Hi Guys,
I try to use sth like extern float shared sdata;
but if I assign memory larger than 64 I get
Signal name : |
CUDA_EXCEPTION_5 |
Signal meaning : |
Warp Out-of-range Address |
does anyone have idea how to use extern shared correctly? Thanks in advance
A common error is to forget to provide the necessary allocation at kernel launch time:
my_kernel<<<grid,block,size_of_shared_memory_in_bytes>>>(...);
this example shows proper/improper usage of extern __shared__
memory.
Thanks Robert, thats what I exactly did. However I got this warp out of range error. Have you ever had this problem?
Nope. Not with properly designed code. Maybe the warp out of range problem is due to something else (some other issue in your code, unrelated to shared memory). Or maybe you made some other mistake.
