We would like to connect external Zibee chip and LTE M1/NB-IOT module to Jetson TX2.
Do you have suggested interface (pins) on Jetson TX2 for these external Zibee chip and LTE NB-IOT module? Thank you
It depends on the supported interface on your external module. TX2 supports many kinds of interface such as USB, PCIe, SDIO etc., you can check the OEM DG first in download center. [url]http://developer.nvidia.com/embedded/dlc/jetson-tx2-oem-product-design-guide[/url]
HI @Pei-lan_yeh , are you able to connect LTE M1 module to jetson TX2? Which module you used specifications?
