I have seen in many CUDA programs using shared memory “extern” is used even when the kernel and the main is in the same .cu file. Like:
extern shared float temp;// allocated on invocation
when “extern” is not written I get error. Why is it so ?
Also is it necessary to specify the amount of shared memory in kernel call in main?
Can anyone please clarify my doubts here?
When the size of a kernel’s shared memory is dynamically allocated upon launch, it’s necessary to declare the shared array as extern [1].
Statically allocated shared variables should not be declared with extern. For example:
[codebox]
global void foo(…)
// no need for extern here
shared int shared_array[10];
int main(void)
// no need to specify the size of shared memory here
foo<<<1,1>>>(…);
[/codebox]
[1] http://developer.download.nvidia.com/compu…g_Guide_2.3.pdf section B.2.3
