Hi ,
I’m using Jetson NX with L4T 32.4.3. I have created a small partition and I am mounting it in cboot and reading the file contents.The read call succeeds.But I am unable to write to it .The read call is using fs_read_file() call. Similarly I try to write from cboot using fs_write_file() call. But that fails. Also it seems that the write call is not implemented.
if (!handle->mount->api->write)
return ERR_NOT_SUPPORTED;
I get ERR_NOT_SUPPORTED on calling that function.
Also It seems for the ext4 filesystem the write function is not implemented,
static const struct fs_api ext4_api = {
.mount = ext4_mount,
.unmount = ext2_unmount,
.open = ext4_open_file,
.stat = ext2_stat_file,
.read = ext4_read_file,
.close = ext2_close_file,
Is there any other alternative way I could save a state of variable in cboot and get it back in next boot. Please provide some pointers if there are any.
