Hello
i wanted to check/edit the content of /boot/extlinux/extlinux.conf
but the data is not readable
device: xavier-nx emmc + nvme
secure boot enabled
disk encryption enabled
flashing steps
sudo ROOTFS_ENC=1 BOARDID=3668 BOARDSKU=0001 FAB=300 BOARDREV=B.0 \
./tools/kernel_flash/l4t_initrd_flash.sh --no-flash \
-u $XKEYS/rsa_priv.pem -v $XKEYS/SBK --user_key $XKEYS/usr_flash.key \
-p "-i $XKEYS/ekb.key --user_key $XKEYS/usr_flash.key" \
jetson-xavier-nx-devkit-qspi internal
--external-device nvme0n1p1 -S 220GiB \
-c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml \
--external-only --append jetson-xavier-nx-devkit-emmc external
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only
Hi HusamAlqaza,
Are you using the devkit or custom board for AGX Xavier?
Could you provide your /boot/extlinux/extlinux.conf
for further check?
Please also share the result of the following command on your board.
$ cat /etc/nv_boot_control.conf
$ cat /etc/nv_tegra_release
Hello @KevinFFF
sorry the device is xavier nx not AGX
and yes we are using a custom carrier board from forecr https://www.forecr.io/
sure i will attach the /boot/extlinux/extlinux.conf
file (changed the name to .log to be able to upload it )
extlinux.con.log (880 Bytes)
nvidia@nvidia:~$ cat /etc/nv_boot_control.conf
TNSPEC 3668-301-0003-B.0-1-2-jetson-xavier-nx-devkit-emmc-internal
COMPATIBLE_SPEC 3668-301---1--jetson-xavier-nx-devkit-emmc-
TEGRA_CHIPID 0x19
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
nvidia@nvidia:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/crypt_root 216G 52G 153G 26% /
/dev/mapper/crypt_UDA 301M 2.1M 279M 1% /mnt/crypt_UDA
none 7.4G 0 7.4G 0% /dev
tmpfs 7.8G 20K 7.8G 1% /dev/shm
tmpfs 7.8G 26M 7.7G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.8G 0 7.8G 0% /sys/fs/cgroup
/dev/nvme0n1p1 380M 91M 265M 26% /boot
tmpfs 1.6G 16K 1.6G 1% /run/user/120
tmpfs 1.6G 0 1.6G 0% /run/user/1000
nvidia@nvidia:~$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t186ref, EABI: aarch64, DATE: Sat Feb 19 17:07:00 UTC 2022
nvidia@nvidia:~$
Do you have custom layout change for the rootfs?
Could your <Linux_for_Tegra>/rootfs/boot/extlinux/extlinux.conf
from your host be readable?
what do you mean by custom layout ?
yes is readable
➜ Linux_for_Tegra cat rootfs/boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
# sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
# MENU LABEL backup kernel
# LINUX /boot/Image.backup
# INITRD /boot/initrd
# APPEND ${cbootargs}
partition layout change (i.e. the XML used to flash the board)
ah yes, we changed the num_sectors
<device type="nvme" instance="0" sector_size="512" num_sectors="488397168">
Isn’t extlinux.conf encrypted on the bootpartition when using Secureboot + Disk encryption?
On my encrypted Jetson AGX I also can’t read the contents of it.
Yes, it seems the expected result when you enable Secureboot and Disk Encryption.
