Continuing the discussion from Mipi-driver : frame start syncpt timeout!0:
Are there other means to update the default timeout in run-time?
For example, by writing file descriptors under /sys or through the module driver code itself? (using ov5693 for instance).
We suspect that with the current timeout of 2500ms, the device stream is unable to respond during the power-up sequence.
Thanks,
Moti.
