Extlinux.conf not being applied
Device: Nvidia Jetson Nano Developer Kit
Model: P3450
Problem:
I want to edit the kernel cmdline to use cgroup v1 instead of v2:
admin@jetson:~$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} systemd.unified_cgroup_hierarchy=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
#    MENU LABEL backup kernel
#    LINUX /boot/Image.backup
#    INITRD /boot/initrd
#    APPEND ${cbootargs}
admin@jetson:~$ cat /sys/fs/cgroup/cgroup.controllers
io memory pids
as shown above, after adding systemd.unified_cgroup_hierarchy=0, it doesn’t change cgroup version from v2 to v1 indicated by the existence of the file /sys/fs/cgroup/cgroup.controllers. Below is the log of dmesg:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5496-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jun 11 16:07:05 PDT 2024
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[    0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 systemd.unified_cgroup_hierarchy=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29688(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3568248K/4159488K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 116104K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 15488 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  6784 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  8640 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  2983 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001737] Console: colour dummy device 80x25
[    0.001747] console [tty0] enabled
[    0.001753] bootconsole [uart8250] disabled
[    0.001772] kmemleak: Kernel memory leak detector disabled
[    0.001791] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001803] pid_max: default: 32768 minimum: 301
[    0.002279] Security Framework initialized
[    0.002520] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002527] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003635] ftrace: allocating 47298 entries in 185 pages
[    0.180573] sched-energy: CPU device node has no sched-energy-costs
[    0.192255] ASID allocator initialised with 65536 entries
[    0.219839] tegra-id: chipid=22117.
[    0.219853] tegra-id: opt_subrevision=0.
[    0.219870] Tegra Speedo/IDDQ fuse revision 4
[    0.219875] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.219879] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[    0.219885] Tegra: CPU Speedo Value 1989, SoC Speedo Value 1907, GPU Speedo Value 2001
[    0.219889] Tegra: CPU IDDQ Value 1548, SoC IDDQ Value 1992, GPU IDDQ Value 2290
[    0.219917] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[    0.219931] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.219939] DTB Build time: Jun 11 2024 16:09:23
[    0.269070] CPU1: Booted secondary processor [411fd071]
[    0.300954] CPU2: Booted secondary processor [411fd071]
[    0.332944] CPU3: Booted secondary processor [411fd071]
[    0.333043] Brought up 4 CPUs
[    0.333050] SMP: Total of 4 processors activated.
[    0.333058] CPU features: detected feature: 32-bit EL0 Support
[    0.333297] CPU: All CPU(s) started at EL2
[    0.333315] alternatives: patching kernel code
[    0.341382] devtmpfs: initialized
[    0.379357] Initilizing CustomIPI irq domain
[    0.379669] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.379690] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.391695] pinctrl core: initialized pinctrl subsystem
[    0.392282] OS set in device tree is not L4T.
[    0.392709] regulator-dummy: no parameters
[    0.392976] Initializing plugin-manager
[    0.393179] Plugin module not found
[    0.393374] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[    0.393880] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[    0.394850] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.395052] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.395670] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[    0.399403] NET: Registered protocol family 16
[    0.400797] pstore: using zlib compression
[    0.400839] console [pstore-1] enabled
[    0.400844] pstore: Registered ramoops as persistent store backend
[    0.400849] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.417090] cpuidle: using governor menu
[    0.421246] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.422913] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.422934] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.425581] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.427918] Serial: AMBA PL011 UART driver
[    0.428416] tegra_powergate_init: DONE
[    0.428431] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.428438] DTB Build time: Jun 11 2024 16:09:23
[    0.430377] Tegra reboot handler registered.
[    0.434889] iommu: Adding device tegra-carveouts to group 0
[    0.435026] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.435375] iommu: Adding device smmu_test to group 1
[    0.435421] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.436228] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.436279] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.436331] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.436340] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.436363] mc-err: mcerr ops are set to t21x
[    0.447031] iommu: Adding device 70090000.xusb to group 2
[    0.447311] iommu: Adding device 70006000.serial to group 3
[    0.447375] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.447798] iommu: Adding device 70006040.serial to group 4
[    0.448054] iommu: Adding device 70006200.serial to group 5
[    0.448240] iommu: Adding device sound to group 6
[    0.448286] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.448849] iommu: Adding device 7000d400.spi to group 7
[    0.449161] iommu: Adding device 7000d600.spi to group 8
[    0.449435] iommu: Adding device 70410000.spi to group 9
[    0.449734] iommu: Adding device 50000000.host1x to group 10
[    0.449996] iommu: Adding device 54080000.vi to group 11
[    0.450396] iommu: Adding device 54600000.isp to group 12
[    0.450652] iommu: Adding device 54680000.isp to group 13
[    0.450916] iommu: Adding device tegradc.0 to group 14
[    0.450968] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.451480] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.451799] iommu: Adding device tegradc.1 to group 15
[    0.451866] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.452370] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.452617] iommu: Adding device 54340000.vic to group 16
[    0.452815] iommu: Adding device 544c0000.nvenc to group 17
[    0.453007] iommu: Adding device 54500000.tsec to group 18
[    0.453239] iommu: Adding device 54100000.tsecb to group 19
[    0.453441] iommu: Adding device 54480000.nvdec to group 20
[    0.453629] iommu: Adding device 54380000.nvjpg to group 21
[    0.454657] iommu: Adding device 546c0000.i2c to group 22
[    0.454980] iommu: Adding device 57000000.gpu to group 23
[    0.455050] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.455087] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.455124] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.455156] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.456004] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.456014] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.456026] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.456032] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.456037] tegra-pmc: ### PMC reset status reg: 0x3
[    0.509266] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.509278] tegra-pmc: Clear bootloader IO dpd settings
[    0.509299] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.509366] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.509664] iommu: Adding device 70012000.se to group 24
[    0.510232] iommu: Adding device 1003000.pcie to group 25
[    0.510291] platform 1003000.pcie: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.510803] iommu: Adding device 7000c000.i2c to group 26
[    0.511115] iommu: Adding device 7000c400.i2c to group 27
[    0.511425] iommu: Adding device 7000c500.i2c to group 28
[    0.511729] iommu: Adding device 7000c700.i2c to group 29
[    0.512082] iommu: Adding device 7000d000.i2c to group 30
[    0.512397] iommu: Adding device 7000d100.i2c to group 31
[    0.512687] iommu: Adding device sdhci-tegra.0 to group 32
[    0.512737] platform sdhci-tegra.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.513808] iommu: Adding device 700d0000.xudc to group 33
[    0.518042] vdd-ac-bat: 5000 mV
[    0.518506] vdd-5v0-sys: 5000 mV
[    0.519420] vdd-5v0-hdmi: 5000 mV
[    0.519896] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.520204] vdd-1v8-sys: 1800 mV
[    0.520688] vdd-fan: 5000 mV
[    0.520999] vdd-fan: supplied by vdd-5v0-sys
[    0.521279] vdd-usb-vbus: 5000 mV
[    0.521498] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.521890] vdd-usb-vbus2: 5000 mV
[    0.550111] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.552394] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.555394] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.555426] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.555446] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.555879] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.564014] eventlib_kernel: keventlib is initialized, test id: 0
[    0.564361] SCSI subsystem initialized
[    0.564553] libata version 3.00 loaded.
[    0.564840] usbcore: registered new interface driver usbfs
[    0.564898] usbcore: registered new interface driver hub
[    0.564939] usbcore: registered new device driver usb
[    0.569158] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.573084] vdd-core: 600 <--> 1162 mV at 1125 mV
[    0.574045] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.576975] vdd-ddr-1v1: 1150 mV
[    0.580969] vdd-pre-reg-1v35: 1350 mV
[    0.584292] vdd-1v8: 1800 mV
[    0.588228] avdd-sys-1v2: 1200 mV
[    0.592228] vdd-pex-1v0: 1050 mV
[    0.592888] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.593429] max77620-ldo3: at 3100 mV
[    0.596229] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.596777] max77620-ldo5: at 3100 mV
[    0.600231] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.604223] avdd-1v05-pll: 1050 mV
[    0.608230] avdd-io-hdmi-dp: 1050 mV
[    0.610766] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.611077] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.611371] max77620 4-003c: max77620 probe successful
[    0.614137] media: Linux media interface: v0.10
[    0.614193] Linux video capture interface: v2.00
[    0.615117] pps_core: LinuxPPS API ver. 1 registered
[    0.615123] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.615142] PTP clock support registered
[    0.618212] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.619058] Advanced Linux Sound Architecture Driver Initialized.
[    0.619659] Bluetooth: Core ver 2.22
[    0.619703] NET: Registered protocol family 31
[    0.619707] Bluetooth: HCI device and connection manager initialized
[    0.619721] Bluetooth: HCI socket layer initialized
[    0.619729] Bluetooth: L2CAP socket layer initialized
[    0.619759] Bluetooth: SCO socket layer initialized
[    0.621552] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.621569] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.621616] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.621630] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.624910] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.626196] vdd-3v3-sys: 3300 mV
[    0.626551] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.626600] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.629361] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.629791] vdd-3v3-sd: 3300 mV
[    0.630179] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.630721] avdd-io-edp-1v05: 1050 mV
[    0.631086] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.631219] vdd-usb-hub-en: 5000 mV
[    0.631578] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.632592] camchar: rtcpu character device driver loaded
[    0.633311] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.634725] clocksource: Switched to clocksource arch_sys_counter
[    0.674566] VFS: Disk quotas dquot_6.6.0
[    0.674695] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.675330] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.675764] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.675783]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.675995] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.676002] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.676017] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.676047] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.676053] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.676073] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.676081] nvmap_page_pool_init: Total RAM pages: 1010846
[    0.676085] nvmap_page_pool_init: nvmap page pool size: 126355 pages (493 MB)
[    0.676180] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.676611] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.677317] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.687123] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.687554] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.687906] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.688164] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.688342] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.688602] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.688608] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.689073] NET: Registered protocol family 2
[    0.689224] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.707003] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.707222] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.707726] TCP: Hash tables configured (established 32768 bind 32768)
[    0.707880] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.707960] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.708374] NET: Registered protocol family 1
[    0.709087] RPC: Registered named UNIX socket transport module.
[    0.709092] RPC: Registered udp transport module.
[    0.709095] RPC: Registered tcp transport module.
[    0.709099] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.709114] PCI: CLS 0 bytes, default 64
[    0.709360] Trying to unpack rootfs image as initramfs...
[    1.016994] Freeing initrd memory: 6992K
[    1.026969] host1x 50000000.host1x: initialized
[    1.028854] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.032131] audit: initializing netlink subsys (disabled)
[    1.032220] audit: type=2000 audit(0.875:1): initialized
[    1.032918] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.042814] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.044286] ntfs: driver 2.1.32 [Flags: R/W].
[    1.045084] 9p: Installing v9fs 9p2000 file system support
[    1.048294] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.048412] io scheduler noop registered
[    1.048724] io scheduler cfq registered (default)
[    1.051592] gic 702f9000.agic: GIC IRQ controller registered
[    1.054547] iommu: Adding device 702ef000.adsp to group 34
[    1.063809] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[    1.063992] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    1.064656] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x71a7c0e
[    1.064663] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.066306] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.066412] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.066505] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.066693] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.066826] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.066922] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.067011] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.067102] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.067185] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.067278] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.073594] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    1.075281] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    1.077149] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.078430] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.078811] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.080069] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.080282] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.080545] Adding domain tsec-pd to PM domain host1x-pd
[    1.082879] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.083777] tsec 54500000.tsec: initialized
[    1.085322] tsec 54100000.tsecb: initialized
[    1.086031] Adding domain nvdec-pd to PM domain host1x-pd
[    1.089510] nvdec 54480000.nvdec: initialized
[    1.090568] Adding domain vic03-pd to PM domain host1x-pd
[    1.090771] Adding domain msenc-pd to PM domain host1x-pd
[    1.090948] Adding domain nvjpg-pd to PM domain host1x-pd
[    1.094955] falcon 54340000.vic: initialized
[    1.096223] falcon 544c0000.nvenc: initialized
[    1.097599] falcon 54380000.nvjpg: initialized
[    1.102145] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    1.102193] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.102231] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.102348] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.102438] display board info: id 0x0, fab 0x0
[    1.102496] generic_infoframe_type: 0x87
[    1.102506] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.102510] tegra_cec 70015000.tegra_cec: probed
[    1.102640] tegradc tegradc.0: DT parsed successfully
[    1.102699] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    1.110302] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.115338] tegradc tegradc.0: probed
[    1.115735] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.116080] Console: switching to colour frame buffer device 80x30
[    1.116113] tegradc tegradc.0: fb registered
[    1.116820] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.116830] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.117479] kfuse 7000fc00.kfuse: initialized
[    1.117537] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    1.117642] tegradc tegradc.1: No lt-data, using default setting
[    1.117675] tegradc tegradc.1: No hpd-gpio in DT
[    1.117726] tegradc tegradc.1: DT parsed successfully
[    1.117777] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[    1.118826] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.119480] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.119778] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.120843] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.120853] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.121241] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.122445] vdd-gpu: applied init 1000000uV constraint
[    1.122452] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.625252] Host read timeout at address 545c00c4
[    1.625303] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.627092] tegradc tegradc.1: probed
[    1.627438] tegradc tegradc.1: fb registered
[    1.629437] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.629531] No Device Node present for smmu client: serial8250 !!
[    1.629541] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.629580] iommu: Adding device serial8250 to group 36
[    1.630668] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.630675] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.630684] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.630700] tegradc tegradc.1: blank - powerdown
[    1.631011] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[    1.631017] Extcon DP: HPD disabled
[    1.631022] hpd: hpd_switch 0
[    1.631028] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.631042] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.631050] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.632190] console [ttyS0] disabled
[    1.632248] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.642659] console [ttyS0] enabled
[    1.643752] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.644061] serial-tegra 70006200.serial: RX in PIO mode
[    1.644158] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.645136] [drm] Initialized
[    1.655524] brd: module loaded
[    1.660751] loop: module loaded
[    1.660839] tegra_profiler: version: 1.145, samples/io: 49/28
[    1.660960] tegra_profiler: auth: init
[    1.662360] THERMAL EST: found 2 subdevs
[    1.662369] THERMAL EST num_resources: 0
[    1.662376] [THERMAL EST subdev 0]
[    1.662384] [THERMAL EST subdev 1]
[    1.662898] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.662903] THERMAL EST: thz register success.
[    1.663085] THERMAL EST: end of probe, return err: 0
[    1.664427] sd: No Scsi addr parsed to reserve index
[    1.664466] hisi_sas: driver version v1.6
[    1.669434] tegra-qspi 70410000.spi: Prod settings list not found
[    1.670593] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[    1.670602] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[    1.674263] tun: Universal TUN/TAP device driver, 1.6
[    1.674269] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.675603] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.675607] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.675658] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.675661] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.675712] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.675716] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.675767] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    1.675771] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.676907] PPP generic driver version 2.4.2
[    1.677116] PPP BSD Compression module registered
[    1.677122] PPP Deflate Compression module registered
[    1.677164] PPP MPPE Compression module registered
[    1.677171] NET: Registered protocol family 24
[    1.677245] usbcore: registered new interface driver r8152
[    1.677291] usbcore: registered new interface driver asix
[    1.677344] usbcore: registered new interface driver ax88179_178a
[    1.677384] usbcore: registered new interface driver cdc_ether
[    1.677421] usbcore: registered new interface driver net1080
[    1.677461] usbcore: registered new interface driver cdc_subset
[    1.677497] usbcore: registered new interface driver zaurus
[    1.677564] usbcore: registered new interface driver cdc_ncm
[    1.677744] VFIO - User Level meta-driver version: 0.3
[    1.679294] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.679320] ehci-pci: EHCI PCI platform driver
[    1.679365] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.679377] ohci-pci: OHCI PCI platform driver
[    1.679418] ohci-platform: OHCI generic platform driver
[    1.682192] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.683226] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.684445] tegra-xusb 70090000.xusb: extcon 0:         (ptrval) id
[    1.685835] usbcore: registered new interface driver uas
[    1.685916] usbcore: registered new interface driver usb-storage
[    1.686071] usbcore: registered new interface driver usbserial
[    1.688661] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[    1.688728] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.688759] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.689546] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.689594] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.689802] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.689810] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.689814] usb usb1: Product: xHCI Host Controller
[    1.689819] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.689823] usb usb1: SerialNumber: 70090000.xusb
[    1.690051] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.690512] hub 1-0:1.0: USB hub found
[    1.690557] hub 1-0:1.0: 5 ports detected
[    1.691428] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.691440] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.691546] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.691653] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.691659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.691664] usb usb2: Product: xHCI Host Controller
[    1.691668] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.691672] usb usb2: SerialNumber: 70090000.xusb
[    1.692024] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.692042] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    1.692057] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    1.692086] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    1.692113] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    1.692224] hub 2-0:1.0: USB hub found
[    1.692259] hub 2-0:1.0: 4 ports detected
[    1.692858] mousedev: PS/2 mouse device common for all mice
[    1.692977] usbcore: registered new interface driver xpad
[    1.693156] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    1.693162] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    1.718811] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    1.824155] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.826832] rtc rtc1: alarm rtc device
[    1.826854] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.826890] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.827608] i2c /dev entries driver
[    1.829767] i2c i2c-6: Added multiplexed i2c bus 7
[    1.830273] i2c i2c-6: Added multiplexed i2c bus 8
[    1.830281] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[    1.831296] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    1.854641] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.854755] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.862374] imx219 7-0010: board setup failed
[    1.866839] imx219: probe of 7-0010 failed with error -121
[    1.867433] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    1.890727] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.890816] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.898384] imx219 8-0010: board setup failed
[    1.902832] imx219: probe of 8-0010 failed with error -121
[    1.904181] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.907099] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.907106] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.907569] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.907589] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.907599] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.907730] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.907741] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.907748] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.907893] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.907904] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.907911] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.908085] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.908911] tegra_aotag tegra-aotag: Registering sensor 0
[    1.908969] tegra_aotag tegra-aotag: Invalid temp readout
[    1.908995] tegra_aotag tegra-aotag: Invalid temp readout
[    1.909013] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.909023] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.909966] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.909989] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.910178] tegra_aotag tegra-aotag: Invalid temp readout
[    1.910207] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.910633] parse_throttle_dt_data: Num cap clks = 6
[    1.910640] parse_throttle_dt_data: clk=cclk_g type=2
[    1.910656] parse_throttle_dt_data: clk=gpu type=4
[    1.910686] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.910735] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.910761] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.910766] parse_throttle_dt_data: clk=emc type=3
[    1.911226] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.911376] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.911572] tegra_throttle_probe: probe successful. #cdevs=4
[    1.912532] FAN dev name: pwm-fan
[    1.912610] FAN:gpio request success.
[    1.912673] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.913068] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.913258] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.913269] pwm_fan_driver pwm-fan: tach period: 1000
[    1.913373] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.913379] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.913385] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.913390] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.913395] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.913400] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.913405] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.913410] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.913415] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.913420] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.916508] device-mapper: uevent: version 1.0.3
[    1.917080] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.922484] tegra210-cpufreq cpufreq: probe()...completed
[    1.923235] sdhci: Secure Digital Host Controller Interface driver
[    1.923237] sdhci: Copyright(c) Pierre Ossman
[    1.923239] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.923730] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    1.924086] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    1.924214] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[    1.928495] tegra-se 70012000.se: tegra_se_probe: complete
[    1.929045] hidraw: raw HID events driver (C) Jiri Kosina
[    1.930100] usbcore: registered new interface driver usbhid
[    1.930102] usbhid: USB HID core driver
[    1.932382] ashmem: initialized
[    1.933305] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.933531] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.935868] nvpmodel: initialized successfully
[    1.937189] usbcore: registered new interface driver snd-usb-audio
[    1.937247] No Device Node present for smmu client: snd-soc-dummy !!
[    1.937252] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.937272] iommu: Adding device snd-soc-dummy to group 37
[    1.942695] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.942806] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.950386] OPE platform probe
[    1.950474] OPE platform probe successful
[    1.950500] OPE platform probe
[    1.950575] OPE platform probe successful
[    1.970953] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    1.972278] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    1.972282] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.972285] usb 1-2: Product: 4-Port USB 2.1 Hub
[    1.972288] usb 1-2: Manufacturer: Generic
[    1.973238] hub 1-2:1.0: USB hub found
[    1.973861] hub 1-2:1.0: 4 ports detected
[    1.975745] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.975877] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.976014] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.976142] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.976272] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.976402] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.976531] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.976677] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.976809] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.976940] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.989209] u32 classifier
[    1.989211]     Actions configured
[    1.989283] Initializing XFRM netlink socket
[    1.990112] NET: Registered protocol family 10
[    1.990874] NET: Registered protocol family 17
[    1.990886] NET: Registered protocol family 15
[    1.990970] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.991067] Bluetooth: RFCOMM socket layer initialized
[    1.991077] Bluetooth: RFCOMM ver 1.11
[    1.991081] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.991086] Bluetooth: HIDP socket layer initialized
[    1.991103] 9pnet: Installing 9P2000 support
[    1.991151] Key type dns_resolver registered
[    1.991569] Registered cp15_barrier emulation handler
[    1.991576] Registered setend emulation handler
[    1.992604] registered taskstats version 1
[    1.993151] Adding domain ve2-pd to PM domain host1x-pd
[    1.993400] Adding domain ve-pd to PM domain host1x-pd
[    1.995568] isp 54600000.isp: initialized
[    1.996587] isp 54680000.isp: initialized
[    2.007069] last reset is due to software reset
[    2.007073] KERNEL: PMC reset status reg: 0x3
[    2.007132] BL: PMC reset status reg: 0x3
[    2.007134] BL: PMIC poweroff Event Recorder: 0x0
[    2.008582] clk_cbus_recalc_rate: no gbus parent
[    2.008588] clk_cbus_round_rate: no gbus parent
[    2.008590] clk_cbus_round_rate: no gbus parent
[    2.008598] clk_cbus_recalc_rate: no gbus parent
[    2.008700] clk_cbus_recalc_rate: no gbus parent
[    2.008704] clk_cbus_round_rate: no gbus parent
[    2.008706] clk_cbus_round_rate: no gbus parent
[    2.008709] clk_cbus_recalc_rate: no gbus parent
[    2.009384] tegra_dvfs: GPU-cap: registered
[    2.009438] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    2.009441] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[    2.009443] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[    2.010839] tegra_dvfs: vdd-gpu-vts: registered
[    2.011534] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    2.012137] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    2.012627] input: gpio-keys as /devices/gpio-keys/input/input1
[    2.018243] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.044908] tegra_rtc 7000e000.rtc: setting system clock to 2024-08-14 08:41:31 UTC (1723624891)
[    2.045914] vi 54080000.vi: vi_probe: ++
[    2.067412] vi 54080000.vi: initialized
[    2.073838] vi 54080000.vi: subdev nvcsi--2 bound
[    2.073946] vi 54080000.vi: subdev nvcsi--1 bound
[    2.075450] Disable partitions left on by BL
[    2.075454]   disb
[    2.075503] bwmgr: missing cdev-type property
[    2.075594] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.075600] DRAM derating cdev registered.
[    2.076469] ALSA device list:
[    2.076472]   #0: tegra-hda at 0x70038000 irq 83
[    2.076475]   #1: tegra-snd-t210ref-mobile-rt565x
[    2.079865] Freeing unused kernel memory: 8640K
[    2.087232] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    2.106798] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.106802] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.106862] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[    2.113606] Root device found: mmcblk0p1
[    2.121014] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    2.121019] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.121022] usb 2-1: Product: 4-Port USB 3.1 Hub
[    2.121025] usb 2-1: Manufacturer: Generic
[    2.126299] hub 2-1:1.0: USB hub found
[    2.127323] hub 2-1:1.0: 4 ports detected
[    2.130730] usb 1-2: usb_suspend_both: status 0
[    2.169296] mmc0: hw tuning done ...
[    2.169332] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[    2.169711] mmcblk0: mmc0:59b4       232 GiB
[    2.172843]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    2.198937] usb usb1: usb_suspend_both: status 0
[    2.290792] usb 2-1: usb_suspend_both: status 0
[    2.290908] usb usb2: usb_suspend_both: status 0
[    2.318876] Found dev node: /dev/mmcblk0p1
[    2.364686] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    2.366523] Rootfs mounted over mmcblk0p1
[    2.383315] Switching from initrd to actual rootfs
[    2.423817] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.593238] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.604561] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[    2.613527] cgroup: cgroup2: unknown option "nsdelegate"
[    2.644972] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[    2.840967] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.843040] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.947550] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.947556] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.947559] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.947562] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.947566] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.947585] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.947649] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.947773] iommu: Adding device 0000:00:02.0 to group 38
[    2.947840] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.947945] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.947971] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.948004] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.948027] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.948187] pci 0000:01:00.0: supports D1 D2
[    2.948190] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.948338] iommu: Adding device 0000:01:00.0 to group 39
[    2.958852] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.958879] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    2.958882] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.958888] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[    2.958906] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[    2.958923] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.958931] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.958934] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.958939] pci 0000:00:02.0:   bridge window [mem 0x13000000-0x130fffff]
[    2.959200] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.959203] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.959208] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.959288] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.959469] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.959486] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.974303] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.974365] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:3d:4e:28 from device tree
[    2.974824] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.974837] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    3.106367] random: systemd: uninitialized urandom read (16 bytes read)
[    3.109720] random: systemd: uninitialized urandom read (16 bytes read)
[    3.112014] random: systemd: uninitialized urandom read (16 bytes read)
[    3.163747] fuse init (API version 7.26)
[    3.202925] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    3.411973] systemd-journald[1938]: Received client request to flush runtime journal.
[    3.962795] tegra-xusb 70090000.xusb: entering ELPG
[    3.963816] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[    3.963994] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[    3.964876] tegra-xusb 70090000.xusb: entering ELPG done
[    4.069118] proc: unrecognized mount option "hidepid=invisible" or missing value
[    4.119504] random: systemd: uninitialized urandom read (16 bytes read)
[    4.127264] random: systemd: uninitialized urandom read (16 bytes read)
[    4.136396] random: systemd: uninitialized urandom read (16 bytes read)
[    4.197149] proc: unrecognized mount option "hidepid=invisible" or missing value
[    4.351531] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.351554] cpu-throttle-alert cooling device registered.
[    4.351674] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.351689] gpu-throttle-alert cooling device registered.
[    4.351829] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.351842] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.351855] hot-surface-alert cooling device registered.
[    4.412845] proc: unrecognized mount option "hidepid=invisible" or missing value
[    4.429584] eth0: 0xffffff800ab8f000, 48:b0:2d:3d:4e:28, IRQ 407
[    4.470741] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    4.504923] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.124791] random: ln: uninitialized urandom read (6 bytes read)
[    5.137900] random: ln: uninitialized urandom read (6 bytes read)
[    5.147323] random: ln: uninitialized urandom read (6 bytes read)
[    7.578736] r8168: eth0: link up
[    7.578759] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    7.888466] random: systemd: uninitialized urandom read (16 bytes read)
[    8.036230] zram: Added device: zram0
[    8.036581] zram: Added device: zram1
[    8.039189] zram: Added device: zram2
[    8.039534] zram: Added device: zram3
[    8.056100] zram0: detected capacity change from 0 to 519557120
[    8.128948] proc: unrecognized mount option "hidepid=invisible" or missing value
[    8.778735] random: crng init done
[    8.782144] random: 371 urandom warning(s) missed due to ratelimiting
[    8.885643] Adding 507376k swap on /dev/zram0.  Priority:5 extents:1 across:507376k SS
[    8.888399] zram1: detected capacity change from 0 to 519557120
[    8.898658] Adding 507376k swap on /dev/zram1.  Priority:5 extents:1 across:507376k SS
[    8.901502] zram2: detected capacity change from 0 to 519557120
[    8.914326] Adding 507376k swap on /dev/zram2.  Priority:5 extents:1 across:507376k SS
[    8.917112] zram3: detected capacity change from 0 to 519557120
[    8.928870] Adding 507376k swap on /dev/zram3.  Priority:5 extents:1 across:507376k SS
[   11.392315] NFS: bad mount option value specified: minorversion=1
[   13.548701] Bridge firewalling registered
[   13.586232] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   13.656635] Netfilter messages via NETLINK v0.30.
[   13.771938] ctnetlink v0.93: registering with nfnetlink.
[   13.859739] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   13.934627] IPv6: ADDRCONF(NETDEV_UP): docker_gwbridge: link is not ready
[   14.865433] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[   14.873732] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[   14.924768] br0: renamed from ov-001000-wg425
[   14.975478] vxlan0: renamed from vx-001000-wg425
[   14.995487] br0: port 1(vxlan0) entered blocking state
[   14.995492] br0: port 1(vxlan0) entered disabled state
[   14.995620] device vxlan0 entered promiscuous mode
[   14.995931] br0: port 1(vxlan0) entered blocking state
[   14.995935] br0: port 1(vxlan0) entered forwarding state
[   15.039643] veth0: renamed from vethb1d9990
[   15.055584] br0: port 2(veth0) entered blocking state
[   15.055588] br0: port 2(veth0) entered disabled state
[   15.055710] device veth0 entered promiscuous mode
[   15.055893] br0: port 2(veth0) entered blocking state
[   15.055897] br0: port 2(veth0) entered forwarding state
[   15.166097] eth0: renamed from veth2733190
[   15.194567] docker_gwbridge: port 1(vethaf6f749) entered blocking state
[   15.194572] docker_gwbridge: port 1(vethaf6f749) entered disabled state
[   15.194693] device vethaf6f749 entered promiscuous mode
[   15.194983] IPv6: ADDRCONF(NETDEV_UP): vethaf6f749: link is not ready
[   15.194988] docker_gwbridge: port 1(vethaf6f749) entered blocking state
[   15.194991] docker_gwbridge: port 1(vethaf6f749) entered forwarding state
[   15.195099] docker_gwbridge: port 1(vethaf6f749) entered disabled state
[   15.235552] eth1: renamed from veth0f89123
[   15.260472] IPv6: ADDRCONF(NETDEV_CHANGE): vethaf6f749: link becomes ready
[   15.260542] docker_gwbridge: port 1(vethaf6f749) entered blocking state
[   15.260546] docker_gwbridge: port 1(vethaf6f749) entered forwarding state
[   15.260633] IPv6: ADDRCONF(NETDEV_CHANGE): docker_gwbridge: link becomes ready
[   15.315409] IPVS: Registered protocols (TCP, UDP)
[   15.316343] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[   15.316406] IPVS: Creating netns size=1928 id=0
[   15.316444] IPVS: Creating netns size=1928 id=1
[   15.316480] IPVS: Creating netns size=1928 id=2
[   15.316515] IPVS: Creating netns size=1928 id=3
[   15.316554] IPVS: ipvs loaded.
[   15.417554] IPVS: [rr] scheduler registered.
[   33.917409] vdd-fan: disabling
[   33.917455] vdd-usb-vbus: disabling
[   33.917487] vdd-usb-vbus2: disabling
[   33.917597] vddio-sdmmc3-ap: disabling
[   33.918300] avdd-io-edp-1v05: disabling
[   33.918332] vdd-usb-hub-en: disabling
There’s one line that says “Kernel command line:”, and it shows systemd.unified_cgroup_hierarchy=0 is feeded in.
Hope someone can guide the path, thanks.
If you remove “quiet” in extlinux.conf, will you see that quiet is gone in your dmesg?
Yes, it’s gone.
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 systemd.unified_cgroup_hierarchy=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[    0.000000] early log buf free: 29696(90%)
[    0.009999] Console: colour dummy device 80x25
[    0.014639] console [tty0] enabled
[    0.018151] bootconsole [uart8250] disabled
[    0.022476] kmemleak: Kernel memory leak detector disabled
[    0.022504] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.022525] pid_max: default: 32768 minimum: 301
[    0.023010] Security Framework initialized
[    0.023261] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.023274] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.024400] ftrace: allocating 47298 entries in 185 pages
[    0.200854] sched-energy: CPU device node has no sched-energy-costs
[    0.212480] ASID allocator initialised with 65536 entries
[    0.239989] tegra-id: chipid=22117.
[    0.240020] tegra-id: opt_subrevision=0.
[    0.240043] Tegra Speedo/IDDQ fuse revision 4
[    0.240053] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.240063] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[    0.240073] Tegra: CPU Speedo Value 1989, SoC Speedo Value 1907, GPU Speedo Value 2001
[    0.240083] Tegra: CPU IDDQ Value 1548, SoC IDDQ Value 1992, GPU IDDQ Value 2290
[    0.240116] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[    0.240136] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.240156] DTB Build time: Jun 11 2024 16:09:23
[    0.289306] CPU1: Booted secondary processor [411fd071]
[    0.321190] CPU2: Booted secondary processor [411fd071]
[    0.353176] CPU3: Booted secondary processor [411fd071]
[    0.353269] Brought up 4 CPUs
[    0.353327] SMP: Total of 4 processors activated.
[    0.353345] CPU features: detected feature: 32-bit EL0 Support
[    0.353592] CPU: All CPU(s) started at EL2
[    0.353619] alternatives: patching kernel code
[    0.361712] devtmpfs: initialized
[    0.399537] Initilizing CustomIPI irq domain
[    0.399873] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.399915] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.411903] pinctrl core: initialized pinctrl subsystem
[    0.412527] OS set in device tree is not L4T.
[    0.412979] regulator-dummy: no parameters
[    0.413264] Initializing plugin-manager
[    0.413466] Plugin module not found
[    0.413671] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[    0.414192] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[    0.415183] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.415406] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.416057] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[    0.419845] NET: Registered protocol family 16
[    0.421235] pstore: using zlib compression
[    0.421769] console [pstore-1] enabled
[    0.421785] pstore: Registered ramoops as persistent store backend
[    0.421802] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.437323] cpuidle: using governor menu
[    0.441471] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.443112] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.443154] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.445796] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.448104] Serial: AMBA PL011 UART driver
[    0.448627] tegra_powergate_init: DONE
[    0.448657] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[    0.448693] DTB Build time: Jun 11 2024 16:09:23
[    0.450556] Tegra reboot handler registered.
[    0.455107] iommu: Adding device tegra-carveouts to group 0
[    0.455279] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.455650] iommu: Adding device smmu_test to group 1
[    0.455713] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.456547] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.456621] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.456684] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.456706] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.456740] mc-err: mcerr ops are set to t21x
[    0.467444] iommu: Adding device 70090000.xusb to group 2
[    0.467756] iommu: Adding device 70006000.serial to group 3
[    0.467851] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.468294] iommu: Adding device 70006040.serial to group 4
[    0.468583] iommu: Adding device 70006200.serial to group 5
[    0.468815] iommu: Adding device sound to group 6
[    0.468880] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.469505] iommu: Adding device 7000d400.spi to group 7
[    0.469776] iommu: Adding device 7000d600.spi to group 8
[    0.470067] iommu: Adding device 70410000.spi to group 9
[    0.470385] iommu: Adding device 50000000.host1x to group 10
[    0.470667] iommu: Adding device 54080000.vi to group 11
[    0.471062] iommu: Adding device 54600000.isp to group 12
[    0.471371] iommu: Adding device 54680000.isp to group 13
[    0.471648] iommu: Adding device tegradc.0 to group 14
[    0.471714] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.472245] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.472564] iommu: Adding device tegradc.1 to group 15
[    0.472629] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.473150] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.473439] iommu: Adding device 54340000.vic to group 16
[    0.473681] iommu: Adding device 544c0000.nvenc to group 17
[    0.473898] iommu: Adding device 54500000.tsec to group 18
[    0.474107] iommu: Adding device 54100000.tsecb to group 19
[    0.474337] iommu: Adding device 54480000.nvdec to group 20
[    0.474537] iommu: Adding device 54380000.nvjpg to group 21
[    0.475574] iommu: Adding device 546c0000.i2c to group 22
[    0.475918] iommu: Adding device 57000000.gpu to group 23
[    0.475989] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.476044] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.476101] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.476175] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.477053] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.477092] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.477117] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.477136] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.477152] tegra-pmc: ### PMC reset status reg: 0x3
[    0.529370] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.529404] tegra-pmc: Clear bootloader IO dpd settings
[    0.529438] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.529514] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.529826] iommu: Adding device 70012000.se to group 24
[    0.530405] iommu: Adding device 1003000.pcie to group 25
[    0.530476] platform 1003000.pcie: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.530955] iommu: Adding device 7000c000.i2c to group 26
[    0.531229] iommu: Adding device 7000c400.i2c to group 27
[    0.531487] iommu: Adding device 7000c500.i2c to group 28
[    0.531749] iommu: Adding device 7000c700.i2c to group 29
[    0.532013] iommu: Adding device 7000d000.i2c to group 30
[    0.532280] iommu: Adding device 7000d100.i2c to group 31
[    0.532586] iommu: Adding device sdhci-tegra.0 to group 32
[    0.532654] platform sdhci-tegra.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.533505] iommu: Adding device 700d0000.xudc to group 33
[    0.536766] vdd-ac-bat: 5000 mV
[    0.537140] vdd-5v0-sys: 5000 mV
[    0.537837] vdd-5v0-hdmi: 5000 mV
[    0.538279] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.538545] vdd-1v8-sys: 1800 mV
[    0.538984] vdd-fan: 5000 mV
[    0.539211] vdd-fan: supplied by vdd-5v0-sys
[    0.539438] vdd-usb-vbus: 5000 mV
[    0.539660] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.540008] vdd-usb-vbus2: 5000 mV
[    0.570302] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.572681] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.573898] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.573942] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.573976] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.574361] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.582283] eventlib_kernel: keventlib is initialized, test id: 0
[    0.582668] SCSI subsystem initialized
[    0.582861] libata version 3.00 loaded.
[    0.583134] usbcore: registered new interface driver usbfs
[    0.583206] usbcore: registered new interface driver hub
[    0.583263] usbcore: registered new device driver usb
[    0.587124] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.593303] vdd-core: 600 <--> 1162 mV at 1125 mV
[    0.594314] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.597241] vdd-ddr-1v1: 1150 mV
[    0.601196] vdd-pre-reg-1v35: 1350 mV
[    0.605191] vdd-1v8: 1800 mV
[    0.609193] avdd-sys-1v2: 1200 mV
[    0.613193] vdd-pex-1v0: 1050 mV
[    0.613867] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.614419] max77620-ldo3: at 3100 mV
[    0.617196] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.617748] max77620-ldo5: at 3100 mV
[    0.621196] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.625193] avdd-1v05-pll: 1050 mV
[    0.629191] avdd-io-hdmi-dp: 1050 mV
[    0.631724] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.632033] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.632357] max77620 4-003c: max77620 probe successful
[    0.635107] media: Linux media interface: v0.10
[    0.635189] Linux video capture interface: v2.00
[    0.636169] pps_core: LinuxPPS API ver. 1 registered
[    0.636192] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.636235] PTP clock support registered
[    0.639466] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.640361] Advanced Linux Sound Architecture Driver Initialized.
[    0.640983] Bluetooth: Core ver 2.22
[    0.641046] NET: Registered protocol family 31
[    0.641062] Bluetooth: HCI device and connection manager initialized
[    0.641087] Bluetooth: HCI socket layer initialized
[    0.641107] Bluetooth: L2CAP socket layer initialized
[    0.641143] Bluetooth: SCO socket layer initialized
[    0.643084] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.643126] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.643195] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.643223] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.646896] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.648110] vdd-3v3-sys: 3300 mV
[    0.648501] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.648568] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.653410] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.653883] vdd-3v3-sd: 3300 mV
[    0.654290] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.654916] avdd-io-edp-1v05: 1050 mV
[    0.655295] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.655445] vdd-usb-hub-en: 5000 mV
[    0.655796] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.656916] camchar: rtcpu character device driver loaded
[    0.657665] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[    0.659068] clocksource: Switched to clocksource arch_sys_counter
[    0.699221] VFS: Disk quotas dquot_6.6.0
[    0.699396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.699935] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.700399] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.700439]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.700655] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.700680] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.700707] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.700766] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.700790] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.700830] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.700852] nvmap_page_pool_init: Total RAM pages: 1010846
[    0.700868] nvmap_page_pool_init: nvmap page pool size: 126355 pages (493 MB)
[    0.700985] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.701426] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.702343] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.710401] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.710869] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.711277] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.711568] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.711768] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.712074] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.712093] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.712564] NET: Registered protocol family 2
[    0.712726] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.735349] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.735591] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.736107] TCP: Hash tables configured (established 32768 bind 32768)
[    0.736272] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.736367] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.736807] NET: Registered protocol family 1
[    0.737489] RPC: Registered named UNIX socket transport module.
[    0.737514] RPC: Registered udp transport module.
[    0.737530] RPC: Registered tcp transport module.
[    0.737546] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.737570] PCI: CLS 0 bytes, default 64
[    0.737820] Trying to unpack rootfs image as initramfs...
[    1.045866] Freeing initrd memory: 6992K
[    1.055804] host1x 50000000.host1x: initialized
[    1.057679] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.060996] audit: initializing netlink subsys (disabled)
[    1.061110] audit: type=2000 audit(0.895:1): initialized
[    1.061807] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.071674] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.073172] ntfs: driver 2.1.32 [Flags: R/W].
[    1.073999] 9p: Installing v9fs 9p2000 file system support
[    1.077267] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.077411] io scheduler noop registered
[    1.077742] io scheduler cfq registered (default)
[    1.080508] gic 702f9000.agic: GIC IRQ controller registered
[    1.083896] iommu: Adding device 702ef000.adsp to group 34
[    1.092757] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[    1.092930] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    1.093565] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x71a7c0e
[    1.093594] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.095241] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.095388] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.095498] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.095721] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.095840] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.095950] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.096060] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.096169] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.096275] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.096377] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.102765] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    1.104524] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    1.106429] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.107731] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.108087] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.109405] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.109649] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    1.109919] Adding domain tsec-pd to PM domain host1x-pd
[    1.112238] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.113263] tsec 54500000.tsec: initialized
[    1.114849] tsec 54100000.tsecb: initialized
[    1.115621] Adding domain nvdec-pd to PM domain host1x-pd
[    1.119044] nvdec 54480000.nvdec: initialized
[    1.120225] Adding domain vic03-pd to PM domain host1x-pd
[    1.120425] Adding domain msenc-pd to PM domain host1x-pd
[    1.120604] Adding domain nvjpg-pd to PM domain host1x-pd
[    1.124636] falcon 54340000.vic: initialized
[    1.125922] falcon 544c0000.nvenc: initialized
[    1.127332] falcon 54380000.nvjpg: initialized
[    1.131920] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    1.131999] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.132047] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.132054] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.132145] display board info: id 0x0, fab 0x0
[    1.132218] generic_infoframe_type: 0x87
[    1.132358] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.132375] tegradc tegradc.0: DT parsed successfully
[    1.132391] tegra_cec 70015000.tegra_cec: probed
[    1.132418] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    1.136069] tegradc tegradc.0: probed
[    1.136801] Console: switching to colour frame buffer device 80x30
[    1.136854] tegradc tegradc.0: fb registered
[    1.138102] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    1.138195] tegradc tegradc.1: No lt-data, using default setting
[    1.138235] tegradc tegradc.1: No hpd-gpio in DT
[    1.138275] tegradc tegradc.1: DT parsed successfully
[    1.138332] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[    1.140074] tegradc tegradc.1: dpd enable lookup fail:-19
[    1.140776] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.645813] Host read timeout at address 545c00c4
[    1.647567] tegradc tegradc.1: probed
[    1.648008] tegradc tegradc.1: fb registered
[    1.648833] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.649710] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.649730] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.650043] kfuse 7000fc00.kfuse: initialized
[    1.650944] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.651243] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.651263] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.651283] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.651306] tegradc tegradc.1: blank - powerdown
[    1.651336] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[    1.651351] Extcon DP: HPD disabled
[    1.651362] hpd: hpd_switch 0
[    1.651373] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.651391] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.651407] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.651862] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.652794] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.652819] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.653262] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.654496] vdd-gpu: applied init 1000000uV constraint
[    1.654515] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.654868] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.658537] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.658653] No Device Node present for smmu client: serial8250 !!
[    1.658672] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.658725] iommu: Adding device serial8250 to group 36
[    1.661075] console [ttyS0] disabled
[    1.661187] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    2.036988] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.155097] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.155102] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.440127] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.843990] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.846006] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.952199] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.952210] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.952215] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.952221] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.952227] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.952270] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.952397] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.952623] iommu: Adding device 0000:00:02.0 to group 37
[    2.952734] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.952909] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.952940] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.952978] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.953003] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.953186] pci 0000:01:00.0: supports D1 D2
[    2.953190] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.953407] iommu: Adding device 0000:01:00.0 to group 38
[    2.963181] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.963232] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    2.963238] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.963248] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[    2.963270] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[    2.963291] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.963301] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.963308] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.963314] pci 0000:00:02.0:   bridge window [mem 0x13000000-0x130fffff]
[    2.963750] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.963755] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.963761] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.963888] aer 0000:00:02.0:pcie002: service driver aer loaded
[    4.207863] console [ttyS0] enabled
[    4.212597] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    4.221796] serial-tegra 70006200.serial: RX in PIO mode
[    4.227238] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    4.237088] [drm] Initialized
[    4.250086] brd: module loaded
[    4.258411] loop: module loaded
[    4.261692] tegra_profiler: version: 1.145, samples/io: 49/28
[    4.267716] tegra_profiler: auth: init
[    4.272847] THERMAL EST: found 2 subdevs
[    4.276807] THERMAL EST num_resources: 0
[    4.280756] [THERMAL EST subdev 0]
[    4.284191] [THERMAL EST subdev 1]
[    4.288056] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    4.297025] THERMAL EST: thz register success.
[    4.301637] THERMAL EST: end of probe, return err: 0
[    4.307866] sd: No Scsi addr parsed to reserve index
[    4.312887] hisi_sas: driver version v1.6
[    4.321833] tegra-qspi 70410000.spi: Prod settings list not found
[    4.329122] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[    4.334556] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[    4.350531] tun: Universal TUN/TAP device driver, 1.6
[    4.355659] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.362850] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.368708] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.374704] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.381677] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.387308] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.395143] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.401116] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    4.408775] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    4.415534] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    4.421416] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    4.442189] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    4.454574] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:3d:4e:28 from device tree
[    4.467142] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    4.478591] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
[    4.509966] PPP generic driver version 2.4.2
[    4.514457] PPP BSD Compression module registered
[    4.519181] PPP Deflate Compression module registered
[    4.524271] PPP MPPE Compression module registered
[    4.529074] NET: Registered protocol family 24
[    4.533596] usbcore: registered new interface driver r8152
[    4.539136] usbcore: registered new interface driver asix
[    4.544609] usbcore: registered new interface driver ax88179_178a
[    4.550747] usbcore: registered new interface driver cdc_ether
[    4.556618] usbcore: registered new interface driver net1080
[    4.562320] usbcore: registered new interface driver cdc_subset
[    4.568280] usbcore: registered new interface driver zaurus
[    4.573929] usbcore: registered new interface driver cdc_ncm
[    4.579761] VFIO - User Level meta-driver version: 0.3
[    4.586136] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.592698] ehci-pci: EHCI PCI platform driver
[    4.597204] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.603394] ohci-pci: OHCI PCI platform driver
[    4.607889] ohci-platform: OHCI generic platform driver
[    4.615803] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    4.622184] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    4.630525] tegra-xusb 70090000.xusb: extcon 0:         (ptrval) id
[    4.639104] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[    4.643204] usbcore: registered new interface driver uas
[    4.643272] usbcore: registered new interface driver usb-storage
[    4.643461] usbcore: registered new interface driver usbserial
[    4.646856] tegra-xudc-new 700d0000.xudc: device count: 1
[    4.648467] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    4.648483] tegra-xudc-new 700d0000.xudc: vbus state: 1
[    4.648499] tegra-xudc-new 700d0000.xudc: device mode on: 0
[    4.648523] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[    4.648550] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[    4.649229] mousedev: PS/2 mouse device common for all mice
[    4.649313] usbcore: registered new interface driver xpad
[    4.711845] tegra-xusb 70090000.xusb: xHCI Host Controller
[    4.717375] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    4.725817] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    4.734575] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    4.740675] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.747477] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.754703] usb usb1: Product: xHCI Host Controller
[    4.759587] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    4.765597] usb usb1: SerialNumber: 70090000.xusb
[    4.770956] hub 1-0:1.0: USB hub found
[    4.774762] hub 1-0:1.0: 5 ports detected
[    4.779336] tegra-xusb 70090000.xusb: xHCI Host Controller
[    4.780380] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    4.782850] rtc rtc1: alarm rtc device
[    4.782868] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    4.782897] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    4.783551] i2c /dev entries driver
[    4.785728] i2c i2c-6: Added multiplexed i2c bus 7
[    4.786134] i2c i2c-6: Added multiplexed i2c bus 8
[    4.786140] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[    4.787118] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    4.810453] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    4.810549] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.810652] imx219 7-0010: board setup failed
[    4.810723] imx219: probe of 7-0010 failed with error -121
[    4.811328] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    4.834600] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    4.834679] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.834739] imx219 8-0010: board setup failed
[    4.834792] imx219: probe of 8-0010 failed with error -121
[    4.836216] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    4.838687] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    4.838692] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    4.839150] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.839165] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    4.839174] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    4.839348] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.839357] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    4.839363] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    4.839506] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.839516] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    4.839521] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    4.839690] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    4.840488] tegra_aotag tegra-aotag: Registering sensor 0
[    4.840548] tegra_aotag tegra-aotag: Invalid temp readout
[    4.840576] tegra_aotag tegra-aotag: Invalid temp readout
[    4.840593] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    4.840602] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    4.841539] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.841559] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    4.841749] tegra_aotag tegra-aotag: Invalid temp readout
[    4.841781] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    4.842208] parse_throttle_dt_data: Num cap clks = 6
[    4.842213] parse_throttle_dt_data: clk=cclk_g type=2
[    4.842227] parse_throttle_dt_data: clk=gpu type=4
[    4.842255] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    4.842276] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    4.842299] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    4.842301] parse_throttle_dt_data: clk=emc type=3
[    4.842663] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.842766] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.842898] tegra_throttle_probe: probe successful. #cdevs=4
[    4.843720] FAN dev name: pwm-fan
[    4.843790] FAN:gpio request success.
[    4.843848] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    4.844159] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    4.844339] pwm_fan_driver pwm-fan: fan tach request irq success
[    4.844349] pwm_fan_driver pwm-fan: tach period: 1000
[    4.844453] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    4.844458] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    4.844463] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    4.844467] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    4.844471] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    4.844475] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    4.844479] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    4.844483] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    4.844487] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    4.844491] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    4.847293] device-mapper: uevent: version 1.0.3
[    4.847759] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    4.853087] tegra210-cpufreq cpufreq: probe()...completed
[    4.853821] sdhci: Secure Digital Host Controller Interface driver
[    4.853823] sdhci: Copyright(c) Pierre Ossman
[    4.853824] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.854304] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    4.854651] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    4.854771] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[    4.859332] tegra-se 70012000.se: tegra_se_probe: complete
[    4.859845] hidraw: raw HID events driver (C) Jiri Kosina
[    4.860970] usbcore: registered new interface driver usbhid
[    4.860972] usbhid: USB HID core driver
[    4.862349] ashmem: initialized
[    4.863384] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    4.863598] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    4.866283] nvpmodel: initialized successfully
[    4.867279] usbcore: registered new interface driver snd-usb-audio
[    4.867333] No Device Node present for smmu client: snd-soc-dummy !!
[    4.867337] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    4.867354] iommu: Adding device snd-soc-dummy to group 39
[    4.881054] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    4.882319] OPE platform probe
[    4.882404] OPE platform probe successful
[    4.882684] OPE platform probe
[    4.882766] OPE platform probe successful
[    4.903318] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    4.913652] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    4.913776] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    4.913899] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    4.914019] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    4.914137] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    4.914263] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    4.914386] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    4.914508] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    4.914627] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    4.914763] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    4.926276] u32 classifier
[    4.926277]     Actions configured
[    4.926349] Initializing XFRM netlink socket
[    4.927095] NET: Registered protocol family 10
[    4.927827] NET: Registered protocol family 17
[    4.927837] NET: Registered protocol family 15
[    4.927917] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.927962] Bluetooth: RFCOMM socket layer initialized
[    4.927970] Bluetooth: RFCOMM ver 1.11
[    4.927974] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.927978] Bluetooth: HIDP socket layer initialized
[    4.927995] 9pnet: Installing 9P2000 support
[    4.928039] Key type dns_resolver registered
[    4.937114] Registered cp15_barrier emulation handler
[    4.937168] Registered setend emulation handler
[    4.938199] registered taskstats version 1
[    4.938809] Adding domain ve2-pd to PM domain host1x-pd
[    4.939044] Adding domain ve-pd to PM domain host1x-pd
[    4.941071] isp 54600000.isp: initialized
[    4.941987] isp 54680000.isp: initialized
[    4.952225] last reset is due to software reset
[    4.952227] KERNEL: PMC reset status reg: 0x3
[    4.952286] BL: PMC reset status reg: 0x3
[    4.952288] BL: PMIC poweroff Event Recorder: 0x0
[    4.953736] clk_cbus_recalc_rate: no gbus parent
[    4.953740] clk_cbus_round_rate: no gbus parent
[    4.953742] clk_cbus_round_rate: no gbus parent
[    4.953748] clk_cbus_recalc_rate: no gbus parent
[    4.953849] clk_cbus_recalc_rate: no gbus parent
[    4.953852] clk_cbus_round_rate: no gbus parent
[    4.953853] clk_cbus_round_rate: no gbus parent
[    4.953857] clk_cbus_recalc_rate: no gbus parent
[    4.954539] tegra_dvfs: GPU-cap: registered
[    4.954595] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    4.954597] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[    4.954599] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[    4.955979] tegra_dvfs: vdd-gpu-vts: registered
[    4.956675] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    4.957301] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    4.957786] input: gpio-keys as /devices/gpio-keys/input/input1
[    4.990339] tegra_rtc 7000e000.rtc: setting system clock to 2024-08-14 09:04:20 UTC (1723626260)
[    4.991358] vi 54080000.vi: vi_probe: ++
[    4.994584] vi 54080000.vi: initialized
[    4.996576] vi 54080000.vi: subdev nvcsi--2 bound
[    4.996676] vi 54080000.vi: subdev nvcsi--1 bound
[    4.998132] Disable partitions left on by BL
[    4.998134]   disb
[    4.998179] bwmgr: missing cdev-type property
[    4.998306] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    4.998313] DRAM derating cdev registered.
[    4.999173] ALSA device list:
[    4.999176]   #0: tegra-hda at 0x70038000 irq 83
[    4.999177]   #1: tegra-snd-t210ref-mobile-rt565x
[    5.104081] mmc0: hw tuning done ...
[    5.104114] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[    5.108511] mmcblk0: mmc0:59b4       232 GiB
[    5.111512]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    5.730184] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    5.737911] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.741247] Freeing unused kernel memory: 8640K
[    5.750601] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    5.757411] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.764651] usb usb2: Product: xHCI Host Controller
[    5.769542] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    5.773090] Root device found: mmcblk0p1
[    5.774496] Found dev node: /dev/mmcblk0p1
[    5.783585] usb usb2: SerialNumber: 70090000.xusb
[    5.788497] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    5.795460] hub 2-0:1.0: USB hub found
[    5.799247] hub 2-0:1.0: 4 ports detected
[    5.803843] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    5.809668] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    5.875448] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    5.885489] Rootfs mounted over mmcblk0p1
[    5.907635] Switching from initrd to actual rootfs
[    6.023144] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    6.056664] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[    6.063382] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.070516] usb 1-2: Product: 4-Port USB 2.1 Hub
[    6.075136] usb 1-2: Manufacturer: Generic
[    6.080309] hub 1-2:1.0: USB hub found
[    6.084697] hub 1-2:1.0: 4 ports detected
[    6.122250] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.138768] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[    6.147771] cgroup: cgroup2: unknown option "nsdelegate"
[    6.167561] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[    6.184827] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
[    6.200252] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[    6.206972] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.214455] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[    6.229040] usb 2-1: Product: 4-Port USB 3.1 Hub
[    6.234425] usb 1-2: usb_suspend_both: status 0
[    6.240152] usb 2-1: Manufacturer: Generic
[    6.240598] usb usb1: usb_suspend_both: status 0
[    6.244014] hub 2-1:1.0: USB hub found
[    6.244846] hub 2-1:1.0: 4 ports detected
[    6.399076] usb 2-1: usb_suspend_both: status 0
[    6.403897] usb usb2: usb_suspend_both: status 0
[    6.665997] random: systemd: uninitialized urandom read (16 bytes read)
[    6.676453] random: systemd: uninitialized urandom read (16 bytes read)
[    6.685360] random: systemd: uninitialized urandom read (16 bytes read)
[    6.751320] fuse init (API version 7.26)
[    6.752128] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    6.941688] systemd-journald[1937]: Received client request to flush runtime journal.
[    7.665363] proc: unrecognized mount option "hidepid=invisible" or missing value
[    7.679957] random: systemd: uninitialized urandom read (16 bytes read)
[    7.693527] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    7.693954] random: systemd: uninitialized urandom read (16 bytes read)
[    7.894946] proc: unrecognized mount option "hidepid=invisible" or missing value
[    7.971203] tegra-xusb 70090000.xusb: entering ELPG
[    7.973675] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[    7.975862] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[    7.977645] tegra-xusb 70090000.xusb: entering ELPG done
[    8.015896] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    8.015918] cpu-throttle-alert cooling device registered.
[    8.016028] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    8.016042] gpu-throttle-alert cooling device registered.
[    8.016179] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    8.016190] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    8.016203] hot-surface-alert cooling device registered.
[    8.021139] proc: unrecognized mount option "hidepid=invisible" or missing value
[    8.057653] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    8.060937] eth0: 0xffffff800a3fe000, 48:b0:2d:3d:4e:28, IRQ 406
[    8.147803] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.684992] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    8.700561] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    8.716833] random: systemd: uninitialized urandom read (16 bytes read)
[   10.375070] random: crng init done
[   10.378475] random: 345 urandom warning(s) missed due to ratelimiting
[   11.203130] r8168: eth0: link up
[   11.203154] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.331788] zram: Added device: zram0
[   12.333008] zram: Added device: zram1
[   12.333924] zram: Added device: zram2
[   12.339992] zram: Added device: zram3
[   12.354458] zram0: detected capacity change from 0 to 519557120
[   12.367370] Adding 507376k swap on /dev/zram0.  Priority:5 extents:1 across:507376k SS
[   12.370274] zram1: detected capacity change from 0 to 519557120
[   12.382240] Adding 507376k swap on /dev/zram1.  Priority:5 extents:1 across:507376k SS
[   12.384987] zram2: detected capacity change from 0 to 519557120
[   12.394407] Adding 507376k swap on /dev/zram2.  Priority:5 extents:1 across:507376k SS
[   12.397188] zram3: detected capacity change from 0 to 519557120
[   12.407013] Adding 507376k swap on /dev/zram3.  Priority:5 extents:1 across:507376k SS
[   12.445342] proc: unrecognized mount option "hidepid=invisible" or missing value
[   15.212261] NFS: bad mount option value specified: minorversion=1
[   17.464174] Bridge firewalling registered
[   17.502514] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   17.573454] Netfilter messages via NETLINK v0.30.
[   17.689926] ctnetlink v0.93: registering with nfnetlink.
[   17.777721] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   17.853197] IPv6: ADDRCONF(NETDEV_UP): docker_gwbridge: link is not ready
[   18.876105] tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
[   18.883115] tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
[   18.926467] br0: renamed from ov-001000-wg425
[   18.983950] vxlan0: renamed from vx-001000-wg425
[   19.012281] br0: port 1(vxlan0) entered blocking state
[   19.012286] br0: port 1(vxlan0) entered disabled state
[   19.012413] device vxlan0 entered promiscuous mode
[   19.012732] br0: port 1(vxlan0) entered blocking state
[   19.012736] br0: port 1(vxlan0) entered forwarding state
[   19.052904] veth0: renamed from vethb8bc3f2
[   19.089597] br0: port 2(veth0) entered blocking state
[   19.089601] br0: port 2(veth0) entered disabled state
[   19.089729] device veth0 entered promiscuous mode
[   19.089965] br0: port 2(veth0) entered blocking state
[   19.089970] br0: port 2(veth0) entered forwarding state
[   19.179627] eth0: renamed from veth52ffaf2
[   19.209604] docker_gwbridge: port 1(veth1bbe322) entered blocking state
[   19.209608] docker_gwbridge: port 1(veth1bbe322) entered disabled state
[   19.209743] device veth1bbe322 entered promiscuous mode
[   19.209962] IPv6: ADDRCONF(NETDEV_UP): veth1bbe322: link is not ready
[   19.209967] docker_gwbridge: port 1(veth1bbe322) entered blocking state
[   19.209970] docker_gwbridge: port 1(veth1bbe322) entered forwarding state
[   19.214936] docker_gwbridge: port 1(veth1bbe322) entered disabled state
[   19.297248] eth1: renamed from vethd7ba2ac
[   19.319697] IPv6: ADDRCONF(NETDEV_CHANGE): veth1bbe322: link becomes ready
[   19.319833] docker_gwbridge: port 1(veth1bbe322) entered blocking state
[   19.319841] docker_gwbridge: port 1(veth1bbe322) entered forwarding state
[   19.320010] IPv6: ADDRCONF(NETDEV_CHANGE): docker_gwbridge: link becomes ready
[   19.368665] IPVS: Registered protocols (TCP, UDP)
[   19.369642] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[   19.369698] IPVS: Creating netns size=1928 id=0
[   19.369733] IPVS: Creating netns size=1928 id=1
[   19.369770] IPVS: Creating netns size=1928 id=2
[   19.369802] IPVS: Creating netns size=1928 id=3
[   19.369837] IPVS: ipvs loaded.
[   19.466455] IPVS: [rr] scheduler registered.
[   36.305755] vdd-fan: disabling
[   36.305800] vdd-usb-vbus: disabling
[   36.305832] vdd-usb-vbus2: disabling
[   36.305942] vddio-sdmmc3-ap: disabling
[   36.306646] avdd-io-edp-1v05: disabling
[   36.306679] vdd-usb-hub-en: disabling
Just a suggestion, if you want to keep sharing the logs, could you attach them as files but not copy and paste all the logs?
From what I saw, extlinux.conf is taking effect.
If you are talking about you added something in kernel cmdline but it didn’t change some driver behavior, then it is different cases. Please file a new topic and directly talking about what cannot take effect. This is not extlinux.conf problem.
