On Windows, I have only one option to choose: YCbCr422. I don’t have RGB or YCbCr420.
Nothing happened when I set on Linux Option “ForceYUV420” “true”
I seem to be having the same issue, I’m wondering now if it’s caused by early KMS. Do you happen to be using early KMS aswell?
This is also happening to me on Ubuntu 21.04 / KDE Plasma 5.22.5 / KDE Frameworks Version 5.86.0 / X11.
I’ve got a GeForce RTX 2080 Mobile and a single external monitor, an LG Ultra. I dual boot with windows 10 and can run just fine at 60hz at 3840x2160.
My issue is maybe slightly different, in that KDE TELLS ME I’m running at 60hz, but I’m most definitely not. When I run a game, I’m at 60hz, but generally I’m at ~23hz it seems.
It’s worth mentioning that before I upgraded to Ubuntu 21.04 from 20.04, I was able to run at 3840x2160 @ 60hz for real. But now, no.
The mode is plainly available in xrandr results.
xrandr output is at the end (sorry, new users can’t put links)…
`sudo nvidia-bug-report.sh’ results here:
nvidia-bug-report.log.gz (314.2 KB)
This info must exist in the report, but just in case, here is a scree shot of my Software & Updates → Additional Drivers:
Hope I’m barking up the right tree here!
Thank you very much.
➜ ~ xrandr
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
eDP-1 connected (normal left inverted right x axis y axis)
1920x1080 144.00 + 60.01 59.97 59.96 59.93
1680x1050 84.94 74.89 69.88 59.95 59.88
1600x1024 60.17
1400x1050 85.00 74.76 70.00 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 85.02 75.02 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 100.00 85.06 85.00 75.00 75.00 70.00 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 85.02 74.96 69.88 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 85.08 74.76 70.06 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
720x450 59.89
700x450 59.96 59.88
640x480 85.09 60.00 85.01 72.81 75.00 59.94
720x405 59.51 58.99
720x400 85.04
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98 85.08
576x432 100.11 85.15 85.09 75.00 75.00 70.00 60.06
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
3840x2160 60.00*+ 59.94 50.00 30.00 29.97 25.00 23.98
2560x1440 59.95
1920x1080 60.00 60.00 59.94 29.97 23.98
1600x900 60.00
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94
1152x864 60.00
1024x768 60.00
800x600 60.32
720x480 59.94
640x480 59.94 59.93
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
1280x1024 (0x5b) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x800 (0x69) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1152x864 (0x71) 81.620MHz -HSync +VSync
h: width 1152 start 1216 end 1336 total 1520 skew 0 clock 53.70KHz
v: height 864 start 865 end 868 total 895 clock 60.00Hz
1024x768 (0x7c) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x98) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0xb3) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
@amrits is there additional data I can provide for you since I’m experiencing a similar/the same(?) issue? My monitor was working fine in Windows at 4k@60hz (although I had to manually add the mode), but my monitor in Linux runs at 4k@<=30hz but SAYS it’s at 60hz.
It’s driving me nuts so if there’s anything you can do to help I’d appreciate it a lot.
Thank you.
I’d appreciate it if you could keep the conversation here, or at least update here, for visibility. Thank you.
This video solved my problem:
My system was rendering using my AMD GPU rather than my NVidia card. Problem solved!
Or at least, I thought it did, but I had changed 2 things. I had also set my ‘nvidia-settings’ → PRIME Profiles → Select the GPU you would like to use → ‘NVIDIA (Performance Mode)’ and this fixed it for real.
I spent so much time on this. I hope someone else will find it useful.
We have been able to root caused the issue, fix will be incorporated in future release driver.
Shall inform once it is publicly released.
Please verify it with driver 530.30.02 and share test results.
https://in.download.nvidia.com/XFree86/Linux-x86_64/530.30.02/NVIDIA-Linux-x86_64-530.30.02.run
Hello @amrits,
I installed version 530.30.02, and now I have to choose 60Hz. It appears that everything is working fine.
Here is the report.
nvidia-bug-report.log.gz (1018.7 KB)
Thank you!
Thanks for sharing the test results, I will archive the bug internally.
Hi @amrits
I noticed that when I switch from Windows to Linux, the problematic monitor shows a black screen and only a frozen cursor is visible.
Then, I must completely shut down the PC and boot Linux, after which it works. If I only restart, it does not work, only a complete shutdown works.
