')
tensor([[-0.5592, 0.3544, -0.8949, -0.9353, -0.2282, -0.2062]],
device='cuda:0')
tensor([[-0.7875, -0.3733, -1.0000, -1.0000, -0.2678, -0.4217]],
device='cuda:0')
tensor([[-0.5984, -0.5766, -1.0000, -1.0000, 0.0464, -0.5609]],
device='cuda:0')
tensor([[-0.2753, -0.0271, -1.0000, -1.0000, 0.3200, -0.1748]],
device='cuda:0')
tensor([[-0.3842, 0.4044, -1.0000, -0.9492, -0.2539, -0.2206]],
device='cuda:0')
tensor([[-6.4951e-01, -4.9989e-04, -1.0000e+00, -1.0000e+00, -2.5767e-01,
-5.5067e-01]], device='cuda:0')
tensor([[-0.6404, -0.5183, -1.0000, -1.0000, -0.1491, -0.4507]],
device='cuda:0')
tensor([[-0.3876, -0.3133, -1.0000, -1.0000, 0.2379, -0.3083]],
device='cuda:0')
tensor([[-0.2889, 0.4871, -1.0000, -0.9488, 0.2882, -0.1684]],
device='cuda:0')
tensor([[-0.5556, 0.3315, -0.8842, -0.9432, -0.2478, -0.2145]],
device='cuda:0')
tensor([[-0.7738, -0.3490, -1.0000, -1.0000, -0.2870, -0.4362]],
device='cuda:0')
tensor([[-0.5808, -0.5886, -1.0000, -1.0000, 0.0482, -0.5692]],
device='cuda:0')
tensor([[-0.2938, -0.0618, -1.0000, -1.0000, 0.2222, -0.1649]],
device='cuda:0')
tensor([[-0.3892, 0.3719, -1.0000, -0.9886, -0.2349, -0.2306]],
device='cuda:0')
tensor([[-0.6363, -0.0031, -1.0000, -1.0000, -0.2966, -0.5841]],
device='cuda:0')
tensor([[-0.6284, -0.5140, -1.0000, -1.0000, -0.1419, -0.4399]],
device='cuda:0')
tensor([[-0.3731, -0.3099, -1.0000, -1.0000, 0.2275, -0.3025]],
device='cuda:0')
tensor([[-0.2805, 0.4742, -1.0000, -0.9569, 0.2677, -0.1801]],
device='cuda:0')
tensor([[-0.5527, 0.3227, -0.8953, -0.9522, -0.2743, -0.2294]],
device='cuda:0')
tensor([[-0.7651, -0.3246, -1.0000, -1.0000, -0.3078, -0.4567]],
device='cuda:0')
tensor([[-0.5705, -0.4992, -1.0000, -1.0000, 0.0953, -0.5551]],
device='cuda:0')
tensor([[-0.2890, 0.0339, -1.0000, -1.0000, 0.2248, -0.1274]],
device='cuda:0')
tensor([[-0.4380, 0.2835, -1.0000, -1.0000, -0.3538, -0.2844]],
device='cuda:0')
tensor([[-0.6462, -0.0538, -1.0000, -1.0000, -0.2957, -0.5578]],
device='cuda:0')
tensor([[-0.6251, -0.5323, -1.0000, -1.0000, -0.1346, -0.4648]],
device='cuda:0')
tensor([[-0.3709, -0.3283, -1.0000, -1.0000, 0.2052, -0.3104]],
device='cuda:0')
tensor([[-0.2769, 0.4703, -1.0000, -0.9636, 0.2715, -0.1852]],
device='cuda:0')
tensor([[-0.5517, 0.3236, -0.9033, -0.9585, -0.2962, -0.2394]],
device='cuda:0')
tensor([[-0.7642, -0.3140, -1.0000, -1.0000, -0.3197, -0.4654]],
device='cuda:0')
tensor([[-0.5859, -0.4512, -1.0000, -1.0000, 0.0852, -0.5649]],
device='cuda:0')
tensor([[-0.3117, -0.0497, -1.0000, -1.0000, 0.1923, -0.1549]],
device='cuda:0')
tensor([[-0.4155, 0.2877, -1.0000, -1.0000, -0.3070, -0.3069]],
device='cuda:0')
tensor([[-0.6284, -0.0307, -1.0000, -1.0000, -0.2997, -0.5704]],
device='cuda:0')
tensor([[-0.6128, -0.5206, -1.0000, -1.0000, -0.1389, -0.4519]],
device='cuda:0')
tensor([[-0.3663, -0.3786, -1.0000, -1.0000, 0.2125, -0.3009]],
device='cuda:0')
tensor([[-0.2375, 0.4121, -1.0000, -1.0000, 0.2636, -0.1947]],
device='cuda:0')
tensor([[-0.5190, 0.3540, -0.9795, -0.9512, -0.2981, -0.2786]],
device='cuda:0')
tensor([[-0.7273, -0.2057, -1.0000, -1.0000, -0.3108, -0.4971]],
device='cuda:0')
tensor([[-0.6037, -0.4561, -1.0000, -1.0000, 0.0101, -0.5149]],
device='cuda:0')
tensor([[-0.3503, -0.1681, -1.0000, -1.0000, 0.1722, -0.2132]],
device='cuda:0')
tensor([[-0.3533, 0.4006, -1.0000, -1.0000, -0.0638, -0.2369]],
device='cuda:0')
tensor([[-0.6016, 0.0863, -1.0000, -1.0000, -0.2942, -0.5542]],
device='cuda:0')
tensor([[-0.6093, -0.4735, -1.0000, -1.0000, -0.1238, -0.4090]],
device='cuda:0')
tensor([[-0.3702, -0.3148, -1.0000, -1.0000, 0.2179, -0.2760]],
device='cuda:0')
tensor([[-0.2747, 0.4814, -1.0000, -0.9528, 0.2588, -0.1864]],
device='cuda:0')
tensor([[-0.5562, 0.3113, -0.8848, -0.9549, -0.3052, -0.2550]],
device='cuda:0')
tensor([[-0.7650, -0.3159, -1.0000, -1.0000, -0.3159, -0.4580]],
device='cuda:0')
tensor([[-0.5799, -0.4475, -1.0000, -1.0000, 0.0854, -0.5715]],
device='cuda:0')
tensor([[-0.3075, -0.0206, -1.0000, -1.0000, 0.1872, -0.1780]],
device='cuda:0')
tensor([[-0.4277, 0.2658, -1.0000, -1.0000, -0.3383, -0.3298]],
device='cuda:0')
tensor([[-0.6292, -0.0382, -1.0000, -1.0000, -0.2885, -0.5607]],
device='cuda:0')
tensor([[-0.6091, -0.5214, -1.0000, -1.0000, -0.1365, -0.4597]],
device='cuda:0')
tensor([[-0.3623, -0.3609, -1.0000, -1.0000, 0.2145, -0.2960]],
device='cuda:0')
tensor([[-0.2515, 0.4707, -1.0000, -0.9550, 0.3045, -0.2080]],
device='cuda:0')
tensor([[-0.5397, 0.3307, -0.8848, -0.9445, -0.3026, -0.2513]],
device='cuda:0')
tensor([[-0.7513, -0.2513, -1.0000, -1.0000, -0.3006, -0.4622]],
device='cuda:0')
tensor([[-0.5949, -0.4879, -1.0000, -1.0000, 0.0299, -0.5475]],
device='cuda:0')
tensor([[-0.3309, -0.1638, -1.0000, -1.0000, 0.1689, -0.2289]],
device='cuda:0')
tensor([[-0.3504, 0.3755, -1.0000, -1.0000, -0.1056, -0.2730]],
device='cuda:0')
tensor([[-0.6006, 0.0498, -1.0000, -1.0000, -0.3149, -0.6093]],
device='cuda:0')
tensor([[-0.6184, -0.5330, -1.0000, -1.0000, -0.1380, -0.4106]],
device='cuda:0')
tensor([[-0.3039, -0.2306, -1.0000, -1.0000, 0.3539, -0.2617]],
device='cuda:0')
tensor([[-0.2620, 0.4741, -1.0000, -0.9444, 0.1596, -0.2112]],
device='cuda:0')
tensor([[-0.5721, 0.2255, -0.9462, -0.9829, -0.3101, -0.3593]],
device='cuda:0')
tensor([[-0.7366, -0.3789, -1.0000, -1.0000, -0.2878, -0.4670]],
device='cuda:0')
tensor([[-0.5170, -0.5863, -1.0000, -1.0000, 0.0614, -0.5741]],
device='cuda:0')
tensor([[-0.2426, 0.3216, -1.0000, -1.0000, 0.3061, -0.1198]],
device='cuda:0')
tensor([[-0.4919, 0.3570, -1.0000, -0.9442, -0.2668, -0.2665]],
device='cuda:0')
tensor([[-0.6887, -0.1136, -1.0000, -1.0000, -0.2764, -0.5098]],
device='cuda:0')
tensor([[-0.6197, -0.5364, -1.0000, -1.0000, -0.0683, -0.4892]],
device='cuda:0')
tensor([[-0.3600, -0.2609, -1.0000, -1.0000, 0.1965, -0.2614]],
device='cuda:0')
tensor([[-0.3056, 0.4651, -1.0000, -0.9931, 0.1579, -0.1807]],
device='cuda:0')
tensor([[-0.5930, 0.2190, -1.0000, -1.0000, -0.3760, -0.4224]],
device='cuda:0')
tensor([[-0.7439, -0.4696, -1.0000, -1.0000, -0.3038, -0.4682]],
device='cuda:0')
tensor([[-0.5041, -0.4962, -1.0000, -1.0000, 0.0699, -0.5173]],
device='cuda:0')
tensor([[-0.2610, 0.4201, -1.0000, -1.0000, 0.2998, -0.1075]],
device='cuda:0')
tensor([[-0.5212, 0.3667, -0.9522, -0.9346, -0.2736, -0.2663]],
device='cuda:0')
tensor([[-0.7315, -0.1952, -1.0000, -1.0000, -0.2742, -0.4625]],
device='cuda:0')
tensor([[-0.6028, -0.4618, -1.0000, -1.0000, 0.0102, -0.5052]],
device='cuda:0')
tensor([[-0.3440, -0.1487, -1.0000, -1.0000, 0.1982, -0.1760]],
device='cuda:0')
tensor([[-0.3500, 0.4253, -1.0000, -1.0000, -0.0682, -0.1813]],
device='cuda:0')
tensor([[-0.6112, 0.0680, -1.0000, -1.0000, -0.3068, -0.5655]],
device='cuda:0')
tensor([[-0.6324, -0.5011, -1.0000, -1.0000, -0.1624, -0.4363]],
device='cuda:0')
tensor([[-0.3712, -0.2944, -1.0000, -1.0000, 0.2400, -0.2900]],
device='cuda:0')
tensor([[-0.2769, 0.4727, -1.0000, -0.9504, 0.2645, -0.1758]],
device='cuda:0')
tensor([[-0.5501, 0.3142, -0.8718, -0.9462, -0.2640, -0.2227]],
device='cuda:0')
tensor([[-0.7571, -0.2981, -1.0000, -1.0000, -0.2960, -0.4488]],
device='cuda:0')
tensor([[-0.5788, -0.4767, -1.0000, -1.0000, 0.0852, -0.5659]],
device='cuda:0')
tensor([[-0.2948, -0.0130, -1.0000, -1.0000, 0.2310, -0.1274]],
device='cuda:0')
tensor([[-0.4120, 0.3153, -1.0000, -1.0000, -0.2923, -0.2375]],
device='cuda:0')
tensor([[-0.6391, -0.0498, -1.0000, -1.0000, -0.3179, -0.5817]],
device='cuda:0')
tensor([[-0.6172, -0.5367, -1.0000, -1.0000, -0.1271, -0.4614]],
device='cuda:0')
tensor([[-0.3289, -0.3178, -1.0000, -1.0000, 0.2880, -0.2920]],
device='cuda:0')
tensor([[-0.2594, 0.4598, -1.0000, -0.9648, 0.2270, -0.2140]],
device='cuda:0')
tensor([[-0.5611, 0.2765, -0.9529, -0.9875, -0.3387, -0.3135]],
device='cuda:0')
tensor([[-0.7513, -0.3564, -1.0000, -1.0000, -0.3331, -0.4927]],
device='cuda:0')
tensor([[-0.5533, -0.5903, -1.0000, -1.0000, 0.0234, -0.5746]],
device='cuda:0')
tensor([[-0.2820, 0.0669, -1.0000, -1.0000, 0.2080, -0.2167]],
device='cuda:0')
tensor([[-0.4586, 0.3136, -1.0000, -0.9769, -0.3332, -0.2762]],
device='cuda:0')
tensor([[-0.6570, -0.0157, -1.0000, -1.0000, -0.3026, -0.5532]],
device='cuda:0')
tensor([[-0.6438, -0.5656, -1.0000, -1.0000, -0.1471, -0.4519]],
device='cuda:0')
tensor([[-0.3821, -0.3863, -1.0000, -1.0000, 0.1983, -0.3089]],
device='cuda:0')
tensor([[-0.2656, 0.3550, -1.0000, -1.0000, 0.2119, -0.1957]],
device='cuda:0')
tensor([[-0.5420, 0.2903, -1.0000, -0.9970, -0.3192, -0.3038]],
device='cuda:0')
tensor([[-0.7308, -0.3409, -1.0000, -1.0000, -0.3388, -0.5208]],
device='cuda:0')
tensor([[-0.5581, -0.5369, -1.0000, -1.0000, 0.0437, -0.5418]],
device='cuda:0')
tensor([[-0.2932, 0.0973, -1.0000, -1.0000, 0.2266, -0.1316]],
device='cuda:0')
tensor([[-0.4664, 0.3543, -1.0000, -0.9457, -0.2565, -0.2119]],
device='cuda:0')
tensor([[-0.6658, -0.0367, -1.0000, -1.0000, -0.2832, -0.5260]],
device='cuda:0')
tensor([[-0.6488, -0.5717, -1.0000, -1.0000, -0.1510, -0.4685]],
device='cuda:0')
tensor([[-0.3904, -0.3878, -1.0000, -1.0000, 0.1926, -0.3095]],
device='cuda:0')
tensor([[-0.2743, 0.3604, -1.0000, -1.0000, 0.2141, -0.1859]],
device='cuda:0')
tensor([[-0.5458, 0.2983, -1.0000, -0.9954, -0.3098, -0.2879]],
device='cuda:0')
tensor([[-0.7392, -0.3606, -1.0000, -1.0000, -0.3406, -0.5152]],
device='cuda:0')
tensor([[-0.5596, -0.5389, -1.0000, -1.0000, 0.0377, -0.5348]],
device='cuda:0')
tensor([[-0.2958, 0.0905, -1.0000, -1.0000, 0.2264, -0.1330]],
device='cuda:0')
tensor([[-0.4637, 0.3599, -1.0000, -0.9418, -0.2539, -0.2074]],
device='cuda:0')
tensor([[-0.6640, -0.0266, -1.0000, -1.0000, -0.2773, -0.5223]],
device='cuda:0')
tensor([[-0.6519, -0.5701, -1.0000, -1.0000, -0.1571, -0.4642]],
device='cuda:0')
tensor([[-0.3946, -0.3933, -1.0000, -1.0000, 0.1940, -0.3094]],
device='cuda:0')
tensor([[-0.2767, 0.3558, -1.0000, -1.0000, 0.2127, -0.1834]],
device='cuda:0')
tensor([[-0.5450, 0.3001, -1.0000, -0.9940, -0.2994, -0.2769]],
device='cuda:0')
tensor([[-0.7398, -0.3625, -1.0000, -1.0000, -0.3396, -0.5144]],
device='cuda:0')
tensor([[-0.5616, -0.5463, -1.0000, -1.0000, 0.0372, -0.5347]],
device='cuda:0')
tensor([[-0.2937, 0.0803, -1.0000, -1.0000, 0.2323, -0.1242]],
device='cuda:0')
tensor([[-0.4606, 0.3558, -1.0000, -0.9441, -0.2692, -0.2118]],
device='cuda:0')
tensor([[-0.6626, -0.0223, -1.0000, -1.0000, -0.2699, -0.5206]],
device='cuda:0')
tensor([[-0.6534, -0.5786, -1.0000, -1.0000, -0.1597, -0.4666]],
device='cuda:0')
tensor([[-0.3960, -0.4064, -1.0000, -1.0000, 0.1931, -0.3110]],
device='cuda:0')
tensor([[-0.2769, 0.3459, -1.0000, -1.0000, 0.2079, -0.1825]],
device='cuda:0')
tensor([[-0.5451, 0.2930, -1.0000, -0.9983, -0.2989, -0.2777]],
device='cuda:0')
tensor([[-0.7378, -0.3694, -1.0000, -1.0000, -0.3389, -0.5180]],
device='cuda:0')
tensor([[-0.5600, -0.5524, -1.0000, -1.0000, 0.0367, -0.5340]],
device='cuda:0')
tensor([[-0.2921, 0.0833, -1.0000, -1.0000, 0.2365, -0.1189]],
device='cuda:0')
tensor([[-0.4625, 0.3526, -1.0000, -0.9450, -0.2664, -0.2104]],
device='cuda:0')
tensor([[-0.6639, -0.0311, -1.0000, -1.0000, -0.2720, -0.5216]],
device='cuda:0')
tensor([[-0.6510, -0.5727, -1.0000, -1.0000, -0.1522, -0.4663]],
device='cuda:0')
tensor([[-0.3952, -0.3910, -1.0000, -1.0000, 0.1923, -0.3038]],
device='cuda:0')
tensor([[-0.2799, 0.3555, -1.0000, -1.0000, 0.2075, -0.1828]],
device='cuda:0')
tensor([[-0.5500, 0.2884, -1.0000, -1.0000, -0.3110, -0.2906]],
device='cuda:0')
tensor([[-0.7410, -0.3850, -1.0000, -1.0000, -0.3411, -0.5151]],
device='cuda:0')
tensor([[-0.5556, -0.5451, -1.0000, -1.0000, 0.0359, -0.5305]],
device='cuda:0')
tensor([[-0.2935, 0.1061, -1.0000, -1.0000, 0.2300, -0.1316]],
device='cuda:0')
tensor([[-0.4671, 0.3619, -1.0000, -0.9397, -0.2398, -0.1984]],
device='cuda:0')
tensor([[-0.6684, -0.0395, -1.0000, -1.0000, -0.2807, -0.5203]],
device='cuda:0')
tensor([[-0.6503, -0.5712, -1.0000, -1.0000, -0.1466, -0.4675]],
device='cuda:0')
tensor([[-0.3930, -0.3828, -1.0000, -1.0000, 0.1917, -0.3033]],
device='cuda:0')
tensor([[-0.2787, 0.3659, -1.0000, -1.0000, 0.2145, -0.1820]],
device='cuda:0')
tensor([[-0.5502, 0.2953, -1.0000, -0.9991, -0.3162, -0.2921]],
device='cuda:0')
tensor([[-0.7430, -0.3796, -1.0000, -1.0000, -0.3441, -0.5145]],
device='cuda:0')
tensor([[-0.5566, -0.5356, -1.0000, -1.0000, 0.0355, -0.5298]],
device='cuda:0')
tensor([[-0.2972, 0.1030, -1.0000, -1.0000, 0.2212, -0.1427]],
device='cuda:0')
tensor([[-0.4690, 0.3586, -1.0000, -0.9432, -0.2481, -0.2100]],
device='cuda:0')
tensor([[-0.6678, -0.0381, -1.0000, -1.0000, -0.2809, -0.5212]],
device='cuda:0')
tensor([[-0.6487, -0.5649, -1.0000, -1.0000, -0.1484, -0.4652]],
device='cuda:0')
tensor([[-0.3909, -0.3769, -1.0000, -1.0000, 0.1939, -0.3051]],
device='cuda:0')
tensor([[-0.2749, 0.3757, -1.0000, -1.0000, 0.2268, -0.1811]],
device='cuda:0')
tensor([[-0.5449, 0.3117, -1.0000, -0.9883, -0.3067, -0.2754]],
device='cuda:0')
tensor([[-0.7440, -0.3547, -1.0000, -1.0000, -0.3436, -0.5119]],
device='cuda:0')
tensor([[-0.5660, -0.5379, -1.0000, -1.0000, 0.0352, -0.5353]],
device='cuda:0')
tensor([[-0.3007, 0.0550, -1.0000, -1.0000, 0.2162, -0.1443]],
device='cuda:0')
tensor([[-0.4445, 0.3094, -1.0000, -0.9723, -0.3125, -0.2306]],
device='cuda:0')
tensor([[-0.6594, -0.0551, -1.0000, -1.0000, -0.2756, -0.5282]],
device='cuda:0')
tensor([[-0.6346, -0.5281, -1.0000, -1.0000, -0.1268, -0.4572]],
device='cuda:0')
tensor([[-0.3833, -0.3197, -1.0000, -1.0000, 0.1984, -0.2862]],
device='cuda:0')
tensor([[-0.2968, 0.4602, -1.0000, -0.9756, 0.2503, -0.1755]],
device='cuda:0')
tensor([[-0.5684, 0.2985, -0.9363, -0.9852, -0.3234, -0.2635]],
device='cuda:0')
tensor([[-0.7731, -0.3885, -1.0000, -1.0000, -0.3421, -0.4787]],
device='cuda:0')
tensor([[-0.5725, -0.6008, -1.0000, -1.0000, 0.0023, -0.5603]],
device='cuda:0')
tensor([[-0.2975, -0.0499, -1.0000, -1.0000, 0.1893, -0.2351]],
device='cuda:0')
tensor([[-0.4025, 0.3389, -1.0000, -0.9975, -0.2409, -0.2402]],
device='cuda:0')
tensor([[-0.6324, -0.0222, -1.0000, -1.0000, -0.2976, -0.5784]],
device='cuda:0')
tensor([[-0.6186, -0.5112, -1.0000, -1.0000, -0.1244, -0.4340]],
device='cuda:0')
tensor([[-0.3425, -0.2851, -1.0000, -1.0000, 0.2705, -0.2789]],
device='cuda:0')
tensor([[-0.2801, 0.4456, -1.0000, -0.9735, 0.2027, -0.2032]],
device='cuda:0')
tensor([[-0.5727, 0.2421, -0.9875, -1.0000, -0.3456, -0.3397]],
device='cuda:0')
tensor([[-0.7417, -0.4398, -1.0000, -1.0000, -0.3372, -0.5035]],
device='cuda:0')
tensor([[-0.5249, -0.5705, -1.0000, -1.0000, 0.0377, -0.5532]],
device='cuda:0')
tensor([[-0.2761, 0.2282, -1.0000, -1.0000, 0.2312, -0.1817]],
device='cuda:0')
tensor([[-0.4915, 0.3450, -1.0000, -0.9554, -0.2565, -0.2331]],
device='cuda:0')
tensor([[-0.6886, -0.1143, -1.0000, -1.0000, -0.3012, -0.5236]],
device='cuda:0')
tensor([[-0.6273, -0.5337, -1.0000, -1.0000, -0.0746, -0.4898]],
device='cuda:0')
tensor([[-0.3690, -0.2700, -1.0000, -1.0000, 0.1821, -0.2686]],
device='cuda:0')
tensor([[-0.3092, 0.4642, -1.0000, -0.9923, 0.1708, -0.1753]],
device='cuda:0')
tensor([[-0.5942, 0.2197, -1.0000, -1.0000, -0.3850, -0.4139]],
device='cuda:0')
tensor([[-0.7496, -0.4757, -1.0000, -1.0000, -0.3146, -0.4704]],
device='cuda:0')
tensor([[-0.5107, -0.5037, -1.0000, -1.0000, 0.0571, -0.5195]],
device='cuda:0')
tensor([[-0.2735, 0.3697, -1.0000, -1.0000, 0.2654, -0.1314]],
device='cuda:0')
tensor([[-0.5175, 0.3619, -0.9812, -0.9413, -0.2688, -0.2516]],
device='cuda:0')
tensor([[-0.7245, -0.1942, -1.0000, -1.0000, -0.2958, -0.4839]],
device='cuda:0')
tensor([[-0.6035, -0.4493, -1.0000, -1.0000, 0.0116, -0.5023]],
device='cuda:0')
tensor([[-0.3480, -0.1405, -1.0000, -1.0000, 0.1921, -0.1755]],
device='cuda:0')
tensor([[-0.3610, 0.4093, -1.0000, -1.0000, -0.0885, -0.1934]],
device='cuda:0')
tensor([[-0.6171, 0.0422, -1.0000, -1.0000, -0.3134, -0.5867]],
device='cuda:0')
tensor([[-0.6270, -0.4968, -1.0000, -1.0000, -0.1434, -0.4275]],
device='cuda:0')
tensor([[-0.3687, -0.2836, -1.0000, -1.0000, 0.2332, -0.2812]],
device='cuda:0')
tensor([[-0.2839, 0.4661, -1.0000, -0.9599, 0.2380, -0.1787]],
device='cuda:0')
tensor([[-0.5601, 0.2964, -0.9055, -0.9665, -0.2953, -0.2546]],
device='cuda:0')
tensor([[-0.7620, -0.3437, -1.0000, -1.0000, -0.3194, -0.4655]],
device='cuda:0')
tensor([[-0.5668, -0.6080, -1.0000, -1.0000, 0.0233, -0.5792]],
device='cuda:0')
tensor([[-0.2823, -0.0082, -1.0000, -1.0000, 0.2097, -0.2072]],
device='cuda:0')
tensor([[-0.4125, 0.3243, -1.0000, -0.9950, -0.2805, -0.2418]],
device='cuda:0')
tensor([[-0.6387, -0.0382, -1.0000, -1.0000, -0.2991, -0.5709]],
device='cuda:0')
tensor([[-0.6202, -0.5244, -1.0000, -1.0000, -0.1260, -0.4491]],
device='cuda:0')
tensor([[-0.3534, -0.3054, -1.0000, -1.0000, 0.2377, -0.2896]],
device='cuda:0')
tensor([[-0.2779, 0.4545, -1.0000, -0.9713, 0.2296, -0.1969]],
device='cuda:0')
tensor([[-0.5664, 0.2728, -0.9579, -0.9930, -0.3407, -0.3069]],
device='cuda:0')
tensor([[-0.7567, -0.3899, -1.0000, -1.0000, -0.3412, -0.4927]],
device='cuda:0')
tensor([[-0.5520, -0.5938, -1.0000, -1.0000, 0.0150, -0.5662]],
device='cuda:0')
tensor([[-0.2852, 0.0616, -1.0000, -1.0000, 0.2043, -0.2251]],
device='cuda:0')
tensor([[-0.4429, 0.2867, -1.0000, -0.9821, -0.3252, -0.2566]],
device='cuda:0')
tensor([[-0.6506, -0.0616, -1.0000, -1.0000, -0.2743, -0.5350]],
device='cuda:0')
tensor([[-0.6218, -0.5319, -1.0000, -1.0000, -0.1154, -0.4649]],
device='cuda:0')
tensor([[-0.3687, -0.3097, -1.0000, -1.0000, 0.2049, -0.2828]],
device='cuda:0')
tensor([[-0.2902, 0.4575, -1.0000, -0.9771, 0.2327, -0.1853]],
device='cuda:0')
tensor([[-0.5735, 0.2711, -0.9651, -0.9999, -0.3530, -0.3132]],
device='cuda:0')
tensor([[-0.7612, -0.4135, -1.0000, -1.0000, -0.3484, -0.4963]],
device='cuda:0')
tensor([[-0.5513, -0.5688, -1.0000, -1.0000, 0.0157, -0.5500]],
device='cuda:0')
tensor([[-0.2928, 0.0781, -1.0000, -1.0000, 0.1962, -0.2245]],
device='cuda:0')
tensor([[-0.4668, 0.3245, -1.0000, -0.9637, -0.2954, -0.2663]],
device='cuda:0')
tensor([[-0.6535, -0.0235, -1.0000, -1.0000, -0.2711, -0.5323]],
device='cuda:0')
tensor([[-0.6397, -0.5590, -1.0000, -1.0000, -0.1520, -0.4603]],
device='cuda:0')
tensor([[-0.3828, -0.3794, -1.0000, -1.0000, 0.2000, -0.3075]],
device='cuda:0')
tensor([[-0.2671, 0.3634, -1.0000, -1.0000, 0.2212, -0.1915]],
device='cuda:0')
tensor([[-0.5403, 0.3045, -1.0000, -0.9888, -0.3071, -0.2816]],
device='cuda:0')
tensor([[-0.7354, -0.3340, -1.0000, -1.0000, -0.3396, -0.5161]],
device='cuda:0')
tensor([[-0.5632, -0.5288, -1.0000, -1.0000, 0.0488, -0.5384]],
device='cuda:0')
tensor([[-0.2956, 0.0771, -1.0000, -1.0000, 0.2260, -0.1219]],
device='cuda:0')
tensor([[-0.4649, 0.3393, -1.0000, -0.9580, -0.2975, -0.2316]],
device='cuda:0')
tensor([[-0.6617, -0.0296, -1.0000, -1.0000, -0.2781, -0.5297]],
device='cuda:0')
tensor([[-0.6490, -0.5648, -1.0000, -1.0000, -0.1574, -0.4645]],
device='cuda:0')
tensor([[-0.3916, -0.3865, -1.0000, -1.0000, 0.1944, -0.3089]],
device='cuda:0')
tensor([[-0.2736, 0.3598, -1.0000, -1.0000, 0.2178, -0.1838]],
device='cuda:0')
tensor([[-0.5422, 0.3061, -1.0000, -0.9891, -0.2977, -0.2717]],
device='cuda:0')
tensor([[-0.7390, -0.3460, -1.0000, -1.0000, -0.3380, -0.5128]],
device='cuda:0')
tensor([[-0.5650, -0.5434, -1.0000, -1.0000, 0.0395, -0.5373]],
device='cuda:0')
tensor([[-0.2955, 0.0631, -1.0000, -1.0000, 0.2286, -0.1241]],
device='cuda:0')
tensor([[-0.4432, 0.3116, -1.0000, -0.9676, -0.3068, -0.2153]],
device='cuda:0')
tensor([[-0.6620, -0.0624, -1.0000, -1.0000, -0.2770, -0.5266]],
device='cuda:0')
tensor([[-0.6356, -0.5370, -1.0000, -1.0000, -0.1215, -0.4635]],
device='cuda:0')
tensor([[-0.3831, -0.3208, -1.0000, -1.0000, 0.1958, -0.2832]],
device='cuda:0')
tensor([[-0.2987, 0.4597, -1.0000, -0.9780, 0.2456, -0.1769]],
device='cuda:0')
tensor([[-0.5725, 0.2902, -0.9486, -0.9927, -0.3359, -0.2793]],
device='cuda:0')
tensor([[-0.7722, -0.4037, -1.0000, -1.0000, -0.3474, -0.4860]],
device='cuda:0')
tensor([[-0.5678, -0.5846, -1.0000, -1.0000, 0.0061, -0.5510]],
device='cuda:0')
tensor([[-0.2985, -0.0166, -1.0000, -1.0000, 0.1880, -0.2318]],
device='cuda:0')
tensor([[-0.4202, 0.3187, -1.0000, -0.9969, -0.2733, -0.2526]],
device='cuda:0')
tensor([[-0.6377, -0.0311, -1.0000, -1.0000, -0.2880, -0.5636]],
device='cuda:0')
tensor([[-0.6216, -0.5131, -1.0000, -1.0000, -0.1241, -0.4385]],
device='cuda:0')
tensor([[-0.3661, -0.3043, -1.0000, -1.0000, 0.2182, -0.2817]],
device='cuda:0')
tensor([[-0.2868, 0.4543, -1.0000, -0.9735, 0.2333, -0.1871]],
device='cuda:0')
tensor([[-0.5685, 0.2741, -0.9537, -0.9930, -0.3401, -0.2991]],
device='cuda:0')
tensor([[-0.7611, -0.3956, -1.0000, -1.0000, -0.3423, -0.4906]],
device='cuda:0')
tensor([[-0.5562, -0.5984, -1.0000, -1.0000, 0.0098, -0.5641]],
device='cuda:0')
tensor([[-0.2873, 0.0339, -1.0000, -1.0000, 0.1985, -0.2318]],
device='cuda:0')
tensor([[-0.4360, 0.2954, -1.0000, -0.9887, -0.3062, -0.2536]],
device='cuda:0')
tensor([[-0.6461, -0.0558, -1.0000, -1.0000, -0.2811, -0.5465]],
device='cuda:0')
tensor([[-0.6211, -0.5295, -1.0000, -1.0000, -0.1152, -0.4591]],
device='cuda:0')
tensor([[-0.3654, -0.3063, -1.0000, -1.0000, 0.2103, -0.2800]],
device='cuda:0')
tensor([[-0.2900, 0.4546, -1.0000, -0.9775, 0.2273, -0.1877]],
device='cuda:0')
tensor([[-0.5742, 0.2648, -0.9708, -1.0000, -0.3558, -0.3214]],
device='cuda:0')
tensor([[-0.7586, -0.4212, -1.0000, -1.0000, -0.3472, -0.4968]],
device='cuda:0')
tensor([[-0.5457, -0.5672, -1.0000, -1.0000, 0.0183, -0.5494]],
device='cuda:0')
tensor([[-0.2905, 0.1064, -1.0000, -1.0000, 0.1999, -0.2211]],
device='cuda:0')
tensor([[-0.4722, 0.3323, -1.0000, -0.9586, -0.2664, -0.2508]],
device='cuda:0')
tensor([[-0.6605, -0.0421, -1.0000, -1.0000, -0.2817, -0.5315]],
device='cuda:0')
tensor([[-0.6381, -0.5622, -1.0000, -1.0000, -0.1392, -0.4667]],
device='cuda:0')
tensor([[-0.3794, -0.3645, -1.0000, -1.0000, 0.1975, -0.3016]],
device='cuda:0')
tensor([[-0.2668, 0.3997, -1.0000, -1.0000, 0.2547, -0.1815]],
device='cuda:0')
tensor([[-0.5397, 0.3284, -0.9867, -0.9767, -0.3101, -0.2639]],
device='cuda:0')
tensor([[-0.7473, -0.3165, -1.0000, -1.0000, -0.3421, -0.5055]],
device='cuda:0')
tensor([[-0.5759, -0.4503, -1.0000, -1.0000, 0.0931, -0.5285]],
device='cuda:0')
tensor([[-0.3063, 0.0434, -1.0000, -1.0000, 0.2139, -0.1019]],
device='cuda:0')
tensor([[-0.4515, 0.2717, -1.0000, -1.0000, -0.3592, -0.2826]],
device='cuda:0')
tensor([[-0.6523, -0.0604, -1.0000, -1.0000, -0.3011, -0.5513]],
device='cuda:0')
tensor([[-0.6299, -0.5288, -1.0000, -1.0000, -0.1293, -0.4625]],
device='cuda:0')
tensor([[-0.3766, -0.3207, -1.0000, -1.0000, 0.1954, -0.2984]],
device='cuda:0')
tensor([[-0.2870, 0.4643, -1.0000, -0.9698, 0.2557, -0.1799]],
device='cuda:0')
tensor([[-0.5615, 0.3053, -0.9184, -0.9746, -0.3173, -0.2565]],
device='cuda:0')
tensor([[-0.7693, -0.3567, -1.0000, -1.0000, -0.3350, -0.4718]],
device='cuda:0')
tensor([[-0.5754, -0.6086, -1.0000, -1.0000, 0.0031, -0.5731]],
device='cuda:0')
tensor([[-0.2957, -0.0666, -1.0000, -1.0000, 0.1879, -0.2403]],
device='cuda:0')
tensor([[-0.3926, 0.3446, -1.0000, -1.0000, -0.2304, -0.2428]],
device='cuda:0')
tensor([[-0.6270, -0.0151, -1.0000, -1.0000, -0.3029, -0.5866]],
device='cuda:0')
tensor([[-0.6143, -0.5114, -1.0000, -1.0000, -0.1282, -0.4333]],
device='cuda:0')
tensor([[-0.3684, -0.3649, -1.0000, -1.0000, 0.2131, -0.2769]],
device='cuda:0')
tensor([[-0.2462, 0.4413, -1.0000, -0.9724, 0.2909, -0.1873]],
device='cuda:0')
tensor([[-0.5350, 0.3368, -0.9183, -0.9514, -0.3124, -0.2609]],
device='cuda:0')
tensor([[-0.7492, -0.2449, -1.0000, -1.0000, -0.3118, -0.4746]],
device='cuda:0')
tensor([[-0.6020, -0.4743, -1.0000, -1.0000, 0.0221, -0.5375]],
device='cuda:0')
tensor([[-0.3425, -0.1788, -1.0000, -1.0000, 0.1572, -0.2315]],
device='cuda:0')
tensor([[-0.3483, 0.3797, -1.0000, -1.0000, -0.0717, -0.2763]],
device='cuda:0')
tensor([[-0.5911, 0.0945, -1.0000, -1.0000, -0.2887, -0.5555]],
device='cuda:0')
tensor([[-0.6273, -0.5177, -1.0000, -1.0000, -0.1635, -0.4249]],
device='cuda:0')
tensor([[-0.3509, -0.2668, -1.0000, -1.0000, 0.2636, -0.2836]],
device='cuda:0')
tensor([[-0.2662, 0.4800, -1.0000, -0.9399, 0.2440, -0.1831]],
device='cuda:0')
tensor([[-0.5456, 0.3145, -0.8532, -0.9345, -0.2498, -0.2192]],
device='cuda:0')
tensor([[-0.7486, -0.2685, -1.0000, -1.0000, -0.2857, -0.4443]],
device='cuda:0')
tensor([[-0.5790, -0.4935, -1.0000, -1.0000, 0.0609, -0.5598]],
device='cuda:0')
tensor([[-0.2991, -0.0533, -1.0000, -1.0000, 0.2202, -0.1620]],
device='cuda:0')
tensor([[-0.3970, 0.3243, -1.0000, -1.0000, -0.2596, -0.2376]],
device='cuda:0')
tensor([[-0.6314, -0.0386, -1.0000, -1.0000, -0.3215, -0.5919]],
device='cuda:0')
tensor([[-0.6143, -0.5364, -1.0000, -1.0000, -0.1279, -0.4557]],
device='cuda:0')
tensor([[-0.3653, -0.3880, -1.0000, -1.0000, 0.2042, -0.2973]],
device='cuda:0')
tensor([[-0.2412, 0.3953, -1.0000, -1.0000, 0.2324, -0.2021]],
device='cuda:0')
tensor([[-0.5306, 0.3223, -1.0000, -0.9756, -0.3312, -0.3241]],
device='cuda:0')
tensor([[-0.7258, -0.2591, -1.0000, -1.0000, -0.3280, -0.5111]],
device='cuda:0')
tensor([[-0.5822, -0.3976, -1.0000, -1.0000, 0.0628, -0.5175]],
device='cuda:0')
tensor([[-0.3265, -0.0089, -1.0000, -1.0000, 0.2026, -0.1570]],
device='cuda:0')
tensor([[-0.4340, 0.2944, -1.0000, -1.0000, -0.3125, -0.2755]],
device='cuda:0')
tensor([[-0.6408, -0.0402, -1.0000, -1.0000, -0.2957, -0.5622]],
device='cuda:0')
tensor([[-0.6219, -0.5171, -1.0000, -1.0000, -0.1333, -0.4510]],
device='cuda:0')
tensor([[-0.3646, -0.3139, -1.0000, -1.0000, 0.2173, -0.3010]],
device='cuda:0')
tensor([[-0.2777, 0.4610, -1.0000, -0.9653, 0.2523, -0.1904]],
device='cuda:0')
tensor([[-0.5564, 0.3037, -0.9157, -0.9693, -0.3101, -0.2576]],
device='cuda:0')
tensor([[-0.7624, -0.3340, -1.0000, -1.0000, -0.3283, -0.4749]],
device='cuda:0')
tensor([[-0.5711, -0.5894, -1.0000, -1.0000, 0.0281, -0.5744]],
device='cuda:0')
tensor([[-0.2914, -0.0353, -1.0000, -1.0000, 0.1924, -0.2171]],
device='cuda:0')
tensor([[-0.4122, 0.3104, -1.0000, -1.0000, -0.2820, -0.2712]],
device='cuda:0')
tensor([[-0.6324, -0.0314, -1.0000, -1.0000, -0.2977, -0.5723]],
device='cuda:0')
tensor([[-0.6174, -0.5197, -1.0000, -1.0000, -0.1295, -0.4449]],
device='cuda:0')
tensor([[-0.3236, -0.2897, -1.0000, -1.0000, 0.3138, -0.2872]],
device='cuda:0')
tensor([[-0.2678, 0.4483, -1.0000, -0.9677, 0.1976, -0.2151]],
device='cuda:0')
tensor([[-0.5694, 0.2433, -0.9802, -1.0000, -0.3393, -0.3408]],
device='cuda:0')
tensor([[-0.7398, -0.4217, -1.0000, -1.0000, -0.3312, -0.5010]],
device='cuda:0')
tensor([[-0.5261, -0.5753, -1.0000, -1.0000, 0.0401, -0.5579]],
device='cuda:0')
tensor([[-0.2711, 0.2308, -1.0000, -1.0000, 0.2407, -0.1709]],
device='cuda:0')
tensor([[-0.4868, 0.3516, -1.0000, -0.9514, -0.2532, -0.2309]],
device='cuda:0')
tensor([[-0.6835, -0.0922, -1.0000, -1.0000, -0.2960, -0.5236]],
device='cuda:0')
tensor([[-0.6337, -0.5523, -1.0000, -1.0000, -0.0995, -0.4834]],
device='cuda:0')
tensor([[-0.3742, -0.3118, -1.0000, -1.0000, 0.1880, -0.2842]],
device='cuda:0')
tensor([[-0.2965, 0.4643, -1.0000, -0.9845, 0.2236, -0.1802]],
device='cuda:0')
tensor([[-0.5807, 0.2652, -0.9948, -1.0000, -0.3720, -0.3464]],
device='cuda:0')
tensor([[-0.7577, -0.4520, -1.0000, -1.0000, -0.3513, -0.4998]],
device='cuda:0')
tensor([[-0.5356, -0.5175, -1.0000, -1.0000, 0.0334, -0.5281]],
device='cuda:0')
tensor([[-0.2951, 0.1973, -1.0000, -1.0000, 0.2050, -0.2014]],
device='cuda:0')
tensor([[-0.4943, 0.3368, -1.0000, -0.9605, -0.2728, -0.2688]],
device='cuda:0')
tensor([[-0.6838, -0.0971, -1.0000, -1.0000, -0.2930, -0.5195]],
device='cuda:0')
tensor([[-0.6246, -0.5082, -1.0000, -1.0000, -0.0903, -0.4670]],
device='cuda:0')
tensor([[-0.3690, -0.2578, -1.0000, -1.0000, 0.1930, -0.2722]],
device='cuda:0')
tensor([[-0.3052, 0.4689, -1.0000, -0.9833, 0.1729, -0.1713]],
device='cuda:0')
tensor([[-0.5918, 0.2232, -1.0000, -1.0000, -0.3742, -0.4007]],
device='cuda:0')
tensor([[-0.7454, -0.4662, -1.0000, -1.0000, -0.3185, -0.4767]],
device='cuda:0')
tensor([[-0.5093, -0.5043, -1.0000, -1.0000, 0.0585, -0.5228]],
device='cuda:0')
tensor([[-0.2698, 0.3824, -1.0000, -1.0000, 0.2699, -0.1312]],
device='cuda:0')
tensor([[-0.5184, 0.3617, -0.9741, -0.9404, -0.2728, -0.2572]],
device='cuda:0')
tensor([[-0.7253, -0.1915, -1.0000, -1.0000, -0.2929, -0.4808]],
device='cuda:0')
tensor([[-0.6030, -0.4550, -1.0000, -1.0000, 0.0075, -0.5042]],
device='cuda:0')
tensor([[-0.3465, -0.1470, -1.0000, -1.0000, 0.1917, -0.1829]],
device='cuda:0')
tensor([[-0.3552, 0.4152, -1.0000, -1.0000, -0.0746, -0.1908]],
device='cuda:0')
tensor([[-0.6127, 0.0601, -1.0000, -1.0000, -0.3068, -0.5679]],
device='cuda:0')
tensor([[-0.6303, -0.4999, -1.0000, -1.0000, -0.1562, -0.4335]],
device='cuda:0')
tensor([[-0.3697, -0.2924, -1.0000, -1.0000, 0.2367, -0.2882]],
device='cuda:0')
tensor([[-0.2783, 0.4694, -1.0000, -0.9534, 0.2566, -0.1777]],
device='cuda:0')
tensor([[-0.5512, 0.3123, -0.8782, -0.9500, -0.2705, -0.2251]],
device='cuda:0')
tensor([[-0.7583, -0.3034, -1.0000, -1.0000, -0.3043, -0.4544]],
device='cuda:0')
tensor([[-0.5802, -0.4745, -1.0000, -1.0000, 0.0860, -0.5687]],
device='cuda:0')
tensor([[-0.2951, -0.0132, -1.0000, -1.0000, 0.2255, -0.1281]],
device='cuda:0')
tensor([[-0.4153, 0.3044, -1.0000, -1.0000, -0.3068, -0.2550]],
device='cuda:0')
tensor([[-0.6379, -0.0512, -1.0000, -1.0000, -0.3172, -0.5788]],
device='cuda:0')
tensor([[-0.6159, -0.5358, -1.0000, -1.0000, -0.1294, -0.4644]],
device='cuda:0')
tensor([[-0.3679, -0.3852, -1.0000, -1.0000, 0.1982, -0.2976]],
device='cuda:0')
tensor([[-0.2418, 0.4039, -1.0000, -1.0000, 0.2379, -0.1959]],
device='cuda:0')
tensor([[-0.5310, 0.3279, -1.0000, -0.9712, -0.3298, -0.3158]],
device='cuda:0')
tensor([[-0.7280, -0.2581, -1.0000, -1.0000, -0.3303, -0.5088]],
device='cuda:0')
tensor([[-0.5844, -0.3979, -1.0000, -1.0000, 0.0591, -0.5166]],
device='cuda:0')
tensor([[-0.3301, -0.0242, -1.0000, -1.0000, 0.1953, -0.1650]],
device='cuda:0')
tensor([[-0.4295, 0.2980, -1.0000, -1.0000, -0.3013, -0.2779]],
device='cuda:0')
tensor([[-0.6378, -0.0355, -1.0000, -1.0000, -0.2954, -0.5645]],
device='cuda:0')
tensor([[-0.6195, -0.5145, -1.0000, -1.0000, -0.1327, -0.4477]],
device='cuda:0')
tensor([[-0.3500, -0.2986, -1.0000, -1.0000, 0.2506, -0.2956]],
device='cuda:0')
tensor([[-0.2765, 0.4547, -1.0000, -0.9668, 0.2283, -0.1980]],
device='cuda:0')
tensor([[-0.5642, 0.2735, -0.9462, -0.9869, -0.3291, -0.2977]],
device='cuda:0')
tensor([[-0.7564, -0.3769, -1.0000, -1.0000, -0.3330, -0.4868]],
device='cuda:0')
tensor([[-0.5547, -0.6106, -1.0000, -1.0000, 0.0137, -0.5759]],
device='cuda:0')
tensor([[-0.2818, 0.0383, -1.0000, -1.0000, 0.2077, -0.2259]],
device='cuda:0')
tensor([[-0.4329, 0.3001, -1.0000, -0.9853, -0.3030, -0.2440]],
device='cuda:0')
tensor([[-0.6476, -0.0591, -1.0000, -1.0000, -0.2828, -0.5476]],
device='cuda:0')
tensor([[-0.6206, -0.5341, -1.0000, -1.0000, -0.1130, -0.4634]],
device='cuda:0')
tensor([[-0.3631, -0.3081, -1.0000, -1.0000, 0.2107, -0.2826]],
device='cuda:0')
tensor([[-0.2881, 0.4559, -1.0000, -0.9776, 0.2280, -0.1894]],
device='cuda:0')
tensor([[-0.5741, 0.2655, -0.9735, -1.0000, -0.3572, -0.3237]],
device='cuda:0')
tensor([[-0.7576, -0.4227, -1.0000, -1.0000, -0.3485, -0.4989]],
device='cuda:0')
tensor([[-0.5441, -0.5635, -1.0000, -1.0000, 0.0204, -0.5487]],
device='cuda:0')
tensor([[-0.2902, 0.1190, -1.0000, -1.0000, 0.2009, -0.2196]],
device='cuda:0')
tensor([[-0.4749, 0.3333, -1.0000, -0.9587, -0.2645, -0.2527]],
device='cuda:0')
tensor([[-0.6631, -0.0469, -1.0000, -1.0000, -0.2829, -0.5303]],
device='cuda:0')
tensor([[-0.6367, -0.5581, -1.0000, -1.0000, -0.1357, -0.4671]],
device='cuda:0')
tensor([[-0.3783, -0.3572, -1.0000, -1.0000, 0.1973, -0.3010]],
device='cuda:0')
tensor([[-0.2696, 0.4408, -1.0000, -0.9750, 0.2921, -0.1835]],
device='cuda:0')
tensor([[-0.5492, 0.3224, -0.9253, -0.9684, -0.3154, -0.2500]],
device='cuda:0')
tensor([[-0.7639, -0.3171, -1.0000, -1.0000, -0.3284, -0.4768]],
device='cuda:0')
tensor([[-0.5821, -0.4768, -1.0000, -1.0000, 0.0843, -0.5470]],
device='cuda:0')
tensor([[-0.3083, -0.0279, -1.0000, -1.0000, 0.1926, -0.1390]],
device='cuda:0')
tensor([[-0.4291, 0.2767, -1.0000, -1.0000, -0.3259, -0.3049]],
device='cuda:0')
tensor([[-0.6361, -0.0413, -1.0000, -1.0000, -0.2966, -0.5591]],
device='cuda:0')
tensor([[-0.6179, -0.5236, -1.0000, -1.0000, -0.1365, -0.4554]],
device='cuda:0')
tensor([[-0.3275, -0.2948, -1.0000, -1.0000, 0.3054, -0.2967]],
device='cuda:0')
tensor([[-0.2655, 0.4535, -1.0000, -0.9648, 0.2096, -0.2116]],
device='cuda:0')
tensor([[-0.5652, 0.2602, -0.9596, -0.9924, -0.3316, -0.3198]],
device='cuda:0')
tensor([[-0.7476, -0.3834, -1.0000, -1.0000, -0.3279, -0.4912]],
device='cuda:0')
tensor([[-0.5431, -0.5963, -1.0000, -1.0000, 0.0269, -0.5696]],
device='cuda:0')
tensor([[-0.2748, 0.1234, -1.0000, -1.0000, 0.2256, -0.1959]],
device='cuda:0')
tensor([[-0.4611, 0.3572, -1.0000, -0.9473, -0.2449, -0.2187]],
device='cuda:0')
tensor([[-0.6591, -0.0246, -1.0000, -1.0000, -0.2828, -0.5342]],
device='cuda:0')
tensor([[-0.6472, -0.5962, -1.0000, -1.0000, -0.1562, -0.4751]],
device='cuda:0')
tensor([[-0.3859, -0.4203, -1.0000, -1.0000, 0.1950, -0.3213]],
device='cuda:0')
tensor([[-0.2657, 0.3407, -1.0000, -1.0000, 0.2066, -0.1920]],
device='cuda:0')
tensor([[-0.5398, 0.2922, -1.0000, -0.9978, -0.3045, -0.2912]],
device='cuda:0')
tensor([[-0.7306, -0.3424, -1.0000, -1.0000, -0.3360, -0.5220]],
device='cuda:0')
tensor([[-0.5604, -0.5428, -1.0000, -1.0000, 0.0462, -0.5391]],
device='cuda:0')
tensor([[-0.2906, 0.0907, -1.0000, -1.0000, 0.2410, -0.1080]],
device='cuda:0')
tensor([[-0.4621, 0.3584, -1.0000, -0.9427, -0.2560, -0.2059]],
device='cuda:0')
tensor([[-0.6644, -0.0311, -1.0000, -1.0000, -0.2771, -0.5240]],
device='cuda:0')
tensor([[-0.6517, -0.5789, -1.0000, -1.0000, -0.1538, -0.4693]],
device='cuda:0')
tensor([[-0.3946, -0.3991, -1.0000, -1.0000, 0.1922, -0.3092]],
device='cuda:0')
tensor([[-0.2782, 0.3520, -1.0000, -1.0000, 0.2070, -0.1833]],
device='cuda:0')
tensor([[-0.5481, 0.2900, -1.0000, -1.0000, -0.3077, -0.2891]],
device='cuda:0')
tensor([[-0.7395, -0.3774, -1.0000, -1.0000, -0.3397, -0.5157]],
device='cuda:0')
tensor([[-0.5567, -0.5436, -1.0000, -1.0000, 0.0379, -0.5314]],
device='cuda:0')
tensor([[-0.2926, 0.1049, -1.0000, -1.0000, 0.2339, -0.1244]],
device='cuda:0')
tensor([[-0.4654, 0.3634, -1.0000, -0.9386, -0.2398, -0.1986]],
device='cuda:0')
tensor([[-0.6675, -0.0369, -1.0000, -1.0000, -0.2794, -0.5204]],
device='cuda:0')
tensor([[-0.6504, -0.5719, -1.0000, -1.0000, -0.1483, -0.4675]],
device='cuda:0')
tensor([[-0.3938, -0.3855, -1.0000, -1.0000, 0.1916, -0.3042]],
device='cuda:0')
tensor([[-0.2793, 0.3625, -1.0000, -1.0000, 0.2130, -0.1822]],
device='cuda:0')
tensor([[-0.5499, 0.2943, -1.0000, -0.9994, -0.3139, -0.2910]],
device='cuda:0')
tensor([[-0.7423, -0.3805, -1.0000, -1.0000, -0.3432, -0.5154]],
device='cuda:0')
tensor([[-0.5568, -0.5373, -1.0000, -1.0000, 0.0367, -0.5292]],
device='cuda:0')
tensor([[-0.2953, 0.1041, -1.0000, -1.0000, 0.2254, -0.1373]],
device='cuda:0')
tensor([[-0.4672, 0.3618, -1.0000, -0.9402, -0.2445, -0.2054]],
device='cuda:0')
tensor([[-0.6678, -0.0358, -1.0000, -1.0000, -0.2803, -0.5203]],
device='cuda:0')
tensor([[-0.6505, -0.5678, -1.0000, -1.0000, -0.1505, -0.4656]],
device='cuda:0')
tensor([[-0.3930, -0.3827, -1.0000, -1.0000, 0.1930, -0.3063]],
device='cuda:0')
tensor([[-0.2771, 0.3661, -1.0000, -1.0000, 0.2189, -0.1827]],
device='cuda:0')
tensor([[-0.5463, 0.3044, -1.0000, -0.9927, -0.3070, -0.2801]],
device='cuda:0')
tensor([[-0.7426, -0.3626, -1.0000, -1.0000, -0.3415, -0.5130]],
device='cuda:0')
tensor([[-0.5619, -0.5399, -1.0000, -1.0000, 0.0359, -0.5342]],
device='cuda:0')
tensor([[-0.2976, 0.0771, -1.0000, -1.0000, 0.2219, -0.1377]],
device='cuda:0')
tensor([[-0.4629, 0.3506, -1.0000, -0.9491, -0.2800, -0.2246]],
device='cuda:0')
tensor([[-0.6612, -0.0211, -1.0000, -1.0000, -0.2711, -0.5232]],
device='cuda:0')
tensor([[-0.6513, -0.5664, -1.0000, -1.0000, -0.1612, -0.4615]],
device='cuda:0')
tensor([[-0.3951, -0.3951, -1.0000, -1.0000, 0.1956, -0.3103]],
device='cuda:0')
tensor([[-0.2754, 0.3532, -1.0000, -1.0000, 0.2141, -0.1829]],
device='cuda:0')
tensor([[-0.5417, 0.3040, -1.0000, -0.9904, -0.2919, -0.2684]],
device='cuda:0')
tensor([[-0.7387, -0.3506, -1.0000, -1.0000, -0.3369, -0.5136]],
device='cuda:0')
tensor([[-0.5653, -0.5507, -1.0000, -1.0000, 0.0385, -0.5376]],
device='cuda:0')
tensor([[-0.2936, 0.0613, -1.0000, -1.0000, 0.2346, -0.1166]],
device='cuda:0')
tensor([[-0.4418, 0.3133, -1.0000, -0.9669, -0.3021, -0.2126]],
device='cuda:0')
tensor([[-0.6621, -0.0634, -1.0000, -1.0000, -0.2752, -0.5259]],
device='cuda:0')
tensor([[-0.6350, -0.5378, -1.0000, -1.0000, -0.1184, -0.4642]],
device='cuda:0')
tensor([[-0.3833, -0.3193, -1.0000, -1.0000, 0.1952, -0.2797]],
device='cuda:0')
tensor([[-0.3014, 0.4589, -1.0000, -0.9797, 0.2424, -0.1756]],
device='cuda:0')
tensor([[-0.5755, 0.2839, -0.9570, -0.9976, -0.3422, -0.2881]],
device='cuda:0')
tensor([[-0.7715, -0.4176, -1.0000, -1.0000, -0.3496, -0.4903]],
device='cuda:0')
tensor([[-0.5632, -0.5735, -1.0000, -1.0000, 0.0093, -0.5447]],
device='cuda:0')
tensor([[-0.3001, 0.0128, -1.0000, -1.0000, 0.1886, -0.2270]],
device='cuda:0')
tensor([[-0.4339, 0.3023, -1.0000, -0.9946, -0.2983, -0.2612]],
device='cuda:0')
tensor([[-0.6425, -0.0399, -1.0000, -1.0000, -0.2798, -0.5502]],
device='cuda:0')
tensor([[-0.6240, -0.5151, -1.0000, -1.0000, -0.1230, -0.4439]],
device='cuda:0')
tensor([[-0.3725, -0.3055, -1.0000, -1.0000, 0.2079, -0.2797]],
device='cuda:0')
tensor([[-0.2917, 0.4563, -1.0000, -0.9742, 0.2352, -0.1819]],
device='cuda:0')
tensor([[-0.5709, 0.2754, -0.9506, -0.9937, -0.3405, -0.2957]],
device='cuda:0')
tensor([[-0.7645, -0.3998, -1.0000, -1.0000, -0.3430, -0.4879]],
device='cuda:0')
tensor([[-0.5576, -0.5941, -1.0000, -1.0000, 0.0084, -0.5602]],
device='cuda:0')
tensor([[-0.2913, 0.0260, -1.0000, -1.0000, 0.1954, -0.2322]],
device='cuda:0')
tensor([[-0.4357, 0.2971, -1.0000, -0.9922, -0.3020, -0.2528]],
device='cuda:0')
tensor([[-0.6450, -0.0518, -1.0000, -1.0000, -0.2816, -0.5486]],
device='cuda:0')
tensor([[-0.6214, -0.5245, -1.0000, -1.0000, -0.1165, -0.4540]],
device='cuda:0')
^Ctensor([[-0.3669, -0.3043, -1.0000, -1.0000, 0.2095, -0.2786]],
device='cuda:0')
tensor([[-0.2912, 0.4540, -1.0000, -0.9777, 0.2268, -0.1859]],
device='cuda:0')
tensor([[-0.5744, 0.2642, -0.9697, -1.0000, -0.3542, -0.3188]],
device='cuda:0')
tensor([[-0.7582, -0.4209, -1.0000, -1.0000, -0.3471, -0.4963]],
device='cuda:0')
tensor([[-0.5463, -0.5699, -1.0000, -1.0000, 0.0181, -0.5497]],
device='cuda:0')
tensor([[-0.2900, 0.1025, -1.0000, -1.0000, 0.1999, -0.2202]],
device='cuda:0')
tensor([[-0.4717, 0.3320, -1.0000, -0.9585, -0.2678, -0.2500]],
device='cuda:0')
tensor([[-0.6606, -0.0421, -1.0000, -1.0000, -0.2811, -0.5312]],
device='cuda:0')
tensor([[-0.6372, -0.5624, -1.0000, -1.0000, -0.1388, -0.4672]],
device='cuda:0')
tensor([[-0.3797, -0.3655, -1.0000, -1.0000, 0.1964, -0.3021]],
device='cuda:0')
tensor([[-0.2674, 0.3957, -1.0000, -1.0000, 0.2492, -0.1826]],
device='cuda:0')
tensor([[-0.5407, 0.3236, -0.9925, -0.9799, -0.3135, -0.2689]],
device='cuda:0')
Can anyone help me figure out how to export a policy and get it running externally from Isaaac Sim? I think this would be a great problem to solve and would help a lot of people.
I’ve tried contacting the repo owner here:
opened 06:57PM - 11 Feb 23 UTC
I am working through the training example for Dofbot reacher, and wanting… to deploy it to a real arm.
I am wondering how I will be able to export the saved .pth to an actual dofbot and run it. What kinds of inputs to the loaded model from the .pth will I need to give it, and what will the output be?
I’m aware that I may be able to use PyTorch to load the model, but I don’t know what kinds of inputs I will need to give it.
In the [Config](https://github.com/j3soon/OmniIsaacGymEnvs-DofbotReacher/blob/0f5fdb7a5687e8f78392f599989a46372b534c23/omniisaacgymenvs/cfg/task/DofbotReacher.yaml) for this task the observation type is set to full. What exactly does the “full” observation look like?
I'm assuming that the full state is like this based on the dofbot_reacher.py code
self.num_obs_dict = {
"full": 29,
# 6: dofbot joints position (action space)
# 6: dofbot joints velocity
# 3: goal position
# 4: goal rotation
# 4: goal relative rotation
# 6: previous action
Can you explain to me what each of these values in the state dictionary are?
