Extracted frame problem
I was able to extract the frame using:
surface->surfaceList[frame_meta->batch_id].dataPtr
in function
static GstPadProbeReturn
gie_primary_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
	gpointer u_data)
However, I have multiple questions.
  1. The dataPtr has always one of the 4 values. Its pattern is a->b->c->d->a …
a)0x7f10158de0
b)0x7f10159350
c)0x7f101598c0
d)0x7f10158870
a)0x7f10158de0
Why it always rotates like this?
  1. I send this dataPtr to Python with stdout piping. After converting the frame to NumPy, I use cv2.imshow(“”, frame) to visualize. Attached you will find the output image.
Left one is the correct frame. While the right one is the Python numpy imshow’ed frame.
There is a similar sample. Please refer to 5 in FAQ
You should need to convert to BGR before calling cv2.imshow()
cv::cvtColor (in_mat, bgr_frame, CV_RGBA2BGR);
Which code block should I use the post
https://devtalk.nvidia.com/default/topic/1061205/deepstream-sdk/rtsp-camera-access-frame-issue/post/5377678/#5377678 ?
Please refer to below sample:
#if 1
  static int dump = 0;
  if (dump < 150) {
    GstMapInfo in_map_info;
    NvBufSurface *surface = NULL;
    memset (&in_map_info, 0, sizeof (in_map_info));
    if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
      g_print ("Error: Failed to map gst buffer\n");
      gst_buffer_unmap (buf, &in_map_info);
      return GST_PAD_PROBE_OK;
    cudaError_t cuda_err;
    NvBufSurfTransformRect src_rect, dst_rect;
    surface = (NvBufSurface *) in_map_info.data;
    int batch_size= surface->batchSize;
    printf("\nBatch Size : %d, resolution : %dx%d \n",batch_size,
        surface->surfaceList[0].width, surface->surfaceList[0].height);
    src_rect.top   = 0;
    src_rect.left  = 0;
    src_rect.width = (guint) surface->surfaceList[0].width;
    src_rect.height= (guint) surface->surfaceList[0].height;
    dst_rect.top   = 0;
    dst_rect.left  = 0;
    dst_rect.width = (guint) surface->surfaceList[0].width;
    dst_rect.height= (guint) surface->surfaceList[0].height;
    NvBufSurfTransformParams nvbufsurface_params;
    nvbufsurface_params.src_rect = &src_rect;
    nvbufsurface_params.dst_rect = &dst_rect;
    nvbufsurface_params.transform_flag =  NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
    nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
    NvBufSurface *dst_surface = NULL;
    NvBufSurfaceCreateParams nvbufsurface_create_params;
    /* An intermediate buffer for NV12/RGBA to BGR conversion  will be
     * required. Can be skipped if custom algorithm can work directly on NV12/RGBA. */
    nvbufsurface_create_params.gpuId  = surface->gpuId;
    nvbufsurface_create_params.width  = (gint) surface->surfaceList[0].width;
    nvbufsurface_create_params.height = (gint) surface->surfaceList[0].height;
    nvbufsurface_create_params.size = 0;
    nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
    nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
    nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
    cuda_err = cudaSetDevice (surface->gpuId);
    cudaStream_t cuda_stream;
    cuda_err=cudaStreamCreate (&cuda_stream);
    int create_result = NvBufSurfaceCreate(&dst_surface,batch_size,&nvbufsurface_create_params);
    NvBufSurfTransformConfigParams transform_config_params;
    NvBufSurfTransform_Error err;
    transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
    transform_config_params.gpu_id = surface->gpuId;
    transform_config_params.cuda_stream = cuda_stream;
    err = NvBufSurfTransformSetSessionParams (&transform_config_params);
    NvBufSurfaceMemSet (dst_surface, 0, 0, 0);
    err = NvBufSurfTransform (surface, dst_surface, &nvbufsurface_params);
    if (err != NvBufSurfTransformError_Success) {
  	  g_print ("NvBufSurfTransform failed with error %d while converting buffer\n", err);
    NvBufSurfaceMap (dst_surface, 0, 0, NVBUF_MAP_READ);
    NvBufSurfaceSyncForCpu (dst_surface, 0, 0);
    cv::Mat bgr_frame = cv::Mat (cv::Size(nvbufsurface_create_params.width, nvbufsurface_create_params.height), CV_8UC3);
    cv::Mat in_mat =
        cv::Mat (nvbufsurface_create_params.height, nvbufsurface_create_params.width,
        CV_8UC4, dst_surface->surfaceList[0].mappedAddr.addr[0],
        dst_surface->surfaceList[0].pitch);
    //imshow("original", bgr_frame);
    //waitKey(1);
    dump ++;
    NvBufSurfaceUnMap (dst_surface, 0, 0);
    NvBufSurfaceDestroy (dst_surface);
    cudaStreamDestroy (cuda_stream);
#endif
