Extensions update available not updating/crashing
Hi
Had issues with the measure tool failing to load, checked the extensions and notice that and quite a few others had updates available including the measure tool.
Theres about 30+ extensions that have update available, going through updating one by one, some just dont update or crash composer.
Has something messed up here? On USD Composer beta 2023.2.2
Thanks for the post. Firstly you do not have to update them all. It is not required but you can. Only if you are having an issue with a certain extension. So going back to the measure tool, did you get that working ?
ok thanks. Yes measure tool fixed by deactivating the extension and then re-enabling it.
Good thanks.
