I am using AT24C02C EEPROM in my custom made carrier board. It is connected to i2c0 bus at 0x55.
Xavier NX is the SOM board used.
Driver file used is sources/kernel/kernel-4.9/drivers/misc/eeprom/at24.c.
Also made following changes in sources/kernel/kernel-4.9/arch/arm64/configs/tegra_defconfig
CONFIG_EEPROM_AT24=m
CONFIG_I2C=y
CONFIG_SYSFS=y
In Linux_for_Tegra/sources/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3668-common.dtsi
i2c@3160000 {
eeprom@55 {
compatible = “24c04”;
reg = <0x55>;
status = “okay”;
In dmesg got ;
"[ 18.287430] at24_probe:606- Inside Probe function
[ 18.287439] AT24 Magic = 8201
[ 18.288571] at24 0-0055: 512 byte 24c04 EEPROM, writable, 1 bytes/write
But I didn’t find a EEPROM node in board for reading and writing into it.
Can you please help on it?
hello user14225,
please have a try to dump the values after you probe the kernel module,
i.e. $ sudo i2cdump -f -y 0 0x55
