Hi. I would like to extract confidence heatmap from detectnet after detection for some additional analysis. As i see from source code, these map is situated in mOutputs[OUTPUT_CVG].CPU (see below). Is that true? It is the same heatmap which i can see using DIGITS (like on picture below)?
int detectNet::clusterDetections( Detection* detections, uint32_t width, uint32_t height )
// cluster detection bboxes
float* net_cvg = mOutputs[OUTPUT_CVG].CPU;
