I have two Xavier NX development kit which would like to connect with imx477 camera, I prepared a SD card with JP4.6.2 (L4T 32.7.2) and use the JetsonIO to config the settings, also applied the ArduCAM driver.
$uname -a
Linux esdt-nx 4.9.253-tegra #1 SMP PREEMPT Sat Feb 19 08:58:27 PST 2022 aarch64 aarch64 aarch64 GNU/Linux
I was able to find the camera in /dev on one of the NX development kit, but another development kit is not success.
Finally, I check up the debug message from UART and shows:
rootfs path: /sd/boot/extlinux/extlinux.conf
ext4_read_data_from_extent:298: Total file read should not be larger than file stat size
file /sd/boot/extlinux/extlinux.conf read failed!!
Is there some way I can work this around to fix the issue?
extlinux.conf (1.2 KB)
nx_load_fail.log (88.7 KB)
nx_load_success.log (29.8 KB)
