External EEPROM is not detected
And i have flashed linux kernel version 4.9 (L4T 32.4.4) Ubuntu 18.04 , in my Jetson NX SOM module custom carrier board.
Here,
Internal EEPROM is connected to SoM via Bus I2C2 at address 0x57.
Connected External EEPROM to my carrier board by I2C0 of 40 pin header.
But even if i connect External EEPROM or not the i2cdetect result remains the same.
What can i do so that External EEPROM starts detecting and i can read and write from it.
output of i2cdetect in bus 0,1,2,and 3 is attached below.
hello vinay2010singh,
please refer to NVIDIA Jetson Xavier NX GPIO Header Pinout - JetsonHacks,
did you connect with pin-3/pin-5 for I2C bus 8, or, you should use pin-27/pin-28 for I2C bus 1.
