So I have a 3D texture. I’ve used it to perform a 3D gaussian, and now I need to do a 3D sobel filter.
The given sdk example is quite obscured compared to the sobel theory. I’d implement naively but having X,Y, and Z temporaries (3 times that if I separate the convolutions), wouldn’t fit in device memory, so I need something efficient.
Example 3D sobel kernels are here
http://www.aravind.ca/cs788h_Final_Project…mators.htm#idsb
Essentially I want to take these two routines from the sobel sdk example and make them perform a 3D sobel using tex3D, and the like
__device__ unsigned char
ComputeSobel(unsigned char ul, // upper left
unsigned char um, // upper middle
unsigned char ur, // upper right
unsigned char ml, // middle left
unsigned char mm, // middle (unused)
unsigned char mr, // middle right
unsigned char ll, // lower left
unsigned char lm, // lower middle
unsigned char lr, // lower right
float fScale )
short Horz = ur + 2*mr + lr - ul - 2*ml - ll;
short Vert = ul + 2*um + ur - ll - 2*lm - lr;
short Sum = (short) (fScale*(abs(Horz)+abs(Vert)));
if ( Sum < 0 ) return 0; else if ( Sum > 0xff ) return 0xff;
return (unsigned char) Sum;
__global__ void
SobelTex( Pixel *pSobelOriginal, unsigned int Pitch,
int w, int h, float fScale )
unsigned char *pSobel =
(unsigned char *) (((char *) pSobelOriginal)+blockIdx.x*Pitch);
for ( int i = threadIdx.x; i < w; i += blockDim.x ) {
unsigned char pix00 = tex2D( tex, (float) i-1, (float) blockIdx.x-1 );
unsigned char pix01 = tex2D( tex, (float) i+0, (float) blockIdx.x-1 );
unsigned char pix02 = tex2D( tex, (float) i+1, (float) blockIdx.x-1 );
unsigned char pix10 = tex2D( tex, (float) i-1, (float) blockIdx.x+0 );
unsigned char pix11 = tex2D( tex, (float) i+0, (float) blockIdx.x+0 );
unsigned char pix12 = tex2D( tex, (float) i+1, (float) blockIdx.x+0 );
unsigned char pix20 = tex2D( tex, (float) i-1, (float) blockIdx.x+1 );
unsigned char pix21 = tex2D( tex, (float) i+0, (float) blockIdx.x+1 );
unsigned char pix22 = tex2D( tex, (float) i+1, (float) blockIdx.x+1 );
pSobel[i] = ComputeSobel(pix00, pix01, pix02,
pix10, pix11, pix12,
pix20, pix21, pix22, fScale );
