Thanks for getting back to me.
Adding the print statement
here is the diff of the spi-tegra114.c
diff --git a/drivers/spi/spi-tegra114.c b/drivers/spi/spi-tegra114.c
index d50705047a02..26895cc5be78 100644
--- a/drivers/spi/spi-tegra114.c
+++ b/drivers/spi/spi-tegra114.c
@@ -634,6 +634,7 @@ static int tegra_spi_start_dma_based_transfer(
int ret = 0;
u8 dma_burst;
struct dma_slave_config dma_sconfig = {0};
+ dev_info(tspi->dev, "Entered Start DMA based transfer\n");
/* Make sure that Rx and Tx fifo are empty */
ret = tegra_spi_clear_fifo(tspi);
This is embarrassing, it turns out there was an error I haven’t never noticed before:
Dump of DMESG
[ 67.161534] spi-tegra114 3230000.spi: interrupt raised in polling mode
[ 67.192502] spi-tegra114 3230000.spi: transfer timeout (polling)
[ 67.192791] ------------[ cut here ]------------
[ 67.192811] WARNING: CPU: 0 PID: 3048 at drivers/spi/spi-tegra114.c:1461 tegra_spi_transfer_one_message+0x5a0/0xcac [spi_tegra114]
[ 67.193084] Modules linked in: fuse aes_ce_ccm rtl8xxxu rtl8192cu rtl_usb rtl8192c_common rtlwifi mac80211 cfg80211 snd_soc_tegra210_ope snd_soc_tegra186_asrc snd_soc_tegra210_iqc snd_soc_tegra186_dspk snd_soc_tegra210_mvc snd_soc_tegra186_arad snd_soc_tegra210_afc snd_soc_tegra210_amx snd_soc_tegra210_dmic snd_soc_tegra210_adx snd_soc_tegra210_i2s snd_soc_tegra210_mixer ofpart snd_soc_tegra210_admaif cmdlinepart qspi_mtd snd_soc_tegra210_sfc snd_soc_tegra_pcm mtd xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter aes_ce_blk crypto_simd cryptd aes_ce_cipher ghash_ce sha2_ce sha256_arm64 sha1_ce lzo_rle lzo_compress zram overlay leds_gpio snd_soc_spdif_tx snd_soc_tegra_machine_driver snd_soc_tegra210_adsp realtek snd_soc_tegra_utils snd_soc_simple_card_utils nvadsp loop max77620_thermal tegra210_adma snd_soc_tegra210_ahub snd_hda_codec_hdmi spidev tegra_bpmp_thermal
[ 67.193339] userspace_alert ina3221 snd_hda_tegra pwm_fan snd_hda_codec imx265 snd_hda_core imx265_fpga nvgpu spi_tegra114 spi_tegra210_qspi binfmt_misc nvmap ramoops reed_solomon ip_tables x_tables
[ 67.193401] CPU: 0 PID: 3048 Comm: adis-imu-contro Tainted: G OE 5.10.104-tegra #3
[ 67.193406] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 1.0-d7fb19b 08/10/2022
[ 67.193412] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
[ 67.193422] pc : tegra_spi_transfer_one_message+0x5a0/0xcac [spi_tegra114]
[ 67.193430] lr : tegra_spi_transfer_one_message+0xbb4/0xcac [spi_tegra114]
[ 67.193434] sp : ffff80001f94ba60
[ 67.193440] x29: ffff80001f94ba60 x28: ffff73b8d4caaf80
[ 67.193450] x27: ffff73b8cf6fe680 x26: ffff73bc3fe9a3a0
[ 67.193461] x25: 00000000000f4240 x24: 0000000000000001
[ 67.193471] x23: ffff73b8cf6fe680 x22: 0000000000000000
[ 67.193498] x21: ffff73b8ee161800 x20: ffff73b8cf6fe680
[ 67.193508] x19: ffff73b8ee17fe00 x18: 0000000000000010
[ 67.193518] x17: 0000000000000000 x16: 0000000000000000
[ 67.193541] x15: ffff73b8fba83f70 x14: ffffffffffffffff
[ 67.193551] x13: ffff80009f94b667 x12: ffff80001f94b66f
[ 67.193561] x11: 0000000000000003 x10: 0101010101010101
[ 67.193585] x9 : 00000000fffffffe x8 : 3332332034313161
[ 67.193595] x7 : 726765742d697073 x6 : c0000000ffffefff
[ 67.193605] x5 : 0000000000000000 x4 : ffff73bc3fd9b958
[ 67.193615] x3 : ffff73bc3fdaab08 x2 : 0000000000000000
[ 67.193649] x1 : 0000000000000000 x0 : 0000000000000000
[ 67.193660] Call trace:
[ 67.193669] tegra_spi_transfer_one_message+0x5a0/0xcac [spi_tegra114]
[ 67.193680] __spi_pump_messages+0x374/0x830
[ 67.193686] __spi_sync+0x2a4/0x2e0
[ 67.193692] spi_sync+0x38/0x60
[ 67.193700] spidev_sync+0x50/0x80 [spidev]
[ 67.193707] spidev_message+0x3dc/0x5e0 [spidev]
[ 67.193714] spidev_ioctl+0x764/0xba0 [spidev]
[ 67.193723] __arm64_sys_ioctl+0xac/0xf0
[ 67.193732] el0_svc_common.constprop.0+0x80/0x1d0
[ 67.193739] do_el0_svc+0x38/0xb0
[ 67.193748] el0_svc+0x1c/0x30
[ 67.193754] el0_sync_handler+0xa8/0xb0
[ 67.193760] el0_sync+0x16c/0x180
[ 67.193765] ---[ end trace f873c89474799f94 ]---
[ 67.193928] spi-tegra114 3230000.spi: spi transfer timeout, err 0
[ 67.194765] spi_master spi2: failed to transfer one message from queue
In the serial console I see the following relevant messages:
Some observations
Since I see there are messages relating to polling I’m removing it and running again:
Removed Polling Mode
I removed the ‘Polling Mode’ flag and it stopped the kernel error, I see no messages on either dmesg or the serial console but the problem still persists. I added more print statements but I don’t want to fill this post with all the intermediate steps I went through, here is where I am currently:
Skipping Ahead
I’ve added more print statements and now here is the diff of the spi-tegra114.c
index d50705047a02..771fd226a5aa 100644
int ret = 0;
u8 dma_burst;
@@ -735,6 +736,7 @@ static int tegra_spi_start_cpu_based_transfer(
u32 val;
unsigned cur_words;
int ret;
+ dev_info(tspi->dev, "Entered Start CPU based transfer\n");
if (ret != 0)
@@ -1496,11 +1498,17 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
msg->actual_length += xfer->len;
complete_xfer:
- if (prefer_last_used_cs)
+ dev_info(tspi->dev, "xfer_1_msg: Complete Transfer\n");
+ if (prefer_last_used_cs){
+ dev_info(tspi->dev, "xfer_1_msg: prefer last used cs\n");
cmd1 = tspi->command1_reg;
- else
+ else{
+ dev_info(tspi->dev, "xfer_1_msg: NOT prefer last used cs\n");
cmd1 = tspi->def_command1_reg;
if (ret < 0 || skip) {
+ dev_info(tspi->dev, "xfer_1_msg: ret: %d, skip: %s\n", ret, skip ? "yes": "no");
if (cstate && cstate->cs_gpio_valid)
gpio_set_value(spi->cs_gpio, gval);
tegra_spi_writel(tspi, cmd1, SPI_COMMAND1);
@@ -1508,6 +1516,7 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
goto exit;
} else if (list_is_last(&xfer->transfer_list,
&msg->transfers)) {
+ dev_info(tspi->dev, "xfer_1_msg: List is last\n");
if (xfer->cs_change)
tspi->cs_control = spi;
else {
@@ -1517,6 +1526,7 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
tegra_spi_transfer_delay(xfer->delay_usecs);
} else if (xfer->cs_change) {
+ dev_info(tspi->dev, "xfer_1_msg: CS Change\n");
@@ -1526,14 +1536,19 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
ret = 0;
exit:
+ dev_info(tspi->dev, "xfer_1_msg: Exit, prefer last used cs\n");
cmd1 = SPI_CMD1_GR_MASK & tspi->command1_reg;
- else
+ else{
+ dev_info(tspi->dev, "xfer_1_msg: Exit, NOT prefer last used cs\n");
cmd1 = tegra_spi_readl(tspi, SPI_COMMAND1);
/* CS de-assert is required before clock
* goes to it's default state.
if (!tspi->is_hw_based_cs) {
+ dev_info(tspi->dev, "xfer_1_msg: Exit, NOT HW BASED CS, De-assert CS\n");
if (spi->mode & SPI_CS_HIGH) {
/* Active high. Reset the value to make it deactive */
cmd1 &= ~SPI_CS_SW_VAL;
@@ -1544,11 +1559,14 @@ static int tegra_spi_transfer_one_message(struct spi_controller *ctrl,
- if (!prefer_last_used_cs)
+ if (!prefer_last_used_cs){
+ dev_info(tspi->dev, "xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x%08X\n", tspi->def_command1_reg);
tegra_spi_writel(tspi, tspi->def_command1_reg, SPI_COMMAND1);
msg->status = ret;
spi_finalize_current_message(ctrl);
+ dev_info(tspi->dev, "xfer_1_msg: Exit, Exiting with status: %d\n", ret);
return ret;
@@ -1583,6 +1601,7 @@ static irqreturn_t handle_cpu_based_xfer(struct tegra_spi_data *tspi)
tspi->cur_pos = tspi->cur_rx_pos;
if (tspi->cur_pos == t->len) {
+ dev_info(tspi->dev, "CpuXfer: CUR POS == LEN\n");
complete(&tspi->xfer_completion);
goto exit;
@@ -1721,6 +1740,7 @@ static int tegra_spi_status_poll(struct tegra_spi_data *tspi)
static irqreturn_t tegra_spi_isr_thread(int irq, void *context_data)
struct tegra_spi_data *tspi = context_data;
+ dev_info(tspi->dev, "spi_threaded_isr entered\n");
if (!tspi->is_curr_dma_xfer)
return handle_cpu_based_xfer(tspi);
@@ -1734,7 +1754,9 @@ static irqreturn_t tegra_spi_isr(int irq, void *context_data)
if (tspi->polling_mode)
dev_warn(tspi->dev, "interrupt raised in polling mode\n");
tspi->status_reg = tegra_spi_readl(tspi, SPI_FIFO_STATUS);
+ dev_info(tspi->dev, "spi_isr entered, FIFO status: 0x%08X\n", tspi->status_reg);
if (tspi->cur_direction & DATA_DIR_TX)
tspi->tx_status = tspi->status_reg &
(SPI_TX_FIFO_UNF | SPI_TX_FIFO_OVF);
I’ve reduced the number of SPI transactions so the application terminates when it transfers one large packet, this will help with the number of messages received.
[ 310.783980] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 310.784113] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 310.784165] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 310.784179] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 310.790287] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 310.790296] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 310.790301] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 310.790306] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 310.790314] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT HW BASED CS, De-assert CS
[ 310.790322] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 310.791090] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 310.792532] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 310.792600] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 310.792712] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 310.792721] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 310.793096] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 310.793103] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 310.793108] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 310.793113] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 310.793121] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 310.793575] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.229065] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.229146] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.229181] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.229193] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.229235] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.229246] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.229255] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.229263] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.229274] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.231682] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.243216] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.243291] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.243314] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.243323] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.243397] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.243404] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.243409] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.243413] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.243421] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.245802] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.260508] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.260628] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.260653] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.260662] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.260738] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.260745] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.260750] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.260755] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.260763] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.262455] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.264362] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.264434] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.264533] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.264544] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.265340] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.265349] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.265354] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.265360] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.265369] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.266588] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.269491] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.269558] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.269582] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.269591] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.269646] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.269653] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.269658] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.269663] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.269670] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.271221] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.272851] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.272915] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.272936] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.272944] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.273021] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.273028] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.273033] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.273038] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.273045] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.274473] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.276176] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.276241] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.276266] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.276273] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.277193] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.277201] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.277206] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.277210] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.277218] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.278232] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.279242] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.279305] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x00C00004
[ 311.279332] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.279340] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.279506] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.279513] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.279518] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.279523] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.279531] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.280932] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
[ 311.293071] spi-tegra114 3230000.spi: Entered Start CPU based transfer
[ 311.293311] spi-tegra114 3230000.spi: spi_isr entered, FIFO status: 0x03400004
[ 311.293338] spi-tegra114 3230000.spi: spi_threaded_isr entered
[ 311.293353] spi-tegra114 3230000.spi: CpuXfer: CUR POS == LEN
[ 311.293646] spi-tegra114 3230000.spi: xfer_1_msg: Complete Transfer
[ 311.293653] spi-tegra114 3230000.spi: xfer_1_msg: NOT prefer last used cs
[ 311.293658] spi-tegra114 3230000.spi: xfer_1_msg: List is last
[ 311.293663] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs
[ 311.293670] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT HW BASED CS, De-assert CS
[ 311.293676] spi-tegra114 3230000.spi: xfer_1_msg: Exit, NOT prefer last used cs, send command: 0x40C08000
[ 311.295433] spi-tegra114 3230000.spi: xfer_1_msg: Exit, Exiting with status: 0
Looking at the SPI_FIFO_STATUS_0 register received within the ISR, I decoded it:
According to the SPI_FIFO_STATUS_0 register in the TRM:
Status: 0x00C00004
bit 2: 1 = TX_FIFO_EMPTY
bits 22:16: TX_FIFO_EMPTY_COUNT: 0x40
bits 29:23: RX_FIFO_FULL_COUNT: 0x01
Status: 0x03400004
bits 2: 1 = TX_FIFO_EMPTY
bits 22: 16: TX_FIFO_EMPTY_COUNT: 0x40
bits 29:23: RX_FIFO_FULL_COUNT: 0x06
Observations
I just verified that the 11 word large transfer was the last transaction and the error occurs when the TX FIFO status register says: 0x03400004
1 word transfer: Status: 0x00C00004
11 word transfer: Status: 0x03400004
This line is interesting:
it corresponds to these lines:
} else {
/* Active low. Set the value to make it deactive */
cmd1 |= SPI_CS_SW_VAL;
The CS line is being set high but the clock has already, seemingly, gone to a ‘default’ state on the larger transaction. If anyone has any suggestions I’ll try it out.
I’ll dig into this more.
Dave
