I need to extract the camera frame from the deepstream sdk pipeline in order to run a specific algorithm on the camera frame separately (in parallel) from the DeepStream pipeline.
Moving to DeepStream SDK forum so that DeepStream team can take a look.
You could add a tee or GstInterpipe to the pipeline and use an appsink
in the second branch, like this:
Another option is to implement an element based on GstVideoFilter and add it to the DeepStream pipeline. You can perform the custom algorithm in the _transform_ip
virtual method. For a reference you can check our perf
plugin that is quite simple, based on VideoFilter and implements transform_ip
: gst-perf/plugins at master · RidgeRun/gst-perf · GitHub
Is there further reference you could provide, I am trying to get example 2 to work so I can understand how I can tolerate the example to get what I am trying to do to work however, I am receiving a null pointer error.
