External RTC YSN8025TS not recognized on Jetson AGX ORIN (R36.4.4)
Platform:
  • Jetson AGX ORIN 64G
  • JetPack version: 6.2.1 (R36.4.4)
  • RTC chip: YSN8025TS (compatible with EPSON RX8025)
  • I2C bus: I2C7 (address 0x32)
Issue Description:
I am trying to add an external RTC (YSN8025TS) to my Jetson AGX ORIN via I2C7. The device is detected on the I2C bus and I can read data from it, but the RTC device does not appear in /sys/class/rtc/.
  1. I2C detection works - the device is visible at address 0x32,I2C register dump works - I can read data from the chip:
fk@tegra-ubuntu:~$ sudo i2cdetect -r -y 7
[sudo] password for fk:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- 32 -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
fk@tegra-ubuntu:~$ sudo i2cdump -f -y 7 0x32
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 11 23 17 7f 18 06 26 61 1d 37 00 00 a0 00 23 40    ?#????&a?7..?.#@
10: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
20: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
30: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
40: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
50: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
60: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
70: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
80: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
90: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
a0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
b0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
c0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
d0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
e0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
f0: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX    XXXXXXXXXXXXXXXX
What I have done:
  1. Created a device tree overlay:
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/tegra234-gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
    overlay-name = "Jetson RTC ysn8025ts";
    jetson-header-name = "Jetson AGX rtc Connector";
    compatible = "nvidia,p3737-0000", "nvidia,p3701-0000", "nvidia,tegra234";
    fragment@0 {
        target-path = "/bus@0/i2c@c250000";
        __overlay__ {
            status = "okay";
            #address-cells = <1>;
            #size-cells = <0>;
            ysn8025ts: rtc@32 {
                compatible = "epson,rx8025", "yxc,ysn8025ts";
                reg = <0x32>;
                status = "okay";
2Applied the overlay using fdtoverlay:
fk@tegra-ubuntu:~$ sudo fdtoverlay -i /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv-back.dtb -o /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb ./tegra234-p3737-camera-fr_fpa_4a_agx-overlay.dtbo -v
input  = /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv-back.dtb
output = /boot/dtb/kernel_tegra234-p3737-0000+p3701-0005-nv.dtb
overlay[0] = ./tegra234-p3737-camera-fr_fpa_4a_agx-overlay.dtbo
3Verified the merged DTB contains the node:
        bus@0 {
        i2c@c250000 {
            compatible = "nvidia,tegra194-i2c";
            reg = <0x00 0xc250000 0x00 0x100>;
            interrupts = <0x00 0x20 0x04>;
            #address-cells = <0x01>;
            #size-cells = <0x00>;
            status = "okay";
            clock-frequency = <0x61a80>;
            clocks = <0x03 0x36 0x03 0x66>;
            clock-names = "div-clk\0parent";
            assigned-clocks = <0x03 0x36>;
            assigned-clock-parents = <0x03 0x66>;
            resets = <0x03 0x22>;
            reset-names = "i2c";
            dmas = <0xee 0x00 0xee 0x00>;
            dma-names = "rx\0tx";
            nvidia,hw-instance-id = <0x07>;
            iommus = <0x04 0x04>;
            dma-coherent;
            phandle = <0x243>;
            rtc@32 {
                phandle = <0x37d>;
                status = "okay";
                reg = <0x32>;
                compatible = "epson,rx8025\0yxc,ysn8025ts";
__symbols__ {
        ysn8025ts = "/bus@0/i2c@c250000/rtc@32";
The problem:
The RTC node does not appear under /sys/firmware/devicetree/base/:
fk@tegra-ubuntu:~$ ls /sys/firmware/devicetree/base/bus@0/i2c@c250000/
'#address-cells'          clock-frequency   compatible     dmas         name                    prod-settings   resets
 assigned-clock-parents   clock-names       dma-coherent   interrupts   nvidia,hw-instance-id   reg            '#size-cells'
 assigned-clocks          clocks            dma-names      iommus       phandle                 reset-names     status
fk@tegra-ubuntu:~$
The rtc@32 node is missing in the live device tree, even though it exists in the DTB file.
Additionally, /sys/class/rtc/ does not show the new RTC device.
Questions:
  1. Why is the device tree node not being recognized by the kernel even though it exists in the merged DTB?
  2. Is there any additional driver configuration or kernel config required for the RX8025/YSN8025TS RTC?
  3. Is the epson,rx8025 compatible string fully supported in JetPack 6.2.1 (R36.4.4)?
  4. Does the YSN8025TS require additional properties (e.g., interrupts, clock, wakeup-source) to be properly probed?
Request:
Could you please help me understand why the RTC node is not being instantiated and how to fix this issue? Any guidance on debugging this further would be greatly appreciated.
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
I could not find clear support for that in the provided Jetson AGX Orin documentation.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
~0722
How do you apply the modify dtb to the system? Modify the extlinux.conf to add FDT?
