Hi DividSoto;
the problem compiled error I have solved; but now I meet the new questions;
I run the command “v4l2-compliance -d /dev/video0” on the develop board;
Driver Info:
Driver name : tegra-video
Card type : vi-output-0, tw9992 1-0044
Bus info : platform:vi:0
Driver version: 3.10.96
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 7
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 42, Succeeded: 42, Failed: 0, Warnings: 0
but when I run the command “sudo ./yavta /dev/video0 -c1 -n1 -s720x480 -fUYVY -Fcam.raw”
Device /dev/video0 opened.
Device vi-output-0, tw9992 1-0044' on
platform:vi:0’ (driver ‘tegra-video’) is a video capture (without mplanes) device.
Unable to set format: Invalid argument (22).
my code:
* tw9992_v4l2.c - tw9992 sensor driver
* Copyright (c) 2013-2016, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify it
* under the terms and conditions of the GNU General Public License,
* version 2, as published by the Free Software Foundation.
* This program is distributed in the hope it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <media/camera_common.h>
#include "cam_dev/camera_gpio.h"
#include "tw9992_mode_tbls.h"
#define TW9992_MAX_COARSE_DIFF 6
#define TW9992_GAIN_SHIFT 8
#define TW9992_REAL_GAIN_SHIFT 4
#define TW9992_MIN_GAIN (1 << TW9992_GAIN_SHIFT)
#define TW9992_MAX_GAIN (16 << TW9992_GAIN_SHIFT)
#define TW9992_DEFAULT_GAIN TW9992_MIN_GAIN
#define TW9992_MIN_FRAME_LENGTH (0x0)
#define TW9992_MAX_FRAME_LENGTH (0x7fff)
#define TW9992_MIN_EXPOSURE_COARSE (0x0002)
#define TW9992_MAX_EXPOSURE_COARSE \
(TW9992_MAX_FRAME_LENGTH-TW9992_MAX_COARSE_DIFF)
#define TW9992_DEFAULT_FRAME_LENGTH (0x07C0)
#define TW9992_DEFAULT_EXPOSURE_COARSE \
(TW9992_DEFAULT_FRAME_LENGTH-TW9992_MAX_COARSE_DIFF)
#define TW9992_DEFAULT_WIDTH 720
#define TW9992_DEFAULT_HEIGHT 240
#define TW9992_DEFAULT_CLK_FREQ 24000000
#define TW9992_DEFAULT_MODE TW9992_MODE_720x480
#define TW9992_DEFAULT_DATAFMT V4L2_MBUS_FMT_SRGGB10_1X10
#define TW9992_TABLE_WAIT_MS 0
#define TW9992_TABLE_END 1
#define TW9992_MAX_RETRIES 3
#define tw9992_reg struct reg_8
struct tw9992 {
struct camera_common_power_rail power;
int numctrls;
struct v4l2_ctrl_handler ctrl_handler;
//struct camera_common_eeprom_data eeprom[TW9992_EEPROM_NUM_BLOCKS];
//u8 eeprom_buf[TW9992_EEPROM_SIZE];
struct i2c_client *i2c_client;
struct v4l2_subdev *subdev;
struct media_pad pad;
int reg_offset;
s32 group_hold_prev;
bool group_hold_en;
struct regmap *regmap;
struct camera_common_data *s_data;
struct camera_common_pdata *pdata;
struct v4l2_ctrl *ctrls[];
static struct regmap_config tw9992_regmap_config = {
.reg_bits = 8,
.val_bits = 8,
static const tw9992_reg reg_table[] = {
{0x00, 0x92},
{0x01, 0x00},
{0x02, 0x40},
{0x03, 0x68},
{0x04, 0x00},
{0x05, 0x09},
{0x06, 0x00},
{0x07, 0x02},
{0x08, 0x15},
{0x09, 0xF0},
{0x0A, 0x14},
{0x0B, 0xD0},
{0x0C, 0xCC},
{0x0D, 0x00},
{0x10, 0x00},
{0x11, 0x64},
{0x12, 0x11},
{0x13, 0x80},
{0x14, 0x80},
{0x15, 0x00},
{0x17, 0x80},
{0x18, 0x44},
{0x19, 0x06},
{0x1A, 0x10},
{0x1B, 0x00},
{0x1C, 0x0F},
{0x1D, 0x7F},
{0x1F, 0x00},
{0x20, 0x50},
{0x21, 0x22},
{0x22, 0xF0},
{0x23, 0xD8},
{0x24, 0xBC},
{0x25, 0xB8},
{0x26, 0x44},
{0x27, 0x38},
{0x28, 0x00},
{0x29, 0x00},
{0x2A, 0x78},
{0x2B, 0x44},
{0x2C, 0x30},
{0x2D, 0x14},
{0x2E, 0xA5},
{0x2F, 0xE0},
{0x30, 0x00},
{0x31, 0x10},
{0x32, 0xFF},
{0x33, 0x05},
{0x34, 0x1A},
{0x35, 0x00},
{0x36, 0x5A},
{0x37, 0x18},
{0x38, 0xDD},
{0x39, 0x00},
{0x3A, 0x30},
{0x3B, 0x00},
{0x3C, 0x00},
{0x3D, 0x00},
{0x3F, 0x1A},
{0x40, 0x80},
{0x41, 0x00},
{0x42, 0x00},
{0x48, 0x02},
{0x49, 0x00},
{0x4A, 0x81},
{0x4B, 0x0A},
{0x4C, 0x00},
{0x4D, 0x01},
{0x4E, 0x01},
{0x50, 0x00},
{0x51, 0x17},
{0x52, 0x00},
{0x53, 0x00},
{0x54, 0x06},
{0x55, 0x00},
{0x56, 0x00},
{0x57, 0x00},
{0x58, 0x00},
{0x60, 0x00},
{0x61, 0x00},
{0x62, 0x00},
{0x63, 0x00},
{0x70, 0x01},
{0x71, 0xA5},
{0x72, 0xA0},
{0x73, 0x00},
{0x74, 0xF0},
{0x75, 0x00},
{0x76, 0x17},
{0x77, 0x05},
{0x78, 0x88},
{0x79, 0x06},
{0x7A, 0x28},
{0x7B, 0x46},
{0x7C, 0xB3},
{0x7D, 0x06},
{0x7E, 0x13},
{0x7F, 0x10},
{0x80, 0x05},
{0x81, 0xA0},
{0x82, 0x13},
{0x83, 0x11},
{0x84, 0x02},
{0x85, 0x0E},
{0x86, 0x08},
{0x87, 0x37},
{0x88, 0x00},
{0x89, 0x00},
{0x8A, 0x02},
{0x8B, 0x33},
{0x8C, 0x22},
{0x8D, 0x03},
{0x8E, 0x22},
{0x8F, 0x01},
{0x90, 0x00},
{0x91, 0x0C},
{0x92, 0x00},
{0x93, 0x0E},
{0x94, 0x07},
{0x95, 0xFF},
{0x96, 0x1A},
{0x9B, 0x02},
{0xA0, 0x00},
{0xA1, 0x00},
{0xA2, 0x30},
{0xA3, 0xC0},
{0xA4, 0x00},
{0xC0, 0x06},
{0xC1, 0x20},
static int tw9992_g_volatile_ctrl(struct v4l2_ctrl *ctrl);
static int tw9992_s_ctrl(struct v4l2_ctrl *ctrl);
static void tw9992_update_ctrl_range(struct tw9992 *priv, s32 frame_length);
static const struct v4l2_ctrl_ops tw9992_ctrl_ops = {
.g_volatile_ctrl = tw9992_g_volatile_ctrl,
.s_ctrl = tw9992_s_ctrl,
static struct v4l2_ctrl_config ctrl_config_list[] = {
/* Do not change the name field for the controls! */
.ops = &tw9992_ctrl_ops,
.id = V4L2_CID_GAIN,
.name = "Gain",
.type = V4L2_CTRL_TYPE_INTEGER,
.flags = V4L2_CTRL_FLAG_SLIDER,
.min = TW9992_MIN_GAIN,
.max = TW9992_MAX_GAIN,
.def = TW9992_DEFAULT_GAIN,
.step = 1,
.id = V4L2_CID_FRAME_LENGTH,
.name = "Frame Length",
.min = TW9992_MIN_FRAME_LENGTH,
.max = TW9992_MAX_FRAME_LENGTH,
.def = TW9992_DEFAULT_FRAME_LENGTH,
.step = 1,
.id = V4L2_CID_COARSE_TIME,
.name = "Coarse Time",
.min = TW9992_MIN_EXPOSURE_COARSE,
.max = TW9992_MAX_EXPOSURE_COARSE,
.def = TW9992_DEFAULT_EXPOSURE_COARSE,
.step = 1,
.id = V4L2_CID_COARSE_TIME_SHORT,
.name = "Coarse Time Short",
.step = 1,
.id = V4L2_CID_GROUP_HOLD,
.name = "Group Hold",
.type = V4L2_CTRL_TYPE_INTEGER_MENU,
.min = 0,
.max = ARRAY_SIZE(switch_ctrl_qmenu) - 1,
.menu_skip_mask = 0,
.def = 0,
.qmenu_int = switch_ctrl_qmenu,
.id = V4L2_CID_HDR_EN,
.name = "HDR enable",
.min = 0,
.def = 0,
.id = V4L2_CID_EEPROM_DATA,
.name = "EEPROM Data",
.type = V4L2_CTRL_TYPE_STRING,
.flags = V4L2_CTRL_FLAG_VOLATILE,
.min = 0,
.max = TW9992_EEPROM_STR_SIZE,
.step = 2,
.id = V4L2_CID_OTP_DATA,
.name = "OTP Data",
.flags = V4L2_CTRL_FLAG_READ_ONLY,
.min = 0,
.max = TW9992_OTP_STR_SIZE,
.step = 2,
.id = V4L2_CID_FUSE_ID,
.name = "Fuse ID",
.min = 0,
.max = TW9992_FUSE_ID_STR_SIZE,
.step = 2,
static inline int tw9992_read_reg(struct camera_common_data *s_data,
u16 addr, u8 *val)
struct tw9992 *priv = (struct tw9992 *)s_data->priv;
return regmap_read(priv->regmap, addr, (unsigned int *) val);
static int tw9992_write_reg(struct camera_common_data *s_data, u16 addr, u8 val)
int err;
err = regmap_write(priv->regmap, addr, val);
if (err)
pr_err("%s:i2c write failed, %x = %x\n",
__func__, addr, val);
return err;
static int tw9992_write_regs(struct camera_common_data *s_data)
int i = 0;
int count = sizeof(reg_table)/sizeof(struct reg_8);
for (i = 0; i < count; i++)
tw9992_write_reg(s_data, reg_table[i].addr, reg_table[i].val);
static int tw9992_write_table(struct tw9992 *priv,
const tw9992_reg table[])
return regmap_util_write_table_8(priv->regmap,
table,
NULL, 0,
TW9992_TABLE_WAIT_MS,
TW9992_TABLE_END);
/*static void tw9992_gpio_set(struct tw9992 *priv,
unsigned int gpio, int val)
if (priv->pdata->use_cam_gpio)
cam_gpio_ctrl(priv->i2c_client, gpio, val, 1);
else {
if (gpio_cansleep(gpio))
gpio_set_value_cansleep(gpio, val);
else
gpio_set_value(gpio, val);
static int tw9992_power_on(struct camera_common_data *s_data)
int err = 0;
struct camera_common_power_rail *pw = &priv->power;
dev_dbg(&priv->i2c_client->dev, "%s: power on\n", __func__);
if (priv->pdata && priv->pdata->power_on) {
err = priv->pdata->power_on(pw);
if (err)
pr_err("%s failed.\n", __func__);
else
pw->state = SWITCH_ON;
return err;
/* sleeps calls in the sequence below are for internal device
* signal propagation as specified by sensor vendor */
if (pw->avdd)
err = regulator_enable(pw->avdd);
if (err)
goto tw9992_avdd_fail;
if (pw->iovdd)
err = regulator_enable(pw->iovdd);
if (err)
goto tw9992_iovdd_fail;
usleep_range(1, 2);
//if (pw->pwdn_gpio)
//tw9992_gpio_set(priv, pw->pwdn_gpio, 1);
/* datasheet 2.9: reset requires ~2ms settling time
* a power on reset is generated after core power becomes stable */
usleep_range(2000, 2010);
//if (pw->reset_gpio)
//tw9992_gpio_set(priv, pw->reset_gpio, 1);
/* datasheet fig 2-9: t3 */
usleep_range(1350, 1360);
return 0;
tw9992_iovdd_fail:
regulator_disable(pw->avdd);
tw9992_avdd_fail:
return -ENODEV;
static int tw9992_power_off(struct camera_common_data *s_data)
int err = 0;
dev_dbg(&priv->i2c_client->dev, "%s: power off\n", __func__);
err = priv->pdata->power_off(pw);
if (!err)
pw->state = SWITCH_OFF;
else
return err;
usleep_range(21, 25);
//tw9992_gpio_set(priv, pw->pwdn_gpio, 0);
usleep_range(1, 2);
//tw9992_gpio_set(priv, pw->reset_gpio, 0);
/* datasheet 2.9: reset requires ~2ms settling time*/
if (pw->iovdd)
regulator_disable(pw->iovdd);
if (pw->avdd)
return 0;
static int tw9992_power_put(struct tw9992 *priv)
if (unlikely(!pw))
return -EFAULT;
if (likely(pw->avdd))
regulator_put(pw->avdd);
if (likely(pw->iovdd))
regulator_put(pw->iovdd);
pw->avdd = NULL;
pw->iovdd = NULL;
cam_gpio_deregister(priv->i2c_client, pw->pwdn_gpio);
else {
gpio_free(pw->pwdn_gpio);
gpio_free(pw->reset_gpio);
return 0;
static int tw9992_power_get(struct tw9992 *priv)
struct camera_common_pdata *pdata = priv->pdata;
const char *mclk_name;
const char *parentclk_name;
struct clk *parent;
int err = 0;
mclk_name = priv->pdata->mclk_name ?
priv->pdata->mclk_name : "cam_mclk1";
pw->mclk = devm_clk_get(&priv->i2c_client->dev, mclk_name);
if (IS_ERR(pw->mclk)) {
dev_err(&priv->i2c_client->dev,
"unable to get clock %s\n", mclk_name);
return PTR_ERR(pw->mclk);
parentclk_name = priv->pdata->parentclk_name;
if (parentclk_name) {
parent = devm_clk_get(&priv->i2c_client->dev, parentclk_name);
if (IS_ERR(parent))
"unable to get parent clcok %s",
parentclk_name);
else
clk_set_parent(pw->mclk, parent);
#if 0
/* analog 2.8v */
err |= camera_common_regulator_get(priv->i2c_client,
&pw->avdd, pdata->regulators.avdd);
/* IO 1.8v */
&pw->iovdd, pdata->regulators.iovdd);
#endif
if (!err) {
pw->reset_gpio = pdata->reset_gpio;
pw->pwdn_gpio = pdata->pwdn_gpio;
if (priv->pdata->use_cam_gpio) {
err = cam_gpio_register(priv->i2c_client, pw->pwdn_gpio);
if (err)
"%s ERR can't register cam gpio %u!\n",
__func__, pw->pwdn_gpio);
} else {
gpio_request(pw->pwdn_gpio, "cam_pwdn_gpio");
gpio_request(pw->reset_gpio, "cam_reset_gpio");
return err;
static int tw9992_set_gain(struct tw9992 *priv, s32 val);
static int tw9992_set_frame_length(struct tw9992 *priv, s32 val);
static int tw9992_set_coarse_time(struct tw9992 *priv, s32 val);
static int tw9992_set_coarse_time_short(struct tw9992 *priv, s32 val);
static int tw9992_s_stream(struct v4l2_subdev *sd, int enable)
struct i2c_client *client = v4l2_get_subdevdata(sd);
struct camera_common_data *s_data = to_camera_common_data(client);
struct v4l2_control control;
int err;
dev_dbg(&client->dev, "%s++\n", __func__);
//err = tw9992_write_table(priv, reg_table);
//if (err)
// printk("write reg table err\n");
#if 0
if (!enable) {
tw9992_update_ctrl_range(priv, TW9992_MAX_FRAME_LENGTH);
return tw9992_write_table(priv,
mode_table[TW9992_MODE_STOP_STREAM]);
printk(" ------------- s_data->mode = %d\n",s_data->mode);
err = tw9992_write_table(priv, mode_table[s_data->mode]);
if (err)
goto exit;
/* write list of override regs for the asking frame length,
* coarse integration time, and gain. Failures to write
* overrides are non-fatal */
control.id = V4L2_CID_GAIN;
err = v4l2_g_ctrl(&priv->ctrl_handler, &control);
err |= tw9992_set_gain(priv, control.value);
if (err)
dev_dbg(&client->dev, "%s: warning gain override failed\n",
__func__);
control.id = V4L2_CID_FRAME_LENGTH;
err |= tw9992_set_frame_length(priv, control.value);
if (err)
"%s: warning frame length override failed\n",
__func__);
control.id = V4L2_CID_COARSE_TIME;
err |= tw9992_set_coarse_time(priv, control.value);
if (err)
"%s: warning coarse time override failed\n",
__func__);
control.id = V4L2_CID_COARSE_TIME_SHORT;
err |= tw9992_set_coarse_time_short(priv, control.value);
if (err)
"%s: warning coarse time short override failed\n",
__func__);
err = tw9992_write_table(priv, mode_table[TW9992_MODE_START_STREAM]);
if (err)
goto exit;
if (test_mode)
mode_table[TW9992_MODE_TEST_PATTERN]);
#endif
dev_dbg(&client->dev, "%s--\n", __func__);
return 0;
exit:
dev_dbg(&client->dev, "%s: error setting stream\n", __func__);
return err;
static int tw9992_g_input_status(struct v4l2_subdev *sd, u32 *status)
*status = pw->state == SWITCH_ON;
return 0;
static struct v4l2_subdev_video_ops tw9992_subdev_video_ops = {
.s_stream = tw9992_s_stream,
.s_mbus_fmt = camera_common_s_fmt,
.g_mbus_fmt = camera_common_g_fmt,
.try_mbus_fmt = camera_common_try_fmt,
.enum_mbus_fmt = camera_common_enum_fmt,
.g_mbus_config = camera_common_g_mbus_config,
.g_input_status = tw9992_g_input_status,
.enum_framesizes = camera_common_enum_framesizes,
.enum_frameintervals = camera_common_enum_frameintervals,
static struct v4l2_subdev_core_ops tw9992_subdev_core_ops = {
.s_power = camera_common_s_power,
static int tw9992_get_fmt(struct v4l2_subdev *sd,
struct v4l2_subdev_fh *fh,
struct v4l2_subdev_format *format)
return camera_common_g_fmt(sd, &format->format);
static int tw9992_set_fmt(struct v4l2_subdev *sd,
int ret;
if (format->which == V4L2_SUBDEV_FORMAT_TRY)
ret = camera_common_try_fmt(sd, &format->format);
else
ret = camera_common_s_fmt(sd, &format->format);
return ret;
static struct v4l2_subdev_pad_ops tw9992_subdev_pad_ops = {
.enum_mbus_code = camera_common_enum_mbus_code,
.set_fmt = tw9992_set_fmt,
.get_fmt = tw9992_get_fmt,
static struct v4l2_subdev_ops tw9992_subdev_ops = {
.core = &tw9992_subdev_core_ops,
.video = &tw9992_subdev_video_ops,
.pad = &tw9992_subdev_pad_ops,
static struct of_device_id tw9992_of_match[] = {
{ .compatible = "nvidia,tw9992", },
static struct camera_common_sensor_ops tw9992_common_ops = {
.power_on = tw9992_power_on,
.power_off = tw9992_power_off,
.write_reg = tw9992_write_reg,
.read_reg = tw9992_read_reg,
static int tw9992_set_group_hold(struct tw9992 *priv)
int err;
int gh_prev = switch_ctrl_qmenu[priv->group_hold_prev];
#if 0
if (priv->group_hold_en == true && gh_prev == SWITCH_OFF) {
/* enter group hold */
err = tw9992_write_reg(priv->s_data,
TW9992_GROUP_HOLD_ADDR, 0x01);
if (err)
goto fail;
priv->group_hold_prev = 1;
"%s: enter group hold\n", __func__);
} else if (priv->group_hold_en == false && gh_prev == SWITCH_ON) {
/* leave group hold */
TW9992_GROUP_HOLD_ADDR, 0x11);
if (err)
goto fail;
TW9992_GROUP_HOLD_ADDR, 0x61);
if (err)
goto fail;
priv->group_hold_prev = 0;
"%s: leave group hold\n", __func__);
#endif
return 0;
fail:
"%s: Group hold control error\n", __func__);
return err;
static u16 tw9992_to_real_gain(u32 rep, int shift)
u16 gain;
int gain_int;
int gain_dec;
int min_int = (1 << shift);
#if 0
if (rep < TW9992_MIN_GAIN)
rep = TW9992_MIN_GAIN;
else if (rep > TW9992_MAX_GAIN)
rep = TW9992_MAX_GAIN;
gain_int = (int)(rep >> shift);
gain_dec = (int)(rep & ~(0xffff << shift));
/* derived from formulat gain = (x * 16 + 0.5) */
gain = ((gain_int * min_int + gain_dec) * 32 + min_int) / (2 * min_int);
#endif
return gain;
tw9992_reg reg_list[2];
int err;
u16 gain;
int i;
#if 0
if (!priv->group_hold_prev)
tw9992_set_group_hold(priv);
/* translate value */
gain = tw9992_to_real_gain((u32)val, TW9992_GAIN_SHIFT);
tw9992_get_gain_regs(reg_list, gain);
"%s: gain %04x val: %04x\n", __func__, val, gain);
for (i = 0; i < 2; i++) {
err = tw9992_write_reg(priv->s_data, reg_list[i].addr,
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
"%s: GAIN control error\n", __func__);
return err;
struct v4l2_ctrl *ctrl = NULL;
int ctrl_ids[2] = {V4L2_CID_COARSE_TIME,
V4L2_CID_COARSE_TIME_SHORT};
s32 max, min, def;
int i, j;
#if 0
for (i = 0; i < ARRAY_SIZE(ctrl_ids); i++) {
for (j = 0; j < priv->numctrls; j++) {
if (priv->ctrls[j]->id == ctrl_ids[i]) {
ctrl = priv->ctrls[j];
break;
if (j == priv->numctrls) {
"could not find ctrl %x\n",
ctrl_ids[i]);
continue;
max = frame_length - TW9992_MAX_COARSE_DIFF;
/* clamp the value in case above is negative */
max = clamp_val(max, TW9992_MIN_EXPOSURE_COARSE,
TW9992_MAX_EXPOSURE_COARSE);
min = TW9992_MIN_EXPOSURE_COARSE;
def = clamp_val(TW9992_DEFAULT_EXPOSURE_COARSE, min, max);
if (__v4l2_ctrl_modify_range(ctrl, min, max, 1, def))
"ctrl %x: range update failed\n",
ctrl_ids[i]);
#endif
int err;
u32 frame_length;
int i;
#if 0
frame_length = (u32)val;
tw9992_get_frame_length_regs(reg_list, frame_length);
"%s: val: %d\n", __func__, frame_length);
reg_list[i].val);
if (err)
goto fail;
tw9992_update_ctrl_range(priv, val);
#endif
return 0;
fail:
"%s: FRAME_LENGTH control error\n", __func__);
return err;
tw9992_reg reg_list[3];
int err;
u32 coarse_time;
int i;
#if 0
coarse_time = (u32)val;
tw9992_get_coarse_time_regs(reg_list, coarse_time);
"%s: val: %d\n", __func__, coarse_time);
for (i = 0; i < 3; i++) {
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
"%s: COARSE_TIME control error\n", __func__);
return err;
int err;
struct v4l2_control hdr_control;
int hdr_en;
u32 coarse_time_short;
int i;
#if 0
/* check hdr enable ctrl */
hdr_control.id = V4L2_CID_HDR_EN;
err = camera_common_g_ctrl(priv->s_data, &hdr_control);
if (err < 0) {
"could not find device ctrl.\n");
return err;
hdr_en = switch_ctrl_qmenu[hdr_control.value];
if (hdr_en == SWITCH_OFF)
return 0;
coarse_time_short = (u32)val;
tw9992_get_coarse_time_short_regs(reg_list, coarse_time_short);
"%s: val: %d\n", __func__, coarse_time_short);
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
"%s: COARSE_TIME_SHORT control error\n", __func__);
return err;
#if 0
static int tw9992_eeprom_device_release(struct tw9992 *priv)
int i;
for (i = 0; i < TW9992_EEPROM_NUM_BLOCKS; i++) {
if (priv->eeprom[i].i2c_client != NULL) {
i2c_unregister_device(priv->eeprom[i].i2c_client);
priv->eeprom[i].i2c_client = NULL;
return 0;
static int tw9992_eeprom_device_init(struct tw9992 *priv)
char *dev_name = "eeprom_tw9992";
static struct regmap_config eeprom_regmap_config = {
.reg_bits = 8,
.val_bits = 8,
int i;
int err;
if (!priv->pdata->has_eeprom)
return -EINVAL;
priv->eeprom[i].adap = i2c_get_adapter(
priv->i2c_client->adapter->nr);
memset(&priv->eeprom[i].brd, 0, sizeof(priv->eeprom[i].brd));
strncpy(priv->eeprom[i].brd.type, dev_name,
sizeof(priv->eeprom[i].brd.type));
priv->eeprom[i].brd.addr = TW9992_EEPROM_ADDRESS + i;
priv->eeprom[i].i2c_client = i2c_new_device(
priv->eeprom[i].adap, &priv->eeprom[i].brd);
priv->eeprom[i].regmap = devm_regmap_init_i2c(
priv->eeprom[i].i2c_client, &eeprom_regmap_config);
if (IS_ERR(priv->eeprom[i].regmap)) {
err = PTR_ERR(priv->eeprom[i].regmap);
tw9992_eeprom_device_release(priv);
return err;
return 0;
static int tw9992_read_eeprom(struct tw9992 *priv,
int err, i;
err = regmap_bulk_read(priv->eeprom[i].regmap, 0,
&priv->eeprom_buf[i * TW9992_EEPROM_BLOCK_SIZE],
TW9992_EEPROM_BLOCK_SIZE);
if (err)
return err;
for (i = 0; i < TW9992_EEPROM_SIZE; i++)
sprintf(&ctrl->string[i*2], "%02x",
priv->eeprom_buf[i]);
return 0;
static int tw9992_write_eeprom(struct tw9992 *priv,
char *string)
int err;
int i;
u8 curr[3];
unsigned long data;
for (i = 0; i < TW9992_EEPROM_SIZE; i++) {
curr[0] = string[i*2];
curr[1] = string[i*2+1];
curr[2] = '
- tw9992_v4l2.c - tw9992 sensor driver
- Copyright © 2013-2016, NVIDIA CORPORATION. All rights reserved.
- This program is free software; you can redistribute it and/or modify it
- under the terms and conditions of the GNU General Public License,
- version 2, as published by the Free Software Foundation.
- This program is distributed in the hope it will be useful, but WITHOUT
- ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
- FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
- more details.
- You should have received a copy of the GNU General Public License
- along with this program. If not, see http://www.gnu.org/licenses/.
#include “cam_dev/camera_gpio.h”
#include “tw9992_mode_tbls.h”
struct tw9992 {
int numctrls;
int reg_offset;
bool group_hold_en;
.reg_bits = 8,
.val_bits = 8,
static const tw9992_reg reg_table = {
{0x00, 0x92},
{0x01, 0x00},
{0x02, 0x40},
{0x03, 0x68},
{0x04, 0x00},
{0x05, 0x09},
{0x06, 0x00},
{0x07, 0x02},
{0x08, 0x15},
{0x09, 0xF0},
{0x0A, 0x14},
{0x0B, 0xD0},
{0x0C, 0xCC},
{0x0D, 0x00},
{0x10, 0x00},
{0x11, 0x64},
{0x12, 0x11},
{0x13, 0x80},
{0x14, 0x80},
{0x15, 0x00},
{0x17, 0x80},
{0x18, 0x44},
{0x19, 0x06},
{0x1A, 0x10},
{0x1B, 0x00},
{0x1C, 0x0F},
{0x1D, 0x7F},
{0x1F, 0x00},
{0x20, 0x50},
{0x21, 0x22},
{0x22, 0xF0},
{0x23, 0xD8},
{0x24, 0xBC},
{0x25, 0xB8},
{0x26, 0x44},
{0x27, 0x38},
{0x28, 0x00},
{0x29, 0x00},
{0x2A, 0x78},
{0x2B, 0x44},
{0x2C, 0x30},
{0x2D, 0x14},
{0x2E, 0xA5},
{0x2F, 0xE0},
{0x30, 0x00},
{0x31, 0x10},
{0x32, 0xFF},
{0x33, 0x05},
{0x34, 0x1A},
{0x35, 0x00},
{0x36, 0x5A},
{0x37, 0x18},
{0x38, 0xDD},
{0x39, 0x00},
{0x3A, 0x30},
{0x3B, 0x00},
{0x3C, 0x00},
{0x3D, 0x00},
{0x3F, 0x1A},
{0x40, 0x80},
{0x41, 0x00},
{0x42, 0x00},
{0x48, 0x02},
{0x49, 0x00},
{0x4A, 0x81},
{0x4B, 0x0A},
{0x4C, 0x00},
{0x4D, 0x01},
{0x4E, 0x01},
{0x50, 0x00},
{0x51, 0x17},
{0x52, 0x00},
{0x53, 0x00},
{0x54, 0x06},
{0x55, 0x00},
{0x56, 0x00},
{0x57, 0x00},
{0x58, 0x00},
{0x60, 0x00},
{0x61, 0x00},
{0x62, 0x00},
{0x63, 0x00},
{0x70, 0x01},
{0x71, 0xA5},
{0x72, 0xA0},
{0x73, 0x00},
{0x74, 0xF0},
{0x75, 0x00},
{0x76, 0x17},
{0x77, 0x05},
{0x78, 0x88},
{0x79, 0x06},
{0x7A, 0x28},
{0x7B, 0x46},
{0x7C, 0xB3},
{0x7D, 0x06},
{0x7E, 0x13},
{0x7F, 0x10},
{0x80, 0x05},
{0x81, 0xA0},
{0x82, 0x13},
{0x83, 0x11},
{0x84, 0x02},
{0x85, 0x0E},
{0x86, 0x08},
{0x87, 0x37},
{0x88, 0x00},
{0x89, 0x00},
{0x8A, 0x02},
{0x8B, 0x33},
{0x8C, 0x22},
{0x8D, 0x03},
{0x8E, 0x22},
{0x8F, 0x01},
{0x90, 0x00},
{0x91, 0x0C},
{0x92, 0x00},
{0x93, 0x0E},
{0x94, 0x07},
{0x95, 0xFF},
{0x96, 0x1A},
{0x9B, 0x02},
{0xA0, 0x00},
{0xA1, 0x00},
{0xA2, 0x30},
{0xA3, 0xC0},
{0xA4, 0x00},
{0xC0, 0x06},
{0xC1, 0x20},
static struct v4l2_ctrl_config ctrl_config_list = {
/* Do not change the name field for the controls! /
.name = “Gain”,
.step = 1,
.name = “Frame Length”,
.step = 1,
.name = “Coarse Time”,
.step = 1,
.name = “Coarse Time Short”,
.step = 1,
.name = “Group Hold”,
.min = 0,
.def = 0,
.name = “HDR enable”,
.min = 0,
.def = 0,
.name = “EEPROM Data”,
.min = 0,
.step = 2,
.name = “OTP Data”,
.min = 0,
.step = 2,
.name = “Fuse ID”,
.min = 0,
.step = 2,
u16 addr, u8 *val)
int err;
if (err)
return err;
int i = 0;
const tw9992_reg table)
table,
NULL, 0,
TW9992_TABLE_END);
/*static void tw9992_gpio_set(struct tw9992 priv,
else {
else
int err = 0;
if (err)
else
return err;
if (pw->avdd)
if (err)
if (pw->iovdd)
if (err)
usleep_range(1, 2);
return 0;
tw9992_iovdd_fail:
tw9992_avdd_fail:
pr_err("%s failed.\n", func);
return -ENODEV;
int err = 0;
if (!err)
else
return err;
usleep_range(1, 2);
if (pw->iovdd)
if (pw->avdd)
return 0;
if (unlikely(!pw))
return -EFAULT;
pw->avdd = NULL;
pw->iovdd = NULL;
else {
return 0;
struct clk *parent;
int err = 0;
if (IS_ERR(parent))
parentclk_name);
else
#if 0
/* analog 2.8v /
/ IO 1.8v */
#endif
if (!err) {
if (err)
} else {
return err;
int err;
//if (err)
#if 0
if (!enable) {
if (err)
goto exit;
if (err)
__func__);
if (err)
__func__);
if (err)
__func__);
if (err)
__func__);
if (err)
goto exit;
if (test_mode)
#endif
return 0;
exit:
dev_dbg(&client->dev, “%s: error setting stream\n”, func);
return err;
return 0;
int ret;
else
return ret;
static struct of_device_id tw9992_of_match = {
{ .compatible = “nvidia,tw9992”, },
int err;
#if 0
if (err)
goto fail;
if (err)
goto fail;
if (err)
goto fail;
#endif
return 0;
fail:
“%s: Group hold control error\n”, func);
return err;
u16 gain;
int gain_int;
int gain_dec;
#if 0
#endif
return gain;
int err;
u16 gain;
int i;
#if 0
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
“%s: GAIN control error\n”, func);
return err;
s32 max, min, def;
int i, j;
#if 0
break;
ctrl_ids[i]);
continue;
ctrl_ids[i]);
#endif
int err;
u32 frame_length;
int i;
#if 0
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
“%s: FRAME_LENGTH control error\n”, func);
return err;
int err;
u32 coarse_time;
int i;
#if 0
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
“%s: COARSE_TIME control error\n”, func);
return err;
int err;
int hdr_en;
int i;
#if 0
if (err < 0) {
return err;
return 0;
reg_list[i].val);
if (err)
goto fail;
#endif
return 0;
fail:
“%s: COARSE_TIME_SHORT control error\n”, func);
return err;
#if 0
int i;
return 0;
char *dev_name = “eeprom_tw9992”;
.reg_bits = 8,
.val_bits = 8,
int i;
int err;
return -EINVAL;
return err;
return 0;
int err, i;
if (err)
return err;
return 0;
char *string)
int err;
int i;
u8 curr[3];
unsigned long data;
curr[2] = '\0';
err = kstrtol(curr, 16, &data);
if (err) {
"invalid eeprom string\n");
return -EINVAL;
priv->eeprom_buf[i] = (u8)data;
err = regmap_write(priv->eeprom[i >> 8].regmap,
i & 0xFF, (u8)data);
if (err)
return err;
msleep(20);
return 0;
static int tw9992_read_otp_bank(struct tw9992 *priv,
u8 *buf, int bank, u16 addr, int size)
int err;
usleep_range(10000, 11000);
if (err)
return err;
err = tw9992_write_reg(priv->s_data, TW9992_OTP_BANK_SELECT_ADDR,
0xC0 | bank);
if (err)
return err;
err = tw9992_write_reg(priv->s_data, TW9992_OTP_LOAD_CTRL_ADDR, 0x01);
if (err)
return err;
err = regmap_bulk_read(priv->regmap, addr, buf, size);
if (err)
return err;
if (err)
return err;
return 0;
static int tw9992_otp_setup(struct tw9992 *priv)
int err;
int i;
struct v4l2_ctrl *ctrl;
u8 otp_buf[TW9992_OTP_SIZE];
err = camera_common_s_power(priv->subdev, true);
if (err)
return -ENODEV;
for (i = 0; i < TW9992_OTP_NUM_BANKS; i++) {
err = tw9992_read_otp_bank(priv,
&otp_buf[i * TW9992_OTP_BANK_SIZE],
i,
TW9992_OTP_BANK_START_ADDR,
TW9992_OTP_BANK_SIZE);
if (err)
return -ENODEV;
ctrl = v4l2_ctrl_find(&priv->ctrl_handler, V4L2_CID_OTP_DATA);
if (!ctrl) {
return -EINVAL;
for (i = 0; i < TW9992_OTP_SIZE; i++)
otp_buf[i]);
ctrl->cur.string = ctrl->string;
err = camera_common_s_power(priv->subdev, false);
if (err)
return -ENODEV;
return 0;
static int tw9992_fuse_id_setup(struct tw9992 *priv)
int err;
int i;
u8 fuse_id[TW9992_FUSE_ID_SIZE];
if (err)
return -ENODEV;
&fuse_id[0],
TW9992_FUSE_ID_OTP_BANK,
TW9992_FUSE_ID_OTP_START_ADDR,
TW9992_FUSE_ID_SIZE);
if (err)
return -ENODEV;
ctrl = v4l2_ctrl_find(&priv->ctrl_handler, V4L2_CID_FUSE_ID);
if (!ctrl) {
return -EINVAL;
for (i = 0; i < TW9992_FUSE_ID_SIZE; i++)
fuse_id[i]);
if (err)
return -ENODEV;
return 0;
#endif
container_of(ctrl->handler, struct tw9992, ctrl_handler);
int err = 0;
if (priv->power.state == SWITCH_OFF)
return 0;
/*switch (ctrl->id) {
case V4L2_CID_EEPROM_DATA:
err = tw9992_read_eeprom(priv, ctrl);
if (err)
return err;
break;
default:
pr_err("%s: unknown ctrl id.\n", __func__);
return -EINVAL;
return err;
int err = 0;
return 0;
switch (ctrl->id) {
case V4L2_CID_GAIN:
err = tw9992_set_gain(priv, ctrl->val);
break;
case V4L2_CID_FRAME_LENGTH:
err = tw9992_set_frame_length(priv, ctrl->val);
break;
case V4L2_CID_COARSE_TIME:
err = tw9992_set_coarse_time(priv, ctrl->val);
break;
case V4L2_CID_COARSE_TIME_SHORT:
err = tw9992_set_coarse_time_short(priv, ctrl->val);
break;
case V4L2_CID_GROUP_HOLD:
if (switch_ctrl_qmenu[ctrl->val] == SWITCH_ON) {
priv->group_hold_en = true;
} else {
priv->group_hold_en = false;
err = tw9992_set_group_hold(priv);
break;
/*if (!ctrl->string[0])
break;
err = tw9992_write_eeprom(priv, ctrl->string);
if (err)
return err;*/
break;
case V4L2_CID_HDR_EN:
break;
default:
//pr_err("%s: unknown ctrl id.\n", __func__);
return -EINVAL;
return err;
static int tw9992_ctrls_init(struct tw9992 *priv, bool eeprom_ctrl)
struct i2c_client *client = priv->i2c_client;
struct camera_common_data *common_data = priv->s_data;
int numctrls;
int err;
int i;
numctrls = ARRAY_SIZE(ctrl_config_list);
v4l2_ctrl_handler_init(&priv->ctrl_handler, numctrls);
for (i = 0; i < numctrls; i++) {
/* Skip control 'V4L2_CID_EEPROM_DATA' if eeprom inint err */
/* if (ctrl_config_list[i].id == V4L2_CID_EEPROM_DATA) {
if (!eeprom_ctrl) {
common_data->numctrls -= 1;
continue;
ctrl = v4l2_ctrl_new_custom(&priv->ctrl_handler,
&ctrl_config_list[i], NULL);
if (ctrl == NULL) {
dev_err(&client->dev, "Failed to init %s ctrl\n",
ctrl_config_list[i].name);
continue;
if (ctrl_config_list[i].type == V4L2_CTRL_TYPE_STRING &&
ctrl_config_list[i].flags & V4L2_CTRL_FLAG_READ_ONLY) {
ctrl->string = devm_kzalloc(&client->dev,
ctrl_config_list[i].max + 1, GFP_KERNEL);
if (!ctrl->string)
return -ENOMEM;
priv->ctrls[i] = ctrl;
priv->numctrls = numctrls;
priv->subdev->ctrl_handler = &priv->ctrl_handler;
if (priv->ctrl_handler.error) {
dev_err(&client->dev, "Error %d adding controls\n",
priv->ctrl_handler.error);
err = priv->ctrl_handler.error;
goto error;
err = v4l2_ctrl_handler_setup(&priv->ctrl_handler);
if (err) {
"Error %d setting default controls\n", err);
goto error;
/*err = tw9992_otp_setup(priv);
if (err) {
"Error %d reading otp data\n", err);
goto error;
err = tw9992_fuse_id_setup(priv);
if (err) {
"Error %d reading fuse id data\n", err);
goto error;
return 0;
error:
v4l2_ctrl_handler_free(&priv->ctrl_handler);
return err;
MODULE_DEVICE_TABLE(of, tw9992_of_match);
static struct camera_common_pdata *tw9992_parse_dt(struct i2c_client *client)
struct device_node *node = client->dev.of_node;
struct camera_common_pdata *board_priv_pdata;
const struct of_device_id *match;
int gpio;
int err;
if (!node)
return NULL;
match = of_match_device(tw9992_of_match, &client->dev);
if (!match) {
dev_err(&client->dev, "Failed to find matching dt id\n");
return NULL;
board_priv_pdata = devm_kzalloc(&client->dev,
sizeof(*board_priv_pdata), GFP_KERNEL);
if (!board_priv_pdata)
return NULL;
err = camera_common_parse_clocks(client, board_priv_pdata);
if (err) {
dev_err(&client->dev, "Failed to find clocks\n");
goto error;
gpio = of_get_named_gpio(node, "pwdn-gpios", 0);
if (gpio < 0) {
dev_err(&client->dev, "pwdn gpios not in DT\n");
goto error;
board_priv_pdata->pwdn_gpio = (unsigned int)gpio;
gpio = of_get_named_gpio(node, "reset-gpios", 0);
if (gpio < 0) {
/* reset-gpio is not absoluctly needed */
dev_dbg(&client->dev, "reset gpios not in DT\n");
gpio = 0;
board_priv_pdata->reset_gpio = (unsigned int)gpio;
board_priv_pdata->use_cam_gpio =
of_property_read_bool(node, "cam,use-cam-gpio");
#if 0
err = of_property_read_string(node, “avdd-reg”,
&board_priv_pdata->regulators.avdd);
if (err) {
dev_err(&client->dev, “avdd-reg not in DT\n”);
goto error;
err = of_property_read_string(node, “iovdd-reg”,
&board_priv_pdata->regulators.iovdd);
if (err) {
dev_err(&client->dev, “iovdd-reg not in DT\n”);
goto error;
board_priv_pdata->has_eeprom =
of_property_read_bool(node, "has-eeprom");
#endif
return board_priv_pdata;
error:
devm_kfree(&client->dev, board_priv_pdata);
return NULL;
static int tw9992_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
dev_dbg(&client->dev, "%s:\n", __func__);
return 0;
static const struct v4l2_subdev_internal_ops tw9992_subdev_internal_ops = {
.open = tw9992_open,
static const struct media_entity_operations tw9992_media_ops = {
.link_validate = v4l2_subdev_link_validate,
static int tw9992_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct camera_common_data *common_data;
struct tw9992 *priv;
char debugfs_name[10];
int err;
printk("Detected TW9992 sensor\n");
if (!IS_ENABLED(CONFIG_OF) || !node)
return -EINVAL;
common_data = devm_kzalloc(&client->dev,
sizeof(struct camera_common_data), GFP_KERNEL);
if (!common_data)
return -ENOMEM;
priv = devm_kzalloc(&client->dev,
sizeof(struct tw9992) + sizeof(struct v4l2_ctrl *) *
ARRAY_SIZE(ctrl_config_list),
GFP_KERNEL);
if (!priv)
return -ENOMEM;
printk(" 11111111111111111\n");
priv->regmap = devm_regmap_init_i2c(client, &tw9992_regmap_config);
if (IS_ERR(priv->regmap)) {
"regmap init failed: %ld\n", PTR_ERR(priv->regmap));
return -ENODEV;
printk(" 2222222222222222\n");
priv->pdata = tw9992_parse_dt(client);
if (!priv->pdata) {
dev_err(&client->dev, "unable to get platform data\n");
return -EFAULT;
common_data->ops = &tw9992_common_ops;
common_data->ctrl_handler = &priv->ctrl_handler;
common_data->i2c_client = client;
common_data->frmfmt = tw9992_frmfmt;
common_data->colorfmt = camera_common_find_datafmt(
TW9992_DEFAULT_DATAFMT);
common_data->power = &priv->power;
common_data->ctrls = priv->ctrls;
common_data->priv = (void *)priv;
common_data->numctrls = ARRAY_SIZE(ctrl_config_list);
common_data->numfmts = ARRAY_SIZE(tw9992_frmfmt);
common_data->def_mode = TW9992_DEFAULT_MODE;
common_data->def_width = TW9992_DEFAULT_WIDTH;
common_data->def_height = TW9992_DEFAULT_HEIGHT;
common_data->fmt_width = common_data->def_width;
common_data->fmt_height = common_data->def_height;
common_data->def_clk_freq = TW9992_DEFAULT_CLK_FREQ;
priv->i2c_client = client;
priv->s_data = common_data;
priv->subdev = &common_data->subdev;
priv->subdev->dev = &client->dev;
priv->s_data->dev = &client->dev;
err = tw9992_power_get(priv);
if (err)
return err;
printk(" 333333333333333333\n");
err = camera_common_parse_ports(client, common_data);
if (err) {
dev_err(&client->dev, "Failed to find port info\n");
return err;
//sprintf(debugfs_name, "tw9992_%c", common_data->csi_port + 'a');
//dev_dbg(&client->dev, "%s: name %s\n", __func__, debugfs_name);
//camera_common_create_debugfs(common_data, debugfs_name);
v4l2_i2c_subdev_init(priv->subdev, client, &tw9992_subdev_ops);
/* eeprom interface */
//err = tw9992_eeprom_device_init(priv);
//if (err)
//dev_err(&client->dev,
//"Failed to allocate eeprom reg map: %d\n", err);
if (err)
//tw9992_write_regs(priv->s_data);
err = tw9992_ctrls_init(priv, !err);
if (err)
return err;
printk(" 4444444444444444444\n");
priv->subdev->internal_ops = &tw9992_subdev_internal_ops;
priv->subdev->flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
V4L2_SUBDEV_FL_HAS_EVENTS;
#if defined(CONFIG_MEDIA_CONTROLLER)
priv->pad.flags = MEDIA_PAD_FL_SOURCE;
priv->subdev->entity.type = MEDIA_ENT_T_V4L2_SUBDEV_SENSOR;
priv->subdev->entity.ops = &tw9992_media_ops;
err = media_entity_init(&priv->subdev->entity, 1, &priv->pad, 0);
if (err < 0) {
dev_err(&client->dev, “unable to init media entity\n”);
return err;
#endif
err = v4l2_async_register_subdev(priv->subdev);
if (err)
return err;
dev_dbg(&client->dev, "Detected TW9992 sensor\n");
return 0;
static int tw9992_remove(struct i2c_client *client)
v4l2_async_unregister_subdev(priv->subdev);
media_entity_cleanup(&priv->subdev->entity);
#endif
tw9992_power_put(priv);
camera_common_remove_debugfs(s_data);
return 0;
static const struct i2c_device_id tw9992_id = {
{ “tw9992”, 0 },
MODULE_DEVICE_TABLE(i2c, tw9992_id);
static struct i2c_driver tw9992_i2c_driver = {
.driver = {
.name = “tw9992”,
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(tw9992_of_match),
.probe = tw9992_probe,
.remove = tw9992_remove,
.id_table = tw9992_id,
module_i2c_driver(tw9992_i2c_driver);
MODULE_DESCRIPTION(“SoC Camera driver for TW9992”);
MODULE_AUTHOR(“David Wang davidw@nvidia.com”);
MODULE_LICENSE(“GPL v2”);
if (err) {
return -EINVAL;
if (err)
return err;
msleep(20);
return 0;
int err;
if (err)
return err;
0xC0 | bank);
if (err)
return err;
if (err)
return err;
if (err)
return err;
if (err)
return err;
return 0;
int err;
int i;
if (err)
return -ENODEV;
i,
if (err)
return -ENODEV;
if (!ctrl) {
return -EINVAL;
otp_buf[i]);
if (err)
return -ENODEV;
return 0;
int err;
int i;
if (err)
return -ENODEV;
&fuse_id[0],
if (err)
return -ENODEV;
if (!ctrl) {
return -EINVAL;
fuse_id[i]);
if (err)
return -ENODEV;
return 0;
#endif
int err = 0;
return 0;
if (err)
return err;
break;
default:
return -EINVAL;
return err;
int err = 0;
return 0;
switch (ctrl->id) {
case V4L2_CID_GAIN:
break;
break;
break;
break;
} else {
break;
break;
if (err)
return err;*/
break;
break;
default:
return -EINVAL;
return err;
int numctrls;
int err;
int i;
if (!eeprom_ctrl) {
continue;
if (ctrl == NULL) {
continue;
if (!ctrl->string)
return -ENOMEM;
goto error;
if (err) {
goto error;
if (err) {
goto error;
if (err) {
goto error;
return 0;
error:
return err;
int gpio;
int err;
if (!node)
return NULL;
if (!match) {
return NULL;
return NULL;
if (err) {
goto error;
if (gpio < 0) {
goto error;
if (gpio < 0) {
gpio = 0;
#if 0
err = of_property_read_string(node, "avdd-reg",
if (err) {
dev_err(&client->dev, "avdd-reg not in DT\n");
goto error;
err = of_property_read_string(node, "iovdd-reg",
if (err) {
dev_err(&client->dev, "iovdd-reg not in DT\n");
goto error;
#endif
error:
return NULL;
return 0;
int err;
return -EINVAL;
if (!common_data)
return -ENOMEM;
GFP_KERNEL);
if (!priv)
return -ENOMEM;
return -ENODEV;
if (!priv->pdata) {
return -EFAULT;
if (err)
return err;
if (err) {
return err;
//if (err)
if (err)
if (err)
return err;
if (err < 0) {
dev_err(&client->dev, "unable to init media entity\n");
return err;
#endif
if (err)
return err;
return 0;
#endif
return 0;
static const struct i2c_device_id tw9992_id[] = {
{ "tw9992", 0 },
.driver = {
.name = "tw9992",
MODULE_DESCRIPTION("SoC Camera driver for TW9992");
MODULE_AUTHOR("David Wang <davidw@nvidia.com>");
MODULE_LICENSE("GPL v2");
my device tree:
* Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* more details.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#define GANG_MODE_L_R 1
#define GANG_MODE_T_B 2
#define GANG_MODE_R_L 3
#define GANG_MODE_B_T 4
#define CAM0_RST_L TEGRA_GPIO(E, 5)
#define CAM_MUX0 TEGRA_GPIO(T, 1)
#define CAM_MUX1 TEGRA_GPIO(S, 6)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
//GPIOs
/* set camera gpio direction to output */
gpio: gpio@6000d000 {
camera-control {
gpio-output-low = <
CAM0_RST_L
CAM_MUX0
CAM_MUX1
CAM0_PWDN
host1x {
vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
tw9992_vi_in0: endpoint {
status = "okay";
csi-port = <0>;
bus-width = <1>;
remote-endpoint = <&tw9992_out0>;
i2c@7000c400 {
status = "okay";
#size-cells = <0>;
tw9992_a@44 {
compatible = "nvidia,tw9992";
/* I2C device address */
reg = <0x44>;
reset-gpios = <&gpio CAM0_RST_L GPIO_ACTIVE_LOW>;
pwdn-gpios = <&gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
/* Sensor Model */
sensor_model ="tw9992";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
//avdd-reg = "vana";
//iovdd-reg = "vif";
//dvdd-reg = "vdig";
clocks = <&tegra_car TEGRA210_CLK_ID_CLK_OUT_3>;
clock-names = "mclk";
clock-frequency = <24000000>;
mclk = "cam_mclk1";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_multiplier
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* mclk_multiplier = "";
* Multiplier to MCLK to help time hardware capture sequence
* TODO: Assign to PLL_Multiplier as well until fixed in core
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 { // TW9992_MODE_720X480
mclk_khz = "24000";
num_lanes = "1";
//mclk_multiplier = "49.0";
//My Stuff
//pix_clk_hz = "1176000000";
//pix_clk_hz = "588000000";
//line_length = "2416";
//Their Stuff
mclk_multiplier = "3.0";
pix_clk_hz = "27000000";
line_length = "760";
//Done
discontinuous_clk = "yes";
cil_settletime = "0";
pixel_t = "bayer_bggr";
inherent_gain = "1";
active_w = "720";
active_h = "480";
min_gain_val = "1.0";
max_gain_val = "16.0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "1";
max_framerate = "30";
min_exp_time = "25";
max_exp_time = "683709";
/*mode1 { // TW9992_MODE_1280X720
mclk_khz = "24000";
num_lanes = "1";
mclk_multiplier = "52.5";
pix_clk_hz = "1260000000";
active_w = "720";
active_h = "480";
//line_length = "2623";
line_length = "1896";
max_framerate = "60";
min_exp_time = "22";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
tw9992_out0: endpoint {
csi-port = <0>;
bus-width = <1>;
remote-endpoint = <&tw9992_vi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
cam_module0: module0 {
badge = "uav_back_tw9992";
position = "rear";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver's v4l2 device name */
devname = "tw9992 1-0044";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@7000c400/tw9992_a@44";
status = "okay";
cam_module0_dirvernode1: drivernode1 {
status = "disabled";
pcl_id = "v4l2_focuser_stub";
proc-device-tree = "";
the hardware we designed don’t need to consider the power control. when power on the devlop board, the tw9992 reset automatically.
As the front input is CVBS signal;
In the probe function “common_data->colorfmt = camera_common_find_datafmt(V4L2_MBUS_FMT_SRGGB10_1X10)”, is it correct?
can you help me check the code? thanks a lot!!
